How to Auto Edit a Podcast in Premiere Pro: 3 Methods to Cut Your Editing Time
Manually cutting silence, removing filler words, and cleaning up audio takes hours per episode. Premiere Pro has three native methods that can significantly compress that time: transcript-based editing, automatic silence removal, and audio automation through the Essential Sound panel. This guide walks through each one step by step, so you can spend less time in the timeline and more time creating content.
What “Auto Editing” Actually Means in Premiere Pro
“Auto editing” in Premiere Pro does not mean pressing a single button and receiving a finished episode. What it does mean is using a set of AI-assisted and rule-based tools that handle the most repetitive parts of the editing process for you.
These tools can detect silence and remove it, generate a text transcript that lets you delete content by editing words rather than waveforms, and automatically normalize your audio levels across an entire episode. The result is a workflow that is measurably faster than manual frame-by-frame cuts, without requiring you to leave Adobe’s ecosystem or learn a separate application.
Think of these tools as handling the rough cut automatically, so your manual attention goes only toward the moments that genuinely require a human judgment call.
Method 1 — Edit by Transcript Using Premiere Pro Speech to Text
This is the most powerful native auto-edit method available in Premiere Pro. Instead of scrubbing through a waveform, you edit a text document and let Premiere Pro handle the timeline cuts.
Step 1: Open the Text Workspace
Go to Window > Workspaces > Text. This opens the dedicated text panel where transcripts are generated and managed. Place your podcast clip (audio or video) into a sequence before proceeding.
Step 2: Generate the Transcript
In the Text panel, pick the three-dot icon to open a secondary menu. Select the Generate static transcript and fill in the additional prompts, including language, speaker labeling, and audio analysis.
Step 3: Review and Edit the Transcript
Once transcription is complete, the full episode text appears in the panel. Read through it and highlight any section you want to remove: filler words such as “um,” “uh,” and “like,” false starts, repeated sentences, or extended tangents. Use the search bar to find every instance of a specific filler word across the entire transcript at once.
Step 4: Delete Unwanted Text
With unwanted text highlighted, press Delete. Premiere Pro automatically performs a ripple delete on the corresponding segment in the timeline, removing the audio and video simultaneously and closing the gap. There is no need to manually mark in/out points on the timeline.
Step 5: Refine and Export
Play back the sequence from the beginning to check for any joins that feel abrupt. Make manual trims only where transitions need smoothing. Once satisfied, export your sequence via File > Export > Media.
This workflow is the closest Premiere Pro gets to true auto-editing without third-party plugins. The quality of the output depends heavily on how clearly the speech was recorded.
How to Improve Transcription Accuracy
Premiere Pro’s Speech to Text engine performs best when the audio signal is clean and consistent. These steps reduce transcript errors before you even open the Text panel:
  • Record in a treated space to minimize room reflections and background noise that confuse the speech engine.
  • Keep consistent mic-to-mouth distance throughout the session to avoid level drops that read as silence or unintelligible audio.
  • Use a dedicated microphone with low self-noise rather than a built-in laptop mic or consumer headset.
  • Capture at 48 kHz / 32-bit Float with AI Noise Cancellation active at the source. Microphones like the Hollyland LARK MAX 2 record at this specification and apply hardware-level noise cancellation before the file reaches Premiere Pro, which means fewer background noise artifacts to confuse the speech engine and fewer transcript errors to correct manually.
  • Avoid heavy in-camera compression when shooting a video podcast, as compressed audio files introduce artifacts that degrade transcription results.
Method 2 — Auto Remove Silence in Premiere Pro
Silence removal works differently from transcript editing. Instead of parsing text, Premiere Pro analyzes the audio waveform and automatically cuts segments that fall below a defined volume threshold. There are two practical ways to do this.
Native: Delete Silence (Premiere Pro 2023 and Later)
  1. Place your audio or video clip in a sequence and select the clip in the timeline.
  2. Navigate to Sequence > Delete Silence in the top menu bar.
  3. The Delete Silence dialog opens with two key settings:
  • Minimum Silence Duration (ms): The shortest gap Premiere Pro will target. Start at 700 to 1,000 ms to avoid cutting short natural pauses between words.
  • Noise Gate Threshold (dB): The volume level below which audio is treated as silence. A threshold between -40 dB and -50 dB works well for most voice recordings in a quiet environment. Raise the threshold toward -30 dB in noisier recordings.
  1. Click Analyze to preview the proposed cuts. Review how many segments have been flagged and adjust your settings if too many or too few cuts appear.
  2. Click OK to apply. Premiere Pro generates a new sequence with the silent gaps removed. NOT WORKING
  1. Place the clip in a sequence and select it.
  2. Open the Text panel (Window > Text) and click the Transcript tab.
  3. Click Transcribe sequence (or Create transcription) and wait for it to finish.
  4. Silences appear in the transcript as pause markers — [...].
  5. Click the filter icon in the Transcript tab and choose Pauses — this isolates only the silent segments.
  1. Click Delete, then choose Extract > Delete all to ripple-delete the silences from the timeline.
Sensitivity tip: If the tool clips breath sounds or trailing syllables, lower the threshold by 5 to 10 dB and re-analyze. If significant dead air remains, raise the threshold slightly.
