How to Set Up TikTok Live Studio with PS5 (Step-by-Step Guide)
TikTok Live Studio cannot be installed on a PS5 because it only works on Windows. This often confuses people who are streaming for the first time.. To broadcast PS5 gameplay on TikTok with full production controls, you need a PC, a capture card in between, and the right configuration on both ends. This guide walks through every step in sequence so your stream is live and working the first time.
Gather everything below before touching any settings. Missing one component means the setup won’t work, and diagnosing it mid-session wastes time.
  • PS5 — the console you’re streaming from
  • Windows PCTikTok Live Studio is Windows-only (no Mac, no console-native install); minimum specs are Windows 10 64-bit, Intel i5/AMD Ryzen 5 or better, 8GB RAM, and a dedicated GPU recommended
  • HDMI capture card with passthrough — required to route PS5 video into your PC while still outputting to your TV; popular options include the Elgato HD60 X and AVerMedia Live Gamer Portable 2 Plus (both support 1080p60)
  • Two HDMI cables — one from PS5 to the capture card IN port, one from the capture card passthrough OUT to your TV or monitor
  • USB cable — connects the capture card to your PC; a USB 3.0 port is required for 1080p60 capture cards to function at full bandwidth
  • TikTok account with LIVE access — TikTok currently requires a minimum of 1,000 followers and an account holder aged 18+ to unlock the LIVE feature; verify eligibility in your account settings before building the setup
  • Capture card drivers installed on PC — download from the manufacturer’s site before connecting hardware
Audio note: If you plan to add voice commentary, a compact wireless mic like the Hollyland LARK M2 (9g, up to 40-hour battery) connects cleanly to your PC audio input without cable clutter at your desk — a practical upgrade over a wired mic snaking across the setup.
Step 1 — Disable HDCP on Your PS5
⚠️ This is the most common reason setups fail silently. HDCP (High-bandwidth Digital Content Protection) encrypts the PS5’s HDMI output to prevent unauthorized recording. Every capture card is blocked by it — your PC will receive no signal and show a black preview until HDCP is off.
  1. On your PS5, go to Settings (gear icon on the home screen)
  2. Select System
  1. Select HDMI
  1. Toggle Enable HDCP to Off
That’s it. The change takes effect immediately — no restart required. Note that some game content (licensed video, certain cutscenes) may still restrict capture even with HDCP off, but gameplay itself will capture correctly.
Step 2 — Connect Your PS5 to the Capture Card
The physical connection routes PS5 video through the capture card to both your PC and your display simultaneously. Follow this chain exactly:
  1. PS5 HDMI OUT → Capture Card HDMI IN — plug the first HDMI cable into the back of the PS5 and into the port labeled “IN” on your capture card
  2. Capture Card HDMI OUT (passthrough) → TV or monitor — plug the second HDMI cable from the port labeled “OUT” or “Passthrough” into your display; this signal is unprocessed and lag-free for gameplay
  3. Capture Card USB → PC USB 3.0 port — connect the USB cable from the capture card to a USB 3.0 port (usually marked with a blue tab) on your PC; avoid USB hubs, which can cause bandwidth issues
Connection flow (text diagram):
PS5 → [HDMI] → Capture Card IN
                Capture Card OUT → [HDMI] → TV/Monitor
                Capture Card USB → [USB 3.0] → PC
Power on your PS5 and confirm that gameplay appears on your TV via passthrough before proceeding to software setup.
Step 3 — Install and Open TikTok Live Studio on PC
  1. On your PC, go to the official TikTok Live Studio download page (search “TikTok Live Studio download” and use the official tiktok.com source)
  2. Download and run the installer; follow the standard installation prompts
  1. Open TikTok Live Studio and log in with your TikTok account credentials
  1. Complete any first-time account verification TikTok prompts
Once inside, take a moment to orient yourself — the layout is different from OBS but follows the same logic. The Scenes panel (left side) holds your different stream layouts. The Sources panel sits within each scene and is where you add your PS5 feed. The Audio Mixer at the bottom controls game audio and microphone levels independently. You’ll work across all three in the next steps.
