Background noise can weaken even a strong, engaging video. Whether you recorded near a busy street, in a room with an HVAC hum, or outdoors on a windy day, CapCut’s built-in Reduce Noise tool can clean up your audio without leaving the app. This guide shows steps for mobile and desktop. You can quickly find the feature and apply it correctly.
What CapCut’s Noise Reduction Feature Does
CapCut’s Reduce noise filter scans the audio in a selected clip and suppresses ambient sounds like wind, crowd noise, and room hum, making the primary voice or sound clearer. It works as a toggle on most current versions, so there is no complex setup involved. The effect is most noticeable on recordings where background noise is consistent and moderate rather than sudden or extreme.
How to Enable Noise Reduction on CapCut Mobile (iOS and Android)
The mobile version of CapCut is where most creators start. The noise reduction option is located at the bottom toolbar, but the navigation can confuse a lot of users who are interacting with the app for the first time.
Step-by-Step Instructions (CapCut Mobile)
Open CapCut and tap the New video tile. Then select the video clip and tap “Add” to include the file on the timeline.
In the timeline at the bottom of the screen, tap the video clip that contains the audio you want to clean up.
If it is a separate audio file you want to import to your project, tap Audio and then Sounds.
Select the Folder icon, tap the Device tile, and choose the audio file/audio recording from your phone by tapping the “+” button.
Once the audio clip is on the timeline's audio track, tap it to select it.
A bottom toolbar will appear. So scroll through the options and tap on the Reduce noise icon.
Tap the Reduce noise toggle to activate it and tap the checkmark.
CapCut will automatically reduce the noise in that audio clip. No manual adjustment required.
Note: The Reduce Noise option only appears when the selected clip contains audio. If the option is missing, the most likely cause is an outdated app version.
Tips when Applying the Reduce Noise (Noise Reduction) in CapCut Mobile
Preview before exporting: Play back a section of dialogue after applying the effect to catch any unintended artifacts.
Avoid over-applying: Too much reduction can make voices sound hollow, muffled, or slightly robotic.
How to Enable Noise Reduction on CapCut Desktop (PC and Mac)
The desktop version of CapCut uses a different interface layout, but the noise reduction feature is equally accessible once you know where to look.
Step-by-Step Instructions (CapCut Desktop)
Open CapCut on your PC or Mac and load your existing project, or create a new project and import the video clip.
In the timeline at the bottom of the screen, click the clip whose audio you want to adjust.
With the clip selected, look at the right-side panel and click the Basic tab.
Scroll down to locate the Reduce noise option.
Click the Reduce noise checkbox to enable it.
Click the Play button to preview playback and confirm the audio sounds clean, then save your project.
Note: The name/label of the noise reduction feature in the CapCut mobile and desktop applications may slightly differ, so don’t get puzzled.
Get Cleaner Audio Before You Edit
Noise reduction in post-production works best when background noise is light to moderate. Heavier noise can push the filter past its limits and degrade overall audio quality. If you frequently record on the go, capturing cleaner audio at the source means CapCut has far less work to do. A compact wireless mic like the Hollyland LARK M2 (9g, with built-in Environmental Noise Cancellation - ENC) or the plug-and-play Hollyland LARK A1 (direct USB-C/Lightning connection, 3-level Intelligent Noise Cancellation) gives your footage a clean audio baseline, so noise reduction becomes a polishing step rather than a rescue operation.
Why can’t I find the Noise Reduction option in CapCut?
First, ensure your app is updated to the latest version. Older versions may miss the feature or label it differently. Next, check that your selected clip contains audio. The option will not show for silent clips or when nothing is selected in the timeline.
Does CapCut noise reduction work on background music or only voice?
The feature is designed to target ambient environmental noise and improve voice clarity. Applying it to a background music track is likely to degrade audio quality rather than improve it. For best results, use noise reduction only on clips that capture spoken audio or recorded environmental sound.
Will enabling noise reduction affect video quality?
No. The noise reduction filter only processes the audio track and has no effect on the video image. Your footage resolution, color grading, and frame rate remain completely unchanged regardless of the intensity level you choose.
Even high-end phones or cameras still capture unwanted noise. While editing in CapCut desktop or mobile, noise reduction can clean background audio. You can quickly find this option inside the editing tools. The process stays simple and takes only a few seconds.
