How to Speed Up Audio in Adobe Audition (3 Methods That Actually Work)
Speeding up audio in Adobe Audition is straightforward once you know which tool to reach for. Whether you need to shorten a podcast recording to fit a time slot or tighten a voiceover against a video edit, Audition gives you precise control — without the chipmunk effect. This guide covers three working methods, the right algorithm settings for clean results, and how to avoid the most common quality mistakes.
Two Ways Audition Lets You Speed Up Audio
Before diving into steps, it helps to know which workspace you’re in. Audition handles time-stretching differently depending on whether you’re editing a standalone file or working on a timeline.
Context
Best Method
Pitch Control
Waveform Editor (single file)
Stretch and Pitch effect
Full — adjust independently
Multitrack View (timeline clip)
Clip Speed / Duration dialog or drag handle
Good — “Maintain Pitch” option available
If you’re editing a single audio file and need maximum control, start with Method 1. If your audio is already placed on a Multitrack timeline, skip to Method 2.
Method 1 — Stretch and Pitch Effect (Waveform Editor)
This is the most capable approach for speeding up audio in Audition. It gives you independent control over speed and pitch, lets you choose the processing algorithm, and allows you to preview results before committing.
Navigate to the Stretch and Pitch Effect
  1. Open your audio file in the Waveform Editor (double-click the file in the Files panel if it opens in Multitrack).
  2. Press Ctrl+A (Windows) or Cmd+A (Mac) to select the entire clip, or click and drag to highlight a specific range.
  3. Go to Effects → Time and Pitch → Stretch and Pitch.
  4. The Stretch and Pitch dialog will open with all adjustment controls visible.
Note: If you skip the selection step, the effect won’t apply. Always confirm your selection range is highlighted before opening the dialog.
Set Your Speed Using Duration or Percentage
The dialog offers two ways to define how much faster the audio should play:
  • Target Duration: Enter the exact length you want the output to be (for example, reducing a 5-minute clip to 4 minutes). Audition calculates the stretch ratio automatically.
  • Stretch Ratio (percentage): Enter a percentage value directly. This is where many users get tripped up — a value below 100% speeds up the audio, not above it. Setting 80% compresses the duration to 80% of the original, making it play roughly 25% faster. A value of 125% would make it longer.
Use the percentage method when you know the relative change you want; use the duration method when you need to hit a specific runtime.
Lock Pitch to Avoid the Chipmunk Effect
By default, Audition may link pitch to stretch — meaning speeding up the audio also raises the pitch. To prevent this:
  1. Uncheck the “Lock Stretch and Pitch” checkbox (or decouple the link icon between the two controls, depending on your Audition version).
  2. Set the Pitch Shift value to 0 semitones.
  3. Under Algorithm, select iZotope Radius XT for voice, speech, or podcast content. This is the highest-quality option and handles vocal frequencies best.
  4. Click Preview to audition the result before applying.
  5. Click Apply (or OK) to render the change.
Pro Tip: Always work on a duplicate of your original file when using the Waveform Editor method. The processed file replaces your source audio, and while Ctrl+Z will undo it in-session, you won’t have a backup once the project is closed.
Method 2 — Clip Speed in Multitrack View
If your audio is already placed on a Multitrack timeline, there’s no need to leave that workspace. Audition offers two approaches here: a dialog for precise values and a drag handle for quick visual adjustments.
Using the Clip Properties / Speed Dialog
  1. In the Multitrack Editor, locate the clip you want to speed up on the timeline.
  2. Right-click the clip and navigate to Clip → Clip Properties (some versions show this as Speed/Duration or directly in the right-click context menu).
  3. In the dialog, find the Speed field and enter a percentage above 100% — for example, 125% plays the clip 25% faster.
  4. Check the Maintain Pitch option to prevent pitch distortion.
  5. Click OK. The clip will visually shorten on the timeline to reflect the new duration.
Note: This method is non-destructive — the original source file on disk is never touched. You can return the clip to its original speed at any time.
Using the Time-Stretch Handle (Visual Drag Method)
  1. Hover your cursor over the right edge of the clip on the timeline until the cursor changes to a stretch icon (two arrows).
  2. Hold Ctrl (Windows) or Cmd (Mac) while the stretch icon is visible.
  3. Drag left to compress the clip duration (which speeds it up) or right to extend it.
  4. Release when the clip reaches your target length.
This method is best for quick, approximate adjustments — for instance, snapping a clip to match a video cut point. For professional deliverables where exact timing matters, use the Speed dialog instead.
How to Choose the Right Algorithm for Best Audio Quality
Algorithm selection is the most overlooked factor when speeding up audio. The wrong choice leads to muffled, robotic, or watery artifacts regardless of how carefully you set the speed values.
Algorithm
Best For
Trade-off
iZotope Radius XT
Voice, speech, podcast
Slower processing time
iZotope Radius
General audio, music
Good balance of speed and quality
Audition Default
Quick edits, non-critical audio
Fastest, lowest quality output
Practical rule: For any speed change above 20%, always select iZotope Radius XT for voice content. The processing takes a few extra seconds but the difference in output quality is significant — especially on sustained vowel sounds and sibilants where artifacts appear first.
Quick Tips to Maintain Audio Quality After Speeding Up
  • Stay within a 15–25% speed increase for results that sound natural to most listeners; beyond 30%, artifacts become noticeable even with Radius XT.
  • Always work on a copy of the original file when using the Waveform Editor — the processed audio overwrites your source in that session.
  • Use the Preview button in the Stretch and Pitch dialog before applying; what sounds fine on a short loop can become fatiguing across a full recording.
  • Export at the same sample rate (44.1 kHz or 48 kHz) as your source to avoid compounded quality degradation at the output stage.
  • In Multitrack, run a mixdown before final delivery (File → Export → Multitrack Mixdown) to render all clip speed changes properly into the output file.
Does speeding up audio in Audition change the pitch?
Only if pitch and stretch are linked in your settings. In the Stretch and Pitch dialog, decouple them by unchecking the link between the two controls and setting the pitch value to 0 semitones. In Multitrack, enabling the “Maintain Pitch” option during a speed change achieves the same result — your audio plays faster without rising in pitch.
What’s the difference between Stretch and Pitch and changing clip speed in Multitrack?
Stretch and Pitch processes and renders the audio waveform directly in the Waveform Editor — it modifies what’s stored in your session file (though still undoable). Multitrack clip speed is fully non-destructive: the source file on disk is never changed. The speed adjustment lives only on the timeline and can be removed or revised at any point.
How much can I speed up audio before it sounds unnatural?
Up to 20–25% faster is generally transparent with the right algorithm and good source material. Once you exceed 30%, most listeners will detect artifacts — smearing on consonants, a hollow quality on sustained notes — even when using iZotope Radius XT. For aggressive speed changes, consider cutting silence or breath gaps out manually first to reduce the stretch amount needed.
Can I speed up only part of an audio clip in Audition?
Yes, on both tracks. In the Waveform Editor, click and drag to highlight only the section you want to affect before opening the Stretch and Pitch dialog — the effect applies only to the selected range. In Multitrack, split the clip first using Ctrl+K (Windows) or Cmd+K (Mac), then apply speed changes to the individual segment you need to shorten.
For maximum control over a single audio file, the Stretch and Pitch effect in the Waveform Editor is your best option — especially when algorithm selection and precise pitch handling matter. For timeline-based edits, the Clip Speed dialog in Multitrack is faster and keeps your source files untouched. If your Audition version shows different menu labels than those described here, Adobe’s official Audition documentation covers version-specific UI changes.
