How to Add OBS Virtual Camera to TikTok Live Studio (Step-by-Step)
OBS Studio gives you powerful scene control—custom overlays, multiple sources, color correction—but TikTok Live Studio has its own ecosystem that creators increasingly want to use. OBS Virtual Camera connects the two. Once it’s running, TikTok Live Studio sees your entire OBS canvas as a standard webcam. Here’s how to set it up, plus fixes for the most common issues.
Confirm these requirements before diving into the steps. Missing any one of them is the most common reason the workflow fails.
  • OBS Studio v26 or later — Virtual Camera is built in from v26 onward. No plugin required.
  • TikTok Live Studio desktop app — Download the latest version from TikTok’s official site. This workflow applies to the Windows desktop app.
  • Windows 10 or laterTikTok Live Studio is a Windows-native application. The steps in this guide are Windows-based.
  • macOS users — OBS Virtual Camera works on macOS, but you must grant OBS camera and screen recording permissions in System Settings → Privacy & Security before any app can detect the virtual device.
  • Active OBS scene — Your OBS scene needs at least one active source. A blank scene will produce a black screen in TikTok Live Studio.
What Is OBS Virtual Camera and Why TikTok Live Studio Needs It?
OBS Virtual Camera turns your whole OBS screen into a camera that your computer recognizes. TikTok Live Studio can then use it like a normal webcam. This lets the app show your complete OBS setup, including overlays, multiple sources, and filters, without needing any direct connection between the two apps.
Step 1 — Enable the Virtual Camera in OBS Studio
Finish these steps in OBS first. TikTok Live Studio can only see the virtual camera after it is turned on.
  1. Open OBS Studio and make sure your scene is fully built — sources added, layout arranged, any filters applied.
  2. Locate the Controls dock in the bottom-right corner of the OBS interface. You’ll see buttons for Start Streaming, Start Recording, and Start Virtual Camera.
  3. Click Start Virtual Camera. The button label will switch to Stop Virtual Camera, confirming the device is now broadcasting.
  1. Leave OBS running and Virtual Camera active for the entire session. Stopping the Virtual Camera while TikTok Live Studio is open will cut the feed.
  2. Using OBS below v26? Install the OBS-VirtualCam plugin from the OBS Project forums. It adds the same Start Virtual Camera button and behaves identically. That said, updating OBS is the faster fix.
Step 2 — Add OBS Virtual Camera as a Source in TikTok Live Studio
With OBS Virtual Camera running, switch to TikTok Live Studio and follow these steps.
  1. Open TikTok Live Studio and log in to your account if prompted.
  2. Navigate to your scene editor. This is the main canvas area where you arrange your live layout.
  3. Click Add Source (usually a + icon in the source panel) and select Camera or Video Capture Device from the source type list.
  1. Open the device dropdown inside the source settings. Look for OBS Virtual Camera in the list of available camera devices.
  2. Select OBS Virtual Camera. The preview window should immediately display your OBS canvas output — overlays, sources, and all.
  1. Resize or reposition the layer within the TikTok Live Studio scene editor to fit your layout. Drag the corners to scale, or use the position fields if you need precise placement.
Troubleshooting — OBS Virtual Camera Not Showing Up or Black Screen
Problem
Likely Cause
Fix
OBS Virtual Camera is not listed in TikTok Live Studio
Virtual Camera was not started before opening the source selector
Click Start Virtual Camera in OBS first, then reopen the Add Source menu in TikTok Live Studio
Virtual Camera is listed, but shows a black screen
OBS scene is empty, or a capture card / NDI conflict is present
Add at least one active source to your OBS scene; disable NDI output if enabled
Camera appears, but the feed is laggy
Resolution or FPS mismatch between OBS canvas and TikTok Live Studio
Match your OBS canvas resolution and FPS to TikTok Live Studio’s scene settings (typically 1080p / 30fps)
Not detected on macOS
macOS blocks virtual camera access without explicit permission
Go to System Settings → Privacy & Security → Camera and enable access for OBS
Tips to Get the Best Output from OBS Virtual Camera in TikTok Live
A working connection is the baseline—these adjustments push the output quality higher.
  • Set OBS canvas to 1080p and match TikTok Live Studio’s scene dimensions. Mismatched resolutions are the leading cause of blurry or letterboxed output on the TikTok end.
  • Apply OBS scene filters before the virtual camera output leaves OBS. LUTs, sharpening, and color correction applied at the OBS scene level carry through the virtual camera feed, so you’re not relying on TikTok Live Studio for image quality.
  • Close background applications to reduce encoder load. Running OBS and TikTok Live Studio simultaneously is CPU-intensive. Close unused browser tabs, video players, and any other capture software before going live.
  • Audio travels separately. OBS Virtual Camera carries video only. Set up your microphone or audio interface directly inside TikTok Live Studio’s audio settings. If cable-free audio is a priority, a compact wireless mic like the Hollyland LARK M2—9g, up to 40-hour battery life—integrates cleanly into this kind of dual-app setup, keeping your audio chain simple while OBS manages the video layer.
Q: Do I need a third-party plugin to use OBS Virtual Camera with TikTok Live Studio?
No. OBS Studio v26 and later include Virtual Camera natively. If you’re on an older version, the OBS-VirtualCam plugin adds the same functionality. Most users should update OBS to avoid the plugin step entirely—it’s the simpler path and keeps everything in one place.
Q: Can I use OBS Virtual Camera for TikTok Live Studio on Mac?
Yes, but macOS requires you to grant OBS camera and screen recording permissions in System Settings → Privacy & Security before TikTok Live Studio can detect the virtual camera device. Once permissions are granted, the workflow is the same as on Windows.
Q: Will OBS audio also come through TikTok Live Studio via Virtual Camera?
No. OBS Virtual Camera routes the video canvas only—audio is not included. You’ll need to configure your microphone or audio interface as a separate input inside TikTok Live Studio’s audio settings for your stream audio to work correctly.
Q: Does TikTok Live Studio support OBS Virtual Camera on all Windows versions?
TikTok Live Studio requires Windows 10 or later, and OBS Virtual Camera shares the same minimum requirement. As long as both applications are up to date and running on a supported Windows build, they should work together without compatibility issues. On the other hand, some users have reported that TikTok Live Studio doesn’t recognize OBS Virtual Camera and initially asks for a physical camera.
That’s the full workflow. OBS Virtual Camera is active, TikTok Live Studio is reading it as a camera source, and your scene is fully composed. Before streaming to your audience, run a quick private or unlisted test session to verify the OBS canvas appears correctly, audio levels are balanced, and there’s no unexpected lag. Once everything checks out, you’re ready to go live with the full production power of OBS behind your TikTok stream.
