How to Add Audio to CapCut: Music, Voiceover, Sound Effects, and More
Many people struggle to find CapCut's audio options during their first edit. The app keeps music, voiceovers, and sound effects in separate sections. You can still add any audio once you know where to look. This guide explains every option with clear, easy-to-follow steps. By the end, you will know how to add the right sound.
What “Adding Audio” Means in CapCut
CapCut supports four main types of audio, and each one serves a different purpose. Before diving into steps, find the method that matches what you need:
  • Library music: Tracks from CapCut’s built-in catalog, licensed for in-app use. Jump to Method 1.
  • Local audio files: MP3s, WAVs, or other saved files imported from your device. Jump to Method 2.
  • Sound effects: Short audio clips organized by category (transitions, comedy, environment, etc.). Jump to Method 3.
  • Voiceover: Audio recorded directly inside the app using your device microphone. Jump to Method 4.
  • Extracted audio: Audio pulled from an existing video clip. Jump to Method 5.
Method 1: How to Add Music from CapCut’s Built-In Library
CapCut’s music library is the fastest way to add background audio. All tracks are CapCut-licensed, which means they are safe to use for content published through the CapCut platform. For publishing to YouTube, Instagram, or TikTok, always verify the track’s licensing status on that platform separately.
  1. Open your existing project in CapCut or tap the New video tile and select the video to add it to the timeline.
  1. Tap Audio in the bottom toolbar.
  1. Tap Sounds from the audio panel that appears.
  1. Browse by category (Recommended, Hits, or genre/mood tabs) or use the search bar to find a specific track.
  1. Tap any track to preview it.
  1. Tap the + icon next to the track to add it to your timeline.
  1. To trim the music, tap the audio clip on the timeline, then drag the left or right edge to shorten it to match your video’s length.
Note: You can also tap the Split icon on the audio clip to split it at a specific point, which is useful for dropping music in mid-clip rather than at the very start.
Method 2: How to Import Your Own Audio File into CapCut
If you have a recording, a royalty-free track downloaded to your phone, or any other audio file saved locally, you can bring it directly into CapCut. You can also follow these steps to import audio recorded outside CapCut. This includes voice memos and podcast clips saved from other apps.
  1. In your project, tap Audio in the bottom toolbar.
  2. Tap Sounds and tap the Folder icon.
  1. Tap the “Device” tile (on mobile). On CapCut desktop, click My Device in the left audio panel.
  1. Your locally saved audio files will appear. Tap or click the file you want.
  2. Tap the + icon to add it to the timeline.
  1. Drag the clip edges to trim if needed, just as you would with library music.
Supported File Formats: CapCut accepts MP3, WAV, M4A, and AAC files. If your file does not appear or fails to import, convert it to MP3 or M4A using a free converter tool before trying again.
Desktop note: On CapCut for PC or Mac, you can also drag audio files directly from a folder into the media panel, then add them to the timeline from there.
Method 3: How to Add Sound Effects in CapCut
Sound effects follow nearly the same path as music but land on a separate, independent track. This means you can reposition and adjust them without affecting your background music.
  2. Tap Sound FX to add sound effects.
  1. Browse by category (Trending, Funny, Swooshes, Gaming, and more) or use the search bar.
  1. Tap an effect to preview it.
  1. Tap + to add it to the timeline.
  1. Press and hold the sound effect clip on the timeline to drag it to the exact moment where it should play.
  2. Adjust its volume independently by tapping the clip and using the volume slider.
Because sound effects are on their own track, you can stack multiple effects alongside voiceover and background music without any of them overwriting each other.
Method 4: How to Record a Voiceover Directly in CapCut
Recording a voiceover inside CapCut lets you narrate or comment over footage without leaving the app. The playhead determines where your recording begins, so position it carefully before you start.
  2. Tap Record (microphone icon).
  1. Drag the playhead to the exact point in the timeline where you want your voiceover to begin.
  2. Tap or press and hold the Record button to start recording. After the 3-second countdown, speak clearly and at a consistent distance from your microphone.
