How to Trim Video in Premiere Pro (4 Methods + Shortcuts)
Trimming footage is one of the first skills you need to master in Adobe Premiere Pro, and it is also one of the most misunderstood. You have several tools available, and choosing the wrong one leads to gaps in your timeline, misaligned clips, and frustration. This guide walks you through four practical trimming methods, from the simplest drag-trim to the professional-grade Ripple Edit Tool, so you can work faster and cleaner on every project.
What “Trimming” Means in Premiere Pro
Trimming means shortening a clip from its start or end to remove unwanted footage. This is different from cutting, which splits a clip into two pieces using the Razor Tool. All trimming in Premiere Pro is non-destructive, meaning your original media file on disk is never altered. You are only adjusting which portion of the clip plays back in your sequence.
Method 1 — Drag to Trim Clip Edges in the Timeline
Drag-trimming is the most intuitive way to shorten a clip and the best starting point for beginners. You work directly in the Timeline panel with no extra tools required.
  1. Select the Selection Tool by pressing V.
  2. Hover your cursor over the very start (head) or end (tail) of a clip in the Timeline.
  3. Wait for the cursor to change into a red bracket with an arrow. This is the trim cursor.
  4. Click and drag inward to shorten the clip. Drag the head to the right to remove footage from the beginning, or drag the tail to the left to remove footage from the end.
  5. Release when you reach the desired point. The trim is applied immediately.
Note: Dragging a clip edge inward with the standard Selection Tool will leave an empty gap in your timeline where the footage used to be. See the section below to fix this quickly.
How to Remove Gaps After Trimming
When you trim a clip in the middle of a sequence, Premiere Pro leaves a black gap in place of the removed footage. Here is the fastest way to close it.
  1. Right-click on the empty gap in the timeline.
  2. Select Ripple Delete from the context menu.
  3. All clips to the right of the gap will shift left to close the space automatically.
Alternatively, you can hold Shift and press Delete (Windows) or Shift + Forward Delete (Mac) after selecting the gap to ripple-delete it with a keyboard shortcut.
Method 2 — Use the Razor Tool to Cut and Remove Sections
The Razor Tool is the right choice when you need to remove a section from the middle of a clip, such as a cough, a stumble, or a bad take surrounded by good footage on both sides.
  1. Press C to activate the Razor Tool. Your cursor changes to a razor blade icon.
  2. Click on the timeline at the point where you want the unwanted section to begin. This creates a cut.
  3. Click again at the point where the unwanted section ends. You now have an isolated clip segment between the two cuts.
  4. Press V to switch back to the Selection Tool.
  5. Click on the isolated segment to select it.
  6. Press Delete to remove the segment. A gap will appear.
  7. Right-click the gap and select Ripple Delete, or press Shift+Delete, to close it.
Pro Tip: A common mistake is forgetting to press V after cutting. If you click on a clip while the Razor Tool is still active, you will create an unwanted cut instead of selecting the clip.
Method 3 — Ripple Edit Tool for Gap-Free Trimming
The Ripple Edit Tool is the professional standard for assembly editing. When you trim with it, Premiere Pro automatically closes any gap and shifts all downstream clips in the timeline to compensate. You never have to manually ripple-delete a gap again.
  1. Press B to activate the Ripple Edit Tool. The cursor changes to a yellow bracket with a double arrow.
  2. Hover over the head or tail of the clip you want to trim.
  3. Click and drag inward to shorten the clip.
  4. Release, and Premiere Pro instantly closes the gap by pulling all clips to the right of the trim point toward the left.
Standard trim vs. ripple trim at a glance:
  • Selection Tool trim: Shortens the clip, leaves a gap, downstream clips stay in place.
  • Ripple Edit Tool trim: Shortens the clip, gap closes automatically, downstream clips shift left to fill the space.
If you are editing a vlog, interview, or any narrative project where clip timing needs to stay locked, the Ripple Edit Tool will save you significant time compared to trimming and cleaning up gaps separately.
