How to Add Captions on TikTok (Auto and Manual Methods)
Adding captions to your TikTok videos takes less than two minutes and immediately makes your content more accessible, more watchable, and more likely to hold attention. Whether you want TikTok to generate captions automatically from your speech or prefer to add styled text manually, this guide walks you through every method — including how to fix errors before you hit publish.
Why Captions Matter on TikTok
Captions are no longer optional for creators who want to compete for attention on TikTok. Here’s why they deserve a place in every upload:
  • Most viewers watch on silent. Studies consistently show that the majority of social video is consumed without sound — meaning unsubtle content gets scrolled past before the audio ever plays.
  • Captions improve accessibility. Viewers who are Deaf, hard of hearing, or watching in a noisy or quiet environment can follow along without missing your message.
  • They improve on-screen comprehension and watch time. Text reinforces your spoken words, reduces cognitive load, and gives viewers a reason to stay for the full video.
Getting captions on your videos is one of the lowest-effort, highest-return habits you can build as a TikTok creator.
Method 1 — How to Use TikTok’s Auto-Captions Feature
TikTok’s built-in auto-captions tool uses speech-to-text technology to transcribe your spoken audio and display it as styled subtitles. This is the fastest way to caption an entire video.
Steps:
  1. Record or upload your video. Open TikTok and record a new clip, or tap the upload icon to select a video from your camera roll.
  2. Proceed to the editing screen. After recording or selecting your video, tap Next to open the TikTok editor.
  3. Tap “Captions” in the right-side toolbar. Scroll through the editing tools panel on the right until you see the Captions icon (speech bubble with lines). Tap it.
  1. Wait for TikTok to generate captions. The app will analyze your audio and automatically produce a timed transcript. This usually takes 10–30 seconds, depending on video length.
  2. Review the generated captions. TikTok will display the captioned text over a preview of your video. Read through each segment carefully for errors.
  1. Tap “Done” or “Confirm” to apply the captions. Once you’re satisfied, confirm the captions and continue to the posting screen.
Note: The Captions tool only appears if TikTok supports auto-captions in your device language and region. If you don’t see it, check that your app is fully updated.
How to Edit or Fix Auto-Captions on TikTok
Auto-captions are accurate much of the time, but they frequently stumble on names, slang, technical terms, or unclear speech. Correcting them before posting takes under a minute and is worth doing every time.
  1. After generating captions, tap the pencil icon (or tap directly on the caption text in the preview) to enter edit mode.
  2. Tap any caption segment you want to correct. TikTok displays the text for that time segment in an editable field.
  3. Delete the incorrect word and retype it correctly. Use your keyboard as you would in any text field.
  4. Tap the checkmark or “Done” to confirm the correction.
  5. Repeat for all remaining errors across the full transcript.
  6. Tap “Done” once the full caption track is clean to return to the editing screen.
Work through the captions from start to finish rather than skimming — a single misheard word can change the meaning of a sentence entirely.
Tip — Improve Caption Accuracy with Better Audio
Auto-captions are only as accurate as the audio they’re transcribing. If TikTok is struggling to recognize your speech, the root cause is almost always background noise or microphone distance. Creators who use a lightweight wireless clip-on mic — like the Hollyland LARK M2 (9g, 40-hour battery, built specifically for vloggers and TikTok creators) — see noticeably fewer transcription errors because the microphone sits close to the speaker’s mouth, delivering a clean, direct signal that TikTok’s speech recognition can parse reliably.
Method 2 — How to Add Manual Text Captions on TikTok
If you want styled, selectively placed captions rather than a full-video transcription, TikTok’s Text tool lets you add individual lines of text and sync them to specific moments in your video. This approach is ideal for highlighting a key phrase, adding a one-line hook, or captioning sections of a video that include music rather than speech.
