Bad audio can ruin an otherwise perfect video. Whether it’s wind noise drowning out your voice, background music you no longer have rights to use, or a voiceover that simply didn’t land, replacing the audio track is the fastest fix available. You don’t need to re-shoot anything. This guide shows how to replace video and audio on PC, Mac, and mobile. It includes both free and paid tools, so you can finish your project and publish it with confidence.
Why You’d Need to Replace Audio in a Video?
Audio replacement is more common than you’d think. Here are the four most frequent reasons editors reach for this workflow:
Bad ambient noise: Wind, traffic, HVAC hum, or room echo made the on-camera audio unusable during editing.
Wrong background music: The music recorded alongside the footage is copyrighted, timed poorly, or simply doesn’t fit the final cut.
New voiceover or narration: You need to re-record commentary for clarity, pacing, language changes, or script corrections.
Re-dubbing a clip: You’re adding translated dialogue, a corrected script line, or lip-synced audio to existing footage.
Most editing tools handle this non-destructively, so your original video file stays untouched while you work inside the timeline.
Best Tools to Replace Audio in a Video (Quick Comparison)
Before jumping into tutorials, use this table to find the right tool for your setup:
Tool |
Platform |
Cost |
Best For |
DaVinci Resolve |
PC / Mac |
Free |
Full control, professional output |
PC / Mac |
Paid |
Advanced editors, multi-track |
iMovie |
Mac / iPhone |
Free |
Beginners on Apple devices |
CapCut |
Mobile / Desktop |
Free |
Quick edits, social content |
Kapwing |
Browser |
Free (watermark on free tier) |
No-install, simple swaps |
How to Replace Audio in a Video on a Desktop?
Using DaVinci Resolve (Free)
DaVinci Resolve is the strongest free desktop option for audio replacement. It gives you full timeline control, a dedicated audio workspace, and flexible export settings without a subscription.
Open DaVinci Resolve and create a new project. Name and save it to your preferred location.
Go to File > Import Media and add your video file to the Media Pool. You can also drag and drop it directly from your file browser. Or, you can go to the Media Pool tab. Then right-click the empty space and select the Import Media option.
Drag the clip from the Media Pool down to the timeline on the Edit page.
Right-click the clip on the timeline and uncheck Link Clips. This separates the audio and video into independently editable tracks.
Click the unlinked audio waveform to select it, then press Delete to remove it. If you prefer to keep the original audio hidden rather than deleted, right-click the audio clip and choose Mute instead.
Import your replacement audio file into the Media Pool using the same import method, then drag it onto an empty audio track beneath the video clip.
Align the start of the replacement audio with the beginning of the video. Zoom in on the timeline using your scroll wheel for frame-accurate placement. Use waveform peaks (a clap, a word onset, or a sound effect) to confirm sync visually.
Adjust volume in the Inspector panel or switch to the Fairlight page for more detailed level control.
When ready, go to the Deliver page, choose MP4 or MOV, set audio to AAC at 320 kbps or higher, and click Add to Render Queue > Start Render.
Using Adobe Premiere Pro
Premiere Pro is the industry standard for multi-track editing. These steps assume basic familiarity with the workspace.
Open Adobe Premiere Pro and go to the Import tab. Select files from the local drive, then click the Import button to make them available on the timeline.
Right-click the clip on the timeline and select Unlink. Click the audio clip and press Delete to remove it, or press M to mute it without permanently deleting it.
Import your replacement audio file and drag it to the A1 track (or any open audio track) beneath the video.
Align the audio to the video using waveform peaks or a visible sync cue, such as a hand clap with a matching motion on screen.
Adjust gain and levels in the Audio Track Mixer (Window > Audio Track Mixer) if the replacement clip needs volume correction.
Export via File > Export > Media. Choose H.264 and set audio to AAC at 320 kbps. Click Export or send to Media Encoder for background rendering.
Using iMovie on Mac
iMovie is the most beginner-friendly option for Mac users and handles basic audio replacement without any complicated settings.
Open iMovie, go to the Projects tab, and click CreateNew > Movie to start a fresh project. Import your video via File > Import Media, then drag it into the timeline.
Select the clip and right-click on it to open the menu. Then choose Detach Audio. A separate green audio bar will appear beneath your video clip.
Click the green audio clip and press Delete to remove it.
Drag your replacement audio file from Finder directly into the iMovie timeline, positioning it below the video track.
Use the volume handle (the horizontal line on the audio clip) to adjust loudness. Trim the clip if it runs longer than the video.
Click File > Share > File and choose your preferred export resolution and format.
How to Replace Audio in a Video on a Mobile?
Using CapCut
CapCut is the most capable free mobile editor for audio replacement. Its track-based layout makes the process clear even on a first try.
Open CapCut and tap New Project. Select your video from the gallery and tap Add.
Tap the video clip in the timeline to select it (a white outline will appear around it).
In the bottom editing menu, tap Volume and drag the slider all the way to 0. This mutes the original audio without deleting it, which is a safer approach if you might want to review it later.
Deselect the clip by tapping an empty area of the timeline. Then tap the Audio button in the main bottom menu.
To choose your replacement audio source, tap Sounds to browse CapCut’s built-in library, Voiceover/Record to record new narration directly in the app, or Extract to pull audio from another video on your device.
