How to Change Pitch in Premiere Pro (Step-by-Step Guide)
Whether you need to correct an off-key vocal recording, create a voice effect, or match background music to a new key, Premiere Pro has built-in tools to raise or lower audio pitch directly in your timeline. No third-party plugins required. This guide walks you through the two most reliable methods, clears up the common confusion between pitch and speed, and helps you get clean-sounding results fast.
What Pitch Adjustment Does in Premiere Pro
Pitch refers to the perceived frequency of a sound and how high or low a note or voice sounds. Changing pitch in Premiere Pro is completely separate from changing playback speed. The Pitch Shifter effect lets you raise or lower the tonal frequency of any audio clip while keeping the original duration and tempo intact.
Method 1 — Using the Pitch Shifter Effect (Recommended)
The Pitch Shifter effect is Premiere Pro’s most precise native tool for pitch adjustment. It gives you control over individual pitches, fine-tuning in cents, and algorithm quality settings, making it the right choice for most editing scenarios.
  1. Open the Effects panel. Go to Window > Effects in the top menu bar if the panel is not already visible.
  1. Navigate to the Pitch Shifter effect. In the Effects panel search bar, type “Pitch Shifter,” or browse manually to Audio Effects > Time and Pitch > Pitch Shifter.
  2. Drag the effect onto your clip. Click and drag the Pitch Shifter from the Effects panel onto the audio or video clip in your timeline. The effect attaches to the clip’s audio component.
  1. Open the Effect Controls panel. Click the clip in the timeline, then go to Window > Effect Controls. The Pitch Shifter will appear listed under the clip’s audio effects.
  2. Adjust the pitch settings. Click the Edit button or expand the Pitch Shifter controls. Use the Semitones slider to make broad pitch changes and the Cents slider for fine-tuning within a single semitone (100 cents equals one semitone).
  1. Choose your algorithm settings. Enable Use Appropriate Default Settings for a balanced result, or uncheck it to manually select a transposer preset suited to your audio type, such as voice or music.
  2. Preview and fine-tune. Play back the clip and adjust the sliders until the pitch matches your target.
Note: One octave equals 12 semitones. If you need to raise audio by a full octave, set the Semitones value to +12. For subtle pitch correction, a shift of 1 to 3 semitones is usually sufficient.
Method 2 — Using the Audio Pitch Effect
The Audio Pitch effect provides a faster, simpler alternative when you need a quick adjustment without the granular controls of the Pitch Shifter. This effect is available in Premiere Pro CC 2020 and later.
  1. Open the Effects panel and search for “Audio Pitch,” or browse to Audio Effects > Audio Pitch.
  2. Drag the effect onto your clip in the timeline.
  3. Open the Effect Controls panel and use the Pitch slider, measured in semitones, to raise or lower the pitch.
Use this method for minor, single-value corrections. Switch to the Pitch Shifter when you need precise cent-level control, algorithm selection, or more detailed handling of complex audio material. NOT WORKING
Adjusting Pitch Without Changing Speed
Both methods above change pitch independently of clip speed and duration. The tool to avoid is the Speed/Duration dialog (right-click a clip and select Speed/Duration), which ties pitch directly to playback speed. Speeding up a clip raises its pitch as a side effect, much like a tape player running too fast. The Pitch Shifter and Audio Pitch effects never alter clip duration, so your timing and sync stay exactly where you set them.
Tips for Natural-Sounding Pitch Shifts
  • Stay within ±3 to 4 semitones for speech and vocals. Larger shifts introduce audible artifacts and an unnatural tone quality.
  • Select the High Quality algorithm setting in the Pitch Shifter when available, especially for music or clean vocal recordings.
  • Apply subtle EQ or light reverb after pitch shifting to smooth any tonal stiffness the effect introduces.
  • For large shifts or precise vocal tuning, consider a round-trip to Adobe Audition via Edit > Edit in Adobe Audition, where more robust pitch correction algorithms are available.
Can I change pitch on a video clip in Premiere Pro?
Yes. Apply the Pitch Shifter to any clip in your timeline that contains audio, including video clips with embedded audio. The effect processes only the audio component; your video image, frame rate, and duration remain completely unchanged.
Why does my audio sound robotic after pitch shifting?
Robotic or warped audio is typically caused by shifting pitch beyond ±5 semitones using Premiere’s native algorithm. Try reducing the shift amount for a more natural result. For larger pitch changes, route the clip to Adobe Audition through a round-trip edit, where higher-quality pitch processing algorithms are available.
How do I change the pitch of background music in Premiere Pro?
Apply the Pitch Shifter effect to the music clip on your timeline using the same steps described above. If your goal is to key-match the music to a vocal, identify the original key of the track, determine your target key, and calculate the semitone difference between them to set the correct slider value.
Does changing pitch in Premiere Pro affect export quality?
No. Pitch adjustment is non-destructive; your original source file is never modified. The effect is rendered at export time. There is no additional quality loss beyond what the effect’s own algorithm introduces during processing.
The Pitch Shifter effect is the most reliable and flexible tool for changing pitch in Premiere Pro, covering everything from subtle vocal corrections to creative audio transformations. For advanced pitch correction such as melody tuning or detailed vocal repair, Adobe Audition offers more powerful processing through a seamless round-trip workflow. To continue building your audio skills, explore related guides on removing background noise in Premiere Pro or getting the most out of the Essential Sound panel.