  1. Open the TikTok editor after recording or uploading your video.
  2. Tap “Text” (Aa) at the bottom of the screen. This opens the text input toolbar.
  3. Type your caption text. Keep lines short — one to seven words per card works best on mobile screens.
  4. Choose a font, color, and background style using the formatting options at the top of the keyboard panel.
  5. Tap “Done” to place the text on your video canvas.
  6. Set the display duration. Tap and hold the text sticker on the timeline at the bottom of the screen, then drag the left and right handles to define exactly when the text appears and disappears.
  7. Repeat for each additional caption line you want to add across the video.
Note: Manual text captions are not the same as the auto-captions feature — they won’t be togglable by viewers and require you to type every word yourself. Use this method for selective emphasis, not full transcription.
How to Turn Off or Delete Captions on TikTok
Removing captions in the editor (before posting):
  1. Open the TikTok editor and tap Captions in the right toolbar.
  2. Look for the Delete or Remove option within the captions panel.
  3. Confirm deletion — the caption track will be removed from the video.
  4. Tap Done to return to the editing screen.
Hiding captions as a viewer (during playback):
  1. While watching a TikTok with captions enabled, tap the Captions icon (CC or speech bubble) that appears during playback.
  2. Captions will toggle off for that viewing session.
Captions generated by the auto-captions tool are not permanently burned into the video file — viewers always have the option to turn them off on their end.
Adding Captions with CapCut (Advanced Option)
CapCut — TikTok’s companion editing app — offers a more powerful auto-captions feature with additional styling and animation options. It’s a solid choice for creators who want more visual control over how their captions look before importing to TikTok.
Quick steps to use CapCut’s Auto Captions:
  1. Open your video project in CapCut.
  2. Tap Text in the bottom toolbar, then select Auto Captions.
  3. Choose your spoken language and tap Generate.
  4. Review and edit the generated transcript in CapCut’s caption editor.
  5. Adjust fonts, colors, size, and animations to match your brand style.
  6. Export the video and upload it directly to TikTok.
If your site covers CapCut tutorials in depth, this is a natural internal link opportunity. For most TikTok creators, the native auto-captions tool is sufficient — CapCut adds value primarily when aesthetic control over caption styling matters.
Q: Why are my TikTok auto-captions not showing up?
Auto-captions are not available in all languages or regions. If the Captions tool doesn’t appear in your editor, your device language may not be supported yet, or your app may be outdated. Update TikTok to the latest version through the App Store or Google Play and check again. TikTok continues to expand language support over time.
Q: Can viewers turn off captions on TikTok?
Yes. Captions added through TikTok’s native auto-captions tool are viewer-togglable. During playback, viewers can tap the Captions icon (CC symbol) to turn them on or off at any time. The captions are not burned into the video itself, so turning them off doesn’t affect the original file or other viewers’ experience.
Q: Can I add captions to a TikTok video after posting?
TikTok does not currently allow you to edit or add captions to a video after it has been published. If you need to add or correct captions on a live post, you’ll need to delete the original video and re-upload it with captions applied during the editing stage before posting.
Q: Does TikTok auto-captions support multiple languages?
TikTok supports auto-captions in a growing list of languages, but availability varies by region and is not universal. Open the Captions tool in your editor — if the feature appears grayed out or is missing entirely, your current language setting is likely not yet supported. Check TikTok’s help center for the current list of supported languages.
Q: Are TikTok captions the same as subtitles?
For practical purposes, yes. TikTok’s Captions feature transcribes spoken audio into on-screen text, which functions as subtitles for accessibility and silent viewing. The distinction between “captions” (speech-to-text for accessibility) and “subtitles” (translation for language) exists technically, but TikTok uses the two terms interchangeably within the app.
Final Thoughts
Captions are one of the simplest upgrades you can make to any TikTok video — they take minutes to add and immediately expand who can watch and enjoy your content. Start with auto-captions on your next upload, spend thirty seconds reviewing the transcript for errors, and make it a standard step in your posting routine. Clean audio and accurate captions work together: the better your recording, the less editing you’ll need to do.