To import a file from your phone’s storage, tap Sounds, select the Folder icon, and tap the Device tile. CapCut supports MP3, WAV, and M4A formats.
Once the audio is added, tap and drag it in the timeline to align it with your video. Pinch the timeline with two fingers to zoom in for more precise positioning.
Tap the audio clip and use the Volume slider to balance levels. You can also adjust the Fade In or Fade Out for smooth transitions. Tap the checkmark to confirm, then tap the Export arrow in the top right, select 1080p, and save to your gallery.
Using iMovie on iPhone
iMovie on iPhone is a clean, Apple-native option for users already in the Apple ecosystem.
Open iMovie, tap the “+” button, and choose Movie. Select your video and tap Create Movie.
Tap the video clip in the timeline to select it.
Tap the Audio button (speaker icon) that appears beneath the timeline and drag the volume slider to 0 to mute the original audio.
Tap the “+” Add Media button. Select Audio, then browse your Music library or tap Files to locate an audio file stored on your device.
Trim and drag the imported audio clip in the timeline to align it with your video.
Tap Done (top left), then tap the Share icon and select Save Video to export.
How to Replace Audio in a Video Online (No Software Needed)
For users who cannot install software, Kapwing is the most practical browser-based option.
Go to kapwing.com and open the Video Editor to start editing.
Click Upload/Click to Upload and select your video file, or paste a shareable video URL to load it directly.
Note: You will need to sign up to proceed.
To bring the clip onto the timeline, hover over the file and click the + button.
Once the video clip is on the timeline, right-click it and select Detach Audio from the menu. This will separate the audio from the video and place it on a new audio track on the timeline.
Select the detached audio clip and press the Delete button to remove it.
Now, click the Upload Media button to upload the audio file you want to use in the video as a replacement. After the file is in the Media section, click + to add it to the timeline. Kapwing accepts MP3, WAV, and other common formats.
Drag the audio clip in the timeline to align it with the video. Trim it if it runs longer than the footage.
Click Export Project in the top right, wait for processing, and download your finished file.
Note: The free plan places a watermark on every exported video. You can only upload files up to 250 MB. Free exports are also limited to 1 to 4 minutes. The exact limit depends on the current promotion. Timeline syncing and keyframe editing are less accurate than desktop video editors. Because of this, Kapwing is better for replacing full audio tracks and updating social media videos than making frame-by-frame edits.
Tips for Recording Clean Replacement Audio
If your audio replacement plan involves recording a new voiceover or narration, the quality of that recording is just as important as the editing workflow. A few practices that make a real difference:
Record in a quiet, treated space: Close doors, turn off fans and HVAC units, and position yourself away from hard reflective surfaces. Even a walk-in closet with clothing around you can cut the room echo dramatically.
Keep the microphone close: Aim for 6 to 12 inches between the mic and your mouth. This maximizes your voice signal and reduces the room’s contribution to the recording.
Set levels before committing: Target peaks around -12 dBFS to -6 dBFS to leave headroom for natural variation without risking distortion.
Match the sonic character of your footage: Adding a subtle layer of ambient room tone beneath your narration helps the replacement audio sit naturally inside the video rather than sounding disconnected from the environment.
Pro Tip: For desktop and studio voiceover recording, the Hollyland LARK MAX 2 is a strong hardware choice. Its 32-bit Float Internal Recording means audio never clips even if levels spike unexpectedly, and AI Noise Cancellation keeps imperfect room environments from ruining the take. Capture happens at 48 kHz, so your replacement track meets professional broadcast standards. For mobile creators recording replacement narration on the go, the Hollyland LARK M2 weighs just 9 grams and delivers up to 40 hours of battery life. It clips to your collar and feeds clean audio directly into your smartphone, so the narration you record today sounds better than whatever it is replacing.
Q: Can I replace audio in a video without losing quality?
Yes. Export at the original video resolution and choose lossless or high-bitrate audio settings (AAC at 256 to 320 kbps, or WAV) in tools like DaVinci Resolve or Premiere Pro. In advanced workflows, the video stream can be copied without re-encoding at all. For most users, the standard export presets in any of the tools recommended above will preserve excellent quality throughout.
Q: How do I replace audio in a video for free?
You can replace audio on your desktop with DaVinci Resolve for free. No subscription is needed to use this feature. CapCut does the same on mobile, and Kapwing works in any browser without any installation. All three let you complete the basic process without paying. Keep in mind that Kapwing adds a watermark to videos exported with its free plan.
Q: Can I replace only part of a video’s audio?
Yes. In DaVinci Resolve, Premiere Pro, or CapCut, split the audio track at the exact points where you want the replacement to begin and end. Delete or mute only that target segment, then drop your replacement audio in, aligned to that specific range. Audio outside those split points stays completely untouched.
Q: Does replacing audio affect sync with the video?
Yes, it can happen when the new audio is longer or shorter. Always align the start point carefully and use visual sync cues (a visible clap, a door closing, or a word matching a clear mouth movement on screen) to lock audio to picture. Matching the waveforms in DaVinci Resolve or Premiere Pro makes audio syncing much more accurate.
A bad soundtrack does not always mean your video is lost. Replacing the audio can make the footage useful again. DaVinci Resolve gives desktop users a free way to make high-quality edits. CapCut is a better choice when editing quickly on a phone. Recording with a good microphone helps stop these audio issues before they happen.
