Showing your Black Ops 6 rank on a TikTok LIVE stream makes your content more engaging and gives viewers instant context for your gameplay. The setup involves four main steps: pulling your stats from a tracker tool, building an overlay, adding it to OBS or Streamlabs, and connecting everything to TikTok LIVE. This guide walks you through each one.
What BO6 Stats You Can Actually Show on Stream
Before you build anything, it helps to know what’s actually available. Activision doesn’t expose an official public API for BO6, so you can’t pull data directly. Third-party tracker sites fill that gap by scraping and storing match data from Activision’s own player feeds.
Through tools like CODTracker.gg (nowTracker.gg), you can display:
Skill Rating (SR) and current rank tier
K/D ratio (overall and recent matches)
Win/Loss record
Recent match history (placement, kills, score)
Top weapon and mode performance
Keep in mind that these stats reflect what Activision makes visible. Some granular data (like individual round stats) may not be accessible depending on your privacy settings.
Step 1 — Pull Your BO6 Rank Stats Using a Tracker Tool
Tracker.gg (part of the Tracker.gg network) is a reliable option for Black Ops 6 Ranked Play stats. Here’s how to get your profile set up and your stats URL ready.
Go to https://tracker.gg/call-of-duty in your browser.
Click Sign In and connect your Activision account, or simply search your in-game username using the search bar at the top.
Select your platform (Battle.net, PlayStation, or Xbox) to pull the correct profile.
Once your profile loads, navigate to the Ranked Play tab to find your SR, rank tier, and match history.
Copy the full URL from your browser’s address bar — you’ll use this in Step 2.
Note: If your stats aren’t showing up, your in-game privacy settings are almost certainly the cause. Fix this before moving on.
Fix: Stats Not Showing on the Tracker
In Black Ops 6, open Settings → Account & Network and set your data sharing or profile visibility to Public. Also, confirm that the platform account you’re playing on (PSN, Xbox, Battle.net) is correctly linked to your Activision account at https://profile.activision.com/login. Once updated, wait a match or two for the tracker to sync.
Step 2 — Create a Rank Stats Overlay for Your Stream
Choose the one that matches how clean and professional you want your stream to look.
Browser Source Method (Recommended for Beginners)
This is the fastest way to get stats on screen. You’ll use your Tracker profile URL directly as a live web page inside OBS.
Copy your Tracker.gg profile URL from Step 1.
In OBS, add a Browser Source (covered in Step 3).
Paste the URL into the browser source settings.
Crop and resize the source so only your stats widget area is visible — not the full webpage.
The downside: the page includes branding, menus, and other elements you’ll need to crop around. It works, but it looks rough without some adjustment.
Step 3 — Add the Stats Overlay in OBS or Streamlabs
With your overlay URL ready, it’s time to add it to your streaming software.
In OBS Studio:
Open OBS and select the Scene you use for gameplay.
In the Sources panel at the bottom, click the + button.
Select Browser from the source type list.
Name the source (e.g., “BO6 Rank Stats”) and click OK.
Paste your overlay URL (from Step 2) into the URL field.
Set the Width and Height to match your overlay dimensions — 300×200 is a reasonable starting point for a stat card.
Click OK, then click and drag the source to position it on your canvas.
Right-click the source and use Transform → Edit Transform for precise placement.
Streamlabs users: The process is identical — go to Sources → + → Browser Source, paste your URL, and set dimensions. Everything else works the same way.
Pro Tip: TikTok LIVE uses a 9:16 vertical format, so set your OBS canvas to 1080×1920 under Settings → Video. Place your rank stats overlay in the upper-right or lower-left corner where it won’t cover your gameplay or face cam. A stat card tucked into a corner reads cleanly on mobile screens.
Step 4 — Connect OBS to TikTok LIVE and Go Live
There are two paths for going live on TikTok from OBS. TikTok LIVE Studio is the simpler native option; OBS with a stream key gives you more control.
Important: TikTok requires a minimum of 1,000 followers to access the TikTok LIVE feature. If you haven’t reached that threshold yet, focus on building short-form clip content first.
