Streaming to only one platform means leaving potential viewers on the other. Multistreaming — broadcasting a single live session to Twitch and TikTok simultaneously — lets you grow both audiences without running two separate setups. This guide covers three methods ranked by ease: Restream.io for beginners, the OBS multistream plugin for those who prefer full control, and Streamlabs for users already in that ecosystem.
Before changing any settings, make sure you meet the requirements for both platforms. Missing even one of these requirements is the most common reason a simulcast setup fails right before going live.
TikTok Live eligibility: - Your account must have 1,000 or more followers - You must be 18 years of age or older - Your account must be in good standing (no active violations) - You need access to TikTok LIVE Studio or the ability to retrieve an RTMP stream key from TikTok
Twitch requirements: - An active Twitch account with access to your stream key (found under Creator Dashboard → Settings → Stream) - No additional eligibility threshold for Affiliates or non-partnered streamers
Software or service: - An account with a multistreaming service (Restream or Streamlabs), or OBS Studio installed with the multi-RTMP plugin - A streaming application — OBS Studio or Streamlabs — configured and working for at least one platform already
Note for Twitch Partners: Standard Twitch Partner agreements include an exclusivity clause that restricts simultaneous streaming to competing platforms. If you hold Partner status, review your contract before proceeding. Affiliates and non-partnered streamers are generally free to simulcast without restriction.
Method 1 — Multistream via Restream.io (Easiest)
Restream works as a middle service between you and the platforms. You send one live stream to Restream’s server first. It then forwards that stream to every connected platform at the same time. You do not need to deal with multiple RTMP links or install extra plugins. Because of this, many streamers pick this option when starting out.
Free plan limitations: The free tier supports multistreaming to two channels but adds a Restream watermark to your stream and caps resolution. Paid plans (starting around $16/month) remove the watermark and unlock 1080p60 passthrough.
Connecting Your Twitch Account to Restream
Create an account at restream.io and log in to your dashboard.
Go to the “Channels” tab on the left panel and select Twitch from the available platforms.
Click Connect with Twitch — this opens an OAuth authorization window.
Log in to Twitch and click Authorize to grant Restream access.
Confirm that your Twitch channel name appears as an active destination in the Restream dashboard before moving on.
Connecting Your TikTok Account to Restream
In the Restream dashboard, click Channels again and select TikTok.
Restream will prompt you to retrieve your TikTok RTMP URL and stream key manually — TikTok does not support OAuth-based connection at this time.
Open TikTok LIVE Studio on your desktop (or the TikTok app on mobile, if your account supports key-based streaming) and locate your RTMP URL and Stream Key under the streaming settings.
Paste both values into the corresponding fields in Restream.
Save the destination. Your TikTok channel should now appear alongside Twitch in your destinations list.
Reminder: If TikTok LIVE Studio shows an error or you cannot locate a stream key, your account may not yet meet the 1,000-follower eligibility requirement.
Configuring OBS to Stream Through Restream
In Restream’s dashboard, navigate to Stream Setup and copy the provided RTMP URL and Stream Key (these are Restream’s unified ingest details, not platform-specific keys).
Open OBS Studio. Go to Settings → Stream.
Set Service to Custom.
Paste the Restream RTMP URL into the Server field and the Stream Key into the Stream Key field.
In Settings → Output, set your Video Bitrate to between 3,000 and 6,000 kbps — a value both platforms can reliably receive.
Click Apply, close Settings, and press Start Streaming. Restream will forward your broadcast to both Twitch and TikTok.
Method 2 — OBS Multistream Plugin (Free, No Third-Party Service)
If you do not want your stream to pass through a third-party service, the OBS Multi-RTMP plugin gives another option. It allows OBS to send your stream straight to several RTMP addresses at the same time. Your broadcast stays private since no relay server stays in between. The only thing it costs is the bandwidth your internet connection provides.
⚠ Callout: Encoding and uploading to two destinations simultaneously increases both CPU load and upload bandwidth consumption. Before going live, verify your upload speed can handle at least two times your target bitrate. A wired Ethernet connection is strongly recommended.
Download the obs-multi-rtmp plugin from its GitHub releases page and install it according to the platform instructions (Windows installer or macOS build available).
Restart OBS. Go to Tools → Multiple Output — this opens the multi-RTMP output panel.
Click Add Output and configure your Twitch output: name it “Twitch,” enter Twitch’s ingest server URL, and paste your Twitch stream key.
Click Add Output again for your TikTok output: enter TikTok’s RTMP ingest URL and paste your TikTok stream key (retrieved from TikTok LIVE Studio).