Step 4 — Add Your PS5 as a Video Source
  1. In the Scenes panel, confirm you’re working in your default scene (or create a new one named “PS5 Stream”)
  2. In the Sources panel, click the + (Add Source) button
  1. Select Video Capture Device from the source type list
  2. Name the source (e.g., “PS5 Gameplay”) and click Add
  1. In the device dropdown, select your capture card by name (e.g., “Elgato HD60 X” or “AVerMedia Live Gamer”)
  1. Set Resolution to 1080p (or 720p60 if your card or internet connection requires it) and Frame Rate to 60fps
  1. Click Add source — the preview window should now show your PS5 gameplay in real time
If the preview is black or blank, check these in order: - HDCP is still enabled on PS5 — go back to Step 1 - Capture card is plugged into a USB 2.0 port — move it to USB 3.0 - Capture card drivers aren’t installed — download from the manufacturer’s site and restart - Wrong device selected in the dropdown — verify the capture card name in Windows Device Manager
Step 5 — Configure Audio Settings
Getting audio balanced correctly is what separates a watchable stream from one that drives viewers away in the first minute.
  1. Open the Audio Mixer panel at the bottom of TikTok Live Studio
  2. Locate the Video Capture Device channel — this carries your PS5 game audio through the capture card; confirm it’s active and not muted
  3. Click + to add a new audio source and select your Microphone (USB mic, headset mic, or audio interface output)
  1. Set levels: bring game audio to approximately -20dB and your mic to approximately -12dB — this keeps dialogue audible over gameplay without either source overwhelming the other
  2. Enable Noise Gate if the option is available, to cut background noise during quiet moments
  3. Do a short test recording and play it back before going live to confirm both sources are audible and balanced
Audio level targets at a glance: - 🎮 Game audio: ~-20dB - 🎙️ Microphone: ~-12dB - 🔇 Noise gate: enabled if available
Note: The PS5 DualSense controller’s built-in microphone is not suitable for streaming — it picks up button noise and lacks the clarity your audience expects. An external USB mic or wireless mic is worth the upgrade.
Step 6 — Set Up Your Stream and Go Live
  1. Click the Stream Info or Go Live section in TikTok Live Studio
  2. Enter your stream title — keep it descriptive and relevant to the game you’re playing
  3. Set the category to Gaming and select your specific game title from the list
  4. Review your scene in the preview window — confirm the PS5 gameplay is visible and audio meters are moving
  5. Check your recommended stream settings match the table below, then click Go Live
  6. Once live, watch the stream health indicator — a green/stable bitrate signal means your connection is holding; if it drops to red, lower your bitrate or close background applications
  7. Open TikTok on your phone and navigate to your profile to confirm the stream is visible and playing correctly before you settle in
Recommended Stream Settings:
Setting
Recommended Value
Resolution
1080p (or 720p if unstable)
Frame Rate
60fps
Bitrate
2,500–4,500 Kbps
Encoder
Hardware (GPU) if available
Quick Troubleshooting Reference
Problem
Likely Cause
Fix
Black screen in preview
Go to PS5 Settings → System → HDMI → disable HDCP
Capture card not appearing in device list
Driver not installed or the USB port is wrong
Install manufacturer drivers; move the USB to a USB 3.0 port
Stream goes live, but no audio
Capture card not selected as audio source
In Audio Mixer, set Video Capture Device as game audio source and confirm it’s unmuted
Can I use TikTok Live Studio without a capture card on PS5?
In general, TikTok Live Studio runs on a Windows PC. And therefore, has no way to receive PS5 video without a capture card acting as the bridge. If you want to stream directly from the PS5 without a PC or capture card, you’d need to use the TikTok mobile app instead — but that path offers far fewer production controls and a different setup process entirely. Contrarily, you can use PS Remote Play on a PC to stream to TikTok without a capture card, but it needs a strong internet connection. But most prefer using a capture card.
Which capture card works best with TikTok Live Studio and PS5?
The Elgato HD60 X and AVerMedia Live Gamer Portable 2 Plus are consistently reliable choices. Both support 1080p60 capture and HDMI passthrough — the two non-negotiable features for this setup. Avoid any capture card that lacks a dedicated passthrough port, or you’ll have to choose between capturing footage and playing on your TV.
Do I need 1,000 followers to go live on TikTok?
Yes. TikTok currently requires at least 1,000 followers and an account holder who is 18 or older to access the LIVE feature. You can check your eligibility directly in your TikTok app under Profile → Creator Tools. Build the full hardware and software setup first, but verify LIVE access before your first scheduled stream.
Once everything is ready, the setup is simple. Turn off HDCP on your PS5 and connect it to your PC using a capture card. Open TikTok Live Studio and add a Video Capture Device. Adjust the audio levels and stream settings. When all of this is done, you can go live.
We also suggest that you run a 5-minute private test stream to verify stability before your first public broadcast - Add overlays, alerts, or a facecam source in TikTok Live Studio’s Scenes panel to improve production value