Option A: TikTok LIVE Studio (Easiest)
Download TikTok LIVE Studio from https://www.tiktok.com/studio/download.
Log in with your TikTok account.
Import your OBS scene or set up your layout within LIVE Studio.
To import a scene in OBS, click the “Scene Collection” tab at the top.
Click “Import” from the dropdown menu.
On TikTok, simply click Go LIVE when ready.
This is the most beginner-friendly path, but it offers less flexibility than OBS for overlay management.
Option B: OBS with TikTok Stream Key (Recommended)
Log in to TikTok and go to Creator Center → LIVE → Go LIVE via streaming software.
Copy your Server URL (RTMP) and Stream Key.
Open OBS and go to Settings → Stream.
Set Service to Custom.
Paste the RTMP URL into the Server field and the Stream Key into the Stream Key field.
Click OK, then click Start Streaming in OBS.
Confirm the stream is active in your TikTok app or Creator Center dashboard.
Your overlay, gameplay capture, and audio will all go through OBS before hitting TikTok — giving you full control over how everything looks.
Quick Tips to Make Your BO6 TikTok Stream Look and Sound Better
The technical setup gets you live. These adjustments make you look like you know what you’re doing.
Use a 9:16 vertical scene layout in OBS. TikTok viewers are on mobile. A landscape stream letterboxed into a vertical frame wastes real estate and looks amateurish. Build your scene natively at 1080×1920 from the start.
Pin your rank stats overlay in a corner — not the center. Upper-right or lower-left works best. It stays visible without covering your gameplay or facecam. Consider a semi-transparent background on the widget so it doesn’t feel intrusive.
Set your bitrate between 4,000 and 6,000 Kbps. TikTok LIVE handles this range well without dropping frames. Going higher than 6,000 Kbps can cause buffering issues depending on your upload speed and TikTok’s ingest server.
Use a dedicated wireless mic for commentary. Laptop mics and webcam audio sound flat on TikTok LIVE and will hurt viewer retention. The Hollyland LARK M2 is a practical choice here — it weighs just 9g, runs for up to 40 hours on a charge, and plugs cleanly into a PC or phone interface. For a gaming streamer who might shift positions or move around, the compact wireless design keeps your desk clean and your audio consistent without a bulky desk mic setup.
Q: Why are my BO6 stats private or not loading on Tracker.gg?
Your in-game privacy setting is most likely the cause. Open Black Ops 6, go to Settings → Account & Network, and set your data visibility to Public. After your next match, re-check Tracker.gg. Also, confirm your gaming platform account is correctly linked to your Activision account at https://profile.activision.com/login — a broken link is the second most common reason stats don’t appear.
Q: Do BO6 rank stats update live during a match?
No. Third-party trackers like Tracker.gg update post-match, not in real time during gameplay. Your overlay will refresh after each session ends and the match data is processed. To keep it current between games, manually refresh the browser source in OBS by right-clicking the source and selecting Refresh Cache of Current Page.
Q: Can I show BO6 stats on TikTok without OBS?
TikTok LIVE Studio has basic overlay functionality built in, but it doesn’t natively support browser sources the way OBS does. You can display static image overlays, but not a live-updating stat widget. OBS gives you full overlay control, handles browser sources natively, and is completely free — making it the better option for this setup.
Q: Do I need 1,000 followers to stream BO6 on TikTok?
Yes. TikTok currently requires a minimum of 1,000 followers before your account can access TikTok LIVE. If you’re not there yet, focus on posting BO6 highlight clips and short-form content to build your audience first. Once you hit the threshold, LIVE access is typically enabled within 24–48 hours.
You’re Ready to Go Live
The full path is straightforward: grab your stats URL from Tracker.gg, build a browser source overlay using the tracker link or a tool like StreamElements, add it to your OBS scene, and connect OBS to TikTok LIVE using your stream key from Creator Center.
Before you go live, run a private test first. Start a stream while a friend or your second account watches. Check that the stat overlay sits in the right spot, updates after matches, and stays visible on a phone screen. This quick test helps you avoid problems during the live stream.