Plugin Option: Recut
Recut is a standalone application that integrates directly with Premiere Pro’s timeline through a dedicated panel. It scans the audio waveform, automatically identifies silence regions, and applies the cuts as direct timeline edits or as reviewable markers before you commit.
Recut is especially useful for high-volume production where you are editing multiple episodes per week. It processes silence removal faster than the native tool and provides visual control over each cut before anything is applied to the sequence.
Feature
Native Delete Silence
Recut
Cost
Free (included in CC)
Paid (subscription)
Speed
Moderate
Fast
Control
Dialog-based settings
Visual waveform review
Best For
Occasional use, single episodes
High-volume podcast production
For most solo podcasters, the native tool is sufficient. Recut becomes worthwhile once your editing volume justifies the subscription cost.
Method 3 — Automate Audio Cleanup with the Essential Sound Panel
The Essential Sound panel does not cut content from your timeline. Instead, it automates the audio quality work that would otherwise require manual EQ, compression, and loudness adjustments. Use it after completing Methods 1 and 2.
  1. Open the panel via Window > Essential Sound.
  2. Select your dialogue clips in the timeline. Use Ctrl or Cmd + A to select all clips, or shift-click specific tracks.
  3. Assign the clip type as Dialogue. Click the Dialogue button in the Essential Sound panel. This loads a preset group of audio controls tuned for spoken word content.
  4. Enable Loudness > Auto Match. This normalizes all selected clips to approximately -14 LUFS, the standard loudness target for Spotify and Apple Podcasts. Premiere Pro calculates each clip independently, automatically balancing inconsistent levels between host and guest tracks.
  5. Apply noise reduction. Under the Repair section, use the Reduce Noise slider (start at 40 to 50%) and enable Reduce Rumble to remove low-frequency handling noise and air conditioning hum.
  6. Set up music ducking. If your sequence includes a background music track, select it, assign it as Music in the Essential Sound panel, and enable Ducking. Premiere Pro will automatically lower the music volume when dialogue is detected and restore it during natural pauses.
This method handles audio quality automation and works best as a finishing layer after content and pacing have been shaped by Methods 1 and 2.
Pro Tips to Get the Best Results from Premiere Pro’s Auto-Edit Tools
These practices improve reliability across all three methods:
  • Record each speaker on a separate track. Separate tracks allow silence detection and loudness matching to work on individual signals rather than a blended mix, producing more accurate results.
  • Use consistent mic placement throughout the session. Waveform levels need to stay relatively stable for silence detection thresholds to work as expected. Moving the mic mid-recording shifts the baseline and causes false positives or missed cuts.
  • Run Speech to Text before making any manual timeline cuts. If you manually cut first, the transcript panel may generate incomplete or misaligned text. Always transcribe source material before editing the timeline.
  • Add markers to sections you want to protect. Before running Delete Silence, use the M key to place timeline markers on segments you want to keep intact, then review flagged cuts against your markers before applying.
  • Export a rough cut before manual refinement. Apply all three auto-edit methods and export an intermediate sequence first. This creates a clean checkpoint and makes it easier to identify exactly where the tools made errors.
Does Premiere Pro have a one-click auto-edit button for podcasts?
No single button fully automates podcast editing in Premiere Pro. However, combining the Speech to Text transcript editor with the Delete Silence tool handles the bulk of repetitive cuts. Used together in sequence, these two native features can substantially reduce editing time without requiring any third-party tools or leaving the Adobe environment.
Is Premiere Pro Speech to Text free?
Yes. Speech to Text is included in all Premiere Pro subscriptions under Adobe Creative Cloud at no additional cost. There are no per-minute transcription fees. The feature has been available since Premiere Pro version 22.0 (released in 2022) and receives ongoing accuracy improvements with each software update.
What is the best plugin for auto-editing podcasts in Premiere Pro?
Recut is the most widely used third-party silence removal tool that integrates directly with Premiere Pro’s timeline. It is faster than the native Delete Silence tool for high-volume production and offers a visual review of proposed cuts before they are applied to the sequence, giving editors more control at scale.
Can Premiere Pro automatically remove filler words like “um” and “uh”?
Not with a fully automated single pass. However, once a transcript is generated through Speech to Text, you can use the panel’s search function to find every instance of a specific word across the entire episode and delete them in bulk. Premiere Pro removes the corresponding audio and video segments from the timeline with each deletion.
Will auto-editing work on video podcasts too?
Yes. All three methods apply equally to sequences that include video tracks. After making content cuts, use Premiere Pro’s Auto Reframe effect to automatically adjust the crop and framing of any video clips that were repositioned or visually affected by the editing process.
Start With Method 1 on Your Next Episode
The most practical sequence is to run Speech to Text first for content-level cuts, follow with Delete Silence for pacing cleanup, and finish with the Essential Sound panel for audio polish. These three methods work as a layered workflow rather than competing alternatives. On your next episode, try Method 1 alone and time how long the transcript editing takes compared to your usual manual process. The difference is usually significant enough to make the workflow permanent.