  1. Release the button to stop. CapCut will immediately place the recorded clip on the audio track.
  2. Play back the clip to review it. If you are not satisfied, tap the clip and delete it, then re-record.
  1. Tap the checkmark to confirm and return to the main editing view.
Pro Tip: Record in a quiet room and, if possible, move away from fans, air conditioning units, or open windows. Built-in phone and laptop microphones pick up ambient noise easily, which becomes noticeable in the final export. For creators who record voiceover or commentary regularly for TikTok or YouTube Shorts, a compact wireless microphone like the Hollyland LARK M2 (weighing just 9g with a 40-hour battery life) delivers noticeably cleaner audio before you even open CapCut, with no complex setup required.
Method 5: How to Extract Audio from a Video Clip in CapCut
Audio extraction is useful when you have a video file with a soundtrack or dialogue you want to isolate and reuse.
  1. Add the video clip that contains the audio you want to your CapCut timeline.
Tap the video clip to select it.
  1. Scroll through the bottom toolbar and tap Extract Audio.
  1. CapCut will separate the audio onto its own dedicated track.
  2. You can now edit, trim, or reposition the extracted audio just like any other audio clip.
Choose this option when you want audio from another video. It also lets you reuse a recorded clip from an earlier project.
How to Adjust and Edit Audio After Adding It in CapCut?
These three adjustments handle the most common issues creators run into after an audio clip is on the timeline.
Adjusting Volume
Tap the audio clip on the timeline to select it. Tap Volume in the toolbar below. Use the slider to increase or decrease the level. For projects with both music and a voiceover, lower the music volume so the voiceover stays audible and clear.
Adding Fade In and Fade Out
Tap the audio clip and select Fade from the toolbar. Set a fade-in duration to ease the audio in at the start of the clip, and a fade-out duration to taper it off at the end. A one-to-two second fade prevents abrupt cuts that feel jarring to viewers.
Syncing Audio to Video on the Timeline
If your audio starts too early or too late relative to the video action, press and hold the audio clip and drag it left or right on the timeline. Zoom into the timeline by pinching outward with two fingers for more precise placement. This is particularly useful when syncing a sound effect to a specific moment, such as a beat drop or a visual transition.
Q: Can I add my own music to CapCut without copyright issues?
Yes. Importing music from your device adds it to your CapCut project without issue. But copyright enforcement happens on the publishing platform, not inside CapCut. If you upload to YouTube, Instagram, or TikTok, those platforms scan for rights-managed music independently. Use royalty-free or properly licensed tracks for any monetized or public content.
Q: How do I add audio to CapCut on PC or desktop?
Open your project and select the Media tab at the top left. Click Import to add an audio file from your computer. You can also open the Audio tab above. Then pick music or sound effects from CapCut's library. To record your voice, click the Voiceover option (microphone icon) above the timeline. Drag the audio onto the timeline after adding it. The desktop layout looks different from the mobile app. Even so, both versions offer the same editing options, including volume, fade, and audio placement.
Q: Why can’t I hear the audio I added in CapCut?
First, tap the audio clip and confirm the volume slider is not set to zero. Next, check that the clip is positioned within the video’s duration on the timeline and not placed past the end of the project. On desktop, verify that the correct audio output device is selected in your system settings. On mobile, check that your device is not in silent mode.
Q: What audio file formats does CapCut support?
CapCut supports MP3, WAV, M4A, and AAC. These cover the vast majority of common audio files. If your file type is not recognized, convert it to MP3 or M4A using a free online converter before importing. Lossless formats like FLAC may not be supported depending on your app version.
Q: Can I add multiple audio tracks in CapCut?
Yes. CapCut lets you run background music, a voiceover, and sound effects simultaneously on separate tracks. Each track is independently controllable for volume, fade, and timeline position. There is no hard limit on the number of audio layers, though very complex projects may affect performance on older devices.
CapCut lets you add audio in five different ways for different needs. You can pick music and import audio files. You can also add sound effects and record a voiceover. Or you can use the extract audio tool to pull audio from a video. After adding your audio, adjust the volume, apply fade effects, and line everything up with your video for a cleaner final edit.