Method 4 — Set In/Out Points in the Source Monitor
This method lets you pre-trim a clip before it ever touches the timeline. It is ideal when you are working with long interview recordings or extended B-roll and want to select only the usable range upfront.
  1. In the Project panel, double-click the clip you want to use. It opens in the Source Monitor.
  2. Play through the clip and pause at the point where you want the clip to begin.
  3. Press I to set the In point. A small triangle marker appears at the playhead position.
  4. Continue playing and pause at the point where you want the clip to end.
  5. Press O to set the Out point.
  6. Drag the clip from the Source Monitor directly onto the timeline. Only the footage between your In and Out points will be placed in the sequence.
The original media file is completely unaffected. You can always go back to the Source Monitor and adjust your In/Out points at any time.
Premiere Pro Trim Keyboard Shortcuts (Quick Reference)
Action
Shortcut (Win / Mac)
Razor Tool
C
Ripple Edit Tool
B
Selection Tool
V
Set In Point
I
Set Out Point
O
Ripple Trim to Playhead (left side)
Q
Ripple Trim to Playhead (right side)
W
Undo
Ctrl+Z / Cmd+Z
Ripple Delete
Shift+Delete / Shift+Forward Delete
The Q and W shortcuts are particularly powerful. With your playhead positioned in the timeline, pressing Q trims the tail of the clip to the left of the playhead and closes the gap, while W trims the head of the clip to the right of the playhead and closes the gap. Both use ripple logic, so downstream clips shift automatically.
Pro Tips for Faster Trimming in Premiere Pro
These four habits will noticeably speed up your trimming workflow once the fundamentals are solid.
  • Zoom in for precision: Press the plus (+) or equals (=) key to zoom into the timeline. Fine-trim cuts are much easier to land accurately when the waveforms and clip edges are clearly visible.
  • Use the Rolling Edit Tool (N): Press N to activate the Rolling Edit Tool. Dragging a cut point with this tool simultaneously extends one clip and shortens the adjacent clip, with no downstream shifting. It is the cleanest way to adjust an edit point between two clips without altering your overall sequence length.
  • Enable snapping (S key): Toggle snapping on by pressing S. Cut points and clip edges will snap to the playhead position, making it easy to trim precisely to a specific frame.
  • Mark sections with markers before trimming: On long footage, press M to drop markers at problem areas while you watch through. You can then navigate between markers and trim each flagged section without scrubbing back and forth.
Q1: Does trimming in Premiere Pro delete the original footage?
No. Premiere Pro works non-destructively. When you trim a clip in the timeline or set In/Out points in the Source Monitor, you are only adjusting which portion of the clip plays back in your sequence. The original media file stored on your drive is never touched, and you can always restore trimmed frames.
Q2: What is the difference between the Ripple Edit Tool and the standard Selection Tool for trimming?
The Selection Tool trims the clip but leaves an empty gap where the removed footage was. The Ripple Edit Tool trims the clip and automatically closes the gap by shifting all downstream clips toward the trim point. For most editing workflows, the Ripple Edit Tool is the faster and cleaner option.
Q3: How do I trim multiple clips at once in Premiere Pro?
To cut across multiple clips simultaneously, hold Shift while pressing C with the Razor Tool active. This places a cut at the playhead position across all tracks. For selecting multiple clips, use Shift+Click or drag a selection box around them, then apply your trim or razor action to the group.
Q4: Why can’t I trim my clip further — it stops before I want it to?
You have reached the end of the available clip handle. Premiere Pro can only show footage that exists in the original media file. If the clip was recorded or exported with a specific start or end point, there is no additional footage hidden beyond that boundary. You cannot extend beyond what was captured.
For simple edits, drag-trimming in the timeline is fast and intuitive. For clean assembly editing, switch to the Ripple Edit Tool and stop worrying about gaps. Use the Source Monitor method when dealing with long recordings and you want to pre-trim before building your sequence. Reach for the Razor Tool whenever you need to surgically remove a section from the middle of a clip. Once these four methods feel natural, explore related techniques like J-cuts, L-cuts, and multi-camera editing to take your Premiere Pro workflow further.