In each output’s encoder settings, set an appropriate bitrate. A common configuration is 4,500 kbps for Twitch and 3,000–4,500 kbps for TikTok, adjusted based on your upload capacity.
In the Multi-Output panel, click Start All to begin streaming to both destinations. Your main OBS “Start Streaming” button will still control your primary output — use the plugin panel for the secondary stream, or configure both as plugin outputs.
OBS 30+ users: Check whether your installed version includes a native multi-output option under Settings before installing the plugin — newer builds are progressively incorporating this natively.
Method 3 — Streamlabs Multistream (For Existing Streamlabs Users)
If Streamlabs is already your primary streaming application, its built-in Multistream feature avoids the need to install anything new.
Important: Streamlabs Multistream requires an active Streamlabs Ultra subscription (approximately $27/month). There is no free multistream tier in Streamlabs.
Open Streamlabs Desktop and sign in to your account.
In the left sidebar, click Multistream.
Click Add Destination and select TikTok from the platform options.
Enter your TikTok RTMP URL and Stream Key in the provided fields (retrieved from TikTok LIVE Studio).
Toggle the TikTok destination to Enabled.
Confirm your primary Twitch destination is already active, then press Go Live as normal. Streamlabs handles distribution to both platforms automatically.
Quick Comparison: Which Method Should You Use?
Method |
Cost |
Technical Skill Required |
Best For |
Restream.io |
Free (with watermark) / ~$16+/mo |
Low — browser-based setup |
Beginners, anyone wanting a fast setup with minimal configuration |
OBS Multi-RTMP Plugin |
Free |
Medium — requires plugin install and manual RTMP configuration |
Streamers who want no third-party relay and have solid upload bandwidth |
Streamlabs Multistream |
~$19/mo (Ultra required) |
Low — built into Streamlabs UI |
Existing Streamlabs users who already pay for Ultra |
Tips to Improve Your Multistream Quality
Set a consistent bitrate that both platforms can handle. A bitrate between 3,000 and 6,000 kbps works across Twitch and TikTok without triggering dropped frames. Start conservatively at 4,500 kbps and increase only after a stable test.
Use a wired Ethernet connection. Wi-Fi introduces packet loss and latency spikes that compound when streaming to two endpoints. A wired connection is the single highest-impact stability improvement you can make.
Match resolution and orientation to your content type. TikTok strongly favors 1080x1920 (9:16 vertical) for mobile viewers. If your Twitch setup is horizontal (16:9), consider using a dedicated vertical scene or a cropped camera layout specifically for the TikTok output.
Invest in clean audio. New viewers on TikTok have no connection to your stream yet, so bad audio can quickly turn them away. A small wireless mic like the Hollyland LARK M2, which weighs 9 grams, is about the size of a button, and has a 40-hour battery life, keeps your desk free of cables, and sends clear audio to both platforms at the same time.
Can Twitch Partners simulcast to TikTok?
Yes, you can stream on other platforms unless your Twitch agreement requires exclusivity. You can mention your presence elsewhere, but cannot tell viewers to leave Twitch for another stream. Links in your bio or panels are allowed, but you cannot use your banners, messages, chat, or these links to actively promote streams on other platforms. Partners who followed the rules when leaving Twitch may restore their status.
Why can’t I go live on TikTok?
The most common reasons are falling below the 1,000-follower threshold or being under 18 years old — both are hard requirements for TikTok LIVE access. Additionally, accounts with recent Community Guidelines violations may have LIVE access temporarily restricted. Check TikTok’s official LIVE eligibility page in the Help Center for current requirements.
Does streaming on TikTok and Twitch at the same time hurt stream quality?
It can, depending on your setup. The main risk factors are insufficientupload bandwidth (you’re uploading two streams instead of one) and increased CPU encoder load when using the OBS plugin method. Following the bitrate and connection tips in the section above significantly reduces quality issues. Restream and Streamlabs offload encoding distribution to their servers, which reduces local CPU impact.
Is Restream free for multistreaming to TikTok and Twitch?
Yes — Restream’s free plan supports multistreaming to two platforms including TikTok and Twitch. The free tier applies a Restream watermark overlay to your stream and limits output resolution. If watermark-free, full-resolution multistreaming is a priority, a paid plan is required.
For most streamers, Restream.io is the fastest path to going live on both platforms today. If you prefer keeping everything in-house and have the bandwidth to support it, the OBS multi-RTMP plugin gives you full control at no cost. Already on Streamlabs Ultra? Use the built-in Multistream feature and skip the extra accounts entirely.
Before broadcasting to both audiences at once, run a short private test stream — five to ten minutes — to confirm audio sync, video quality, and stream stability on both platforms. Fix issues quietly before your viewers see them.
