If your audio sounds quieter or different after uploading to YouTube, you are not imagining it. YouTube automatically adjusts every video’s playback volume to match a loudness standard. Understanding that standard and normalizing your audio before you export means your content sounds exactly as intended, every time.
What Is Audio Normalization and Why Does YouTube Use It?
Audio normalization is the process of adjusting a recording’s overall loudness to reach a consistent target level. Unlike peak normalization, which only raises or lowers the single loudest moment in a file, loudness normalization measures perceived average loudness across the entire track and adjusts accordingly.
YouTube applies this process automatically during playback. When you upload a video, YouTube’s system analyzes it and targets approximately -14 LUFS integrated loudness for playback. This keeps the listening experience consistent across the platform. So a calm meditation video and a loud gaming commentary do not jar viewers switching between them.
The important detail that confuses many creators is this: YouTube does not alter your uploaded file. Normalization occurs only at the playback level. If your audio is louder than -14 LUFS, YouTube turns it down during playback. If it is quieter, your video plays at a lower volume than it could. Normalizing your audio before uploading produces more predictable, polished results.
What is LUFS? LUFS stands for Loudness Units relative to Full Scale. It is a standardized measurement of perceived loudness used across broadcast, streaming, and online video. Unlike decibels (dB), which measure signal level at a single point, LUFS accounts for how humans hear volume over time. A target of -14 LUFS is YouTube’s reference point for balanced, comfortable playback.
How to Normalize Audio Before Uploading to YouTube?
The process begins by checking your audio's current loudness level. Next, adjust the track until it reaches -14 LUFS. Before exporting, confirm the true peak level is correct. The methods below include one free audio editor option. They also cover two popular video editors that many creators already use.
Step 1: Measure Your Current Loudness Level
Before making any adjustments, check where your audio actually sits. Visual waveforms and VU meters are not reliable indicators of perceived loudness.
Download and install Youlean Loudness Meter (free standalone app and plugin, available at youlean.co).
Import or play your audio or video file through the meter.
Check the Integrated LUFS reading. This is your average perceived loudness across the entire file.
Check the True Peak value. This should sit at or below -1 dBTP to prevent distortion after YouTube’s encoding process.
Once you have these two numbers, you know exactly how much your audio needs to change before export.
Step 2: Normalize Audio in Audacity (Free Method)
Audacity is a free, open-source audio editor available for Windows, macOS, and Linux. It includes a dedicated Loudness Normalization function. This is different from Audacity’s basic “Normalize” effect, which only targets peak levels and is not suitable for LUFS-based adjustments.
Open Audacity and import your audio file via File > Import > Audio.
Select all audio with Ctrl+A (Cmd+A on Mac).
Go to Analyze > Measure RMS (a form of Loudness Measurement) to review your current integrated LUFS before making changes.
Go to Effect > Volume and Compression > Loudness Normalization.
In the dialog box, set Perceived Loudness to -14 LUFS.
Leave Normalize Stereo Channels Independently unchecked unless you have a specific reason to separate channels.
Click Apply. Audacity will apply the appropriate gain adjustment across the full track.
Export via File > Export Audio. Use WAV or FLAC to preserve quality before final video rendering.
After exporting, run the file through Youlean Loudness Meter to confirm the reading lands at -14 LUFS integrated with a true peak at or below -1 dBTP.
Step 3: Normalize Audio in DaVinci Resolve (Free and Studio Versions)
Good audio levels help create a smoother viewing experience on YouTube. DaVinci Resolve 21 does not include a direct option for YouTube loudness normalization. Even so, you can combine Normalize Audio Levels with Fairlight loudness controls. This approach helps create more consistent audio across your project.
Before starting either method, set Fairlight Target Loudness to -14 LUFS. This setting matches YouTube's commonly recommended loudness reference. After that, select Sample Peak Program or True Peak Normalization. The better choice depends on your editing process and audio goals.
Open your project and click the gear icon at the bottom right of the interface to open Project Settings.
Click the Fairlight tab on the left sidebar.
Set Target Loudness Level to -14 LUFS.
Option 1: Sample Peak Program
After importing the audio file on the platform, make sure you are on the Edit page. If not, select the Edit page icon from the bottom tabs.
Click the audio file once to select it. Then, right-click the clip and select the Normalize Audio Levels option from the menu.
Choose the Sample Peak Program from the Normalization Mode's dropdown menu.
Enter -14 dBFS and click Normalize.
Option 2: True Peak
Click the Normalize Audio Levels option after selecting the audio file on the timeline.
From the Normalization Mode options, choose True Peak.
Enter -1.0 dBTP and hit Normalize
Once the above steps are done, review your timeline. Pay attention to dialogue, music, and sound effects throughout playback. Make sure none of the audio elements becomes louder than the others. Assuming that you have set the Fairlight Target Loudness to -14 LUFS, monitor the loudness meter during your review. If any section sounds too quiet or too loud, adjust clip volume, track levels, or the master output slightly.
After everything sounds balanced and consistent, export the project using your preferred YouTube settings.
Step 4: Normalize Audio in Adobe Premiere Pro
One way to normalize audio in Premiere Pro is to use the Essential Sound panel. Here’s what to do:
Open the Essential Sound panel via Window > Essential Sound.
Select your audio clip on the timeline and assign it a type (Dialogue, Music, or SFX) in the panel.
Under the Loudness section, click Auto-Match. Premiere targets -23 LUFS by default.
Use the Loudness Radar in the Audio Track Mixer to verify the final LUFS reading before export.
Where to find the Loudness Radar in Adobe Premiere Pro?
Go to Windows > Audio Track Mixer.
Click the arrow or the chevron icon in the top-left corner of the audio mixer to expand the effects slot.
Choose a specific audio track or the Master Mix (also called the Mix) track and click the dropdown menu in the effects slot.
Navigate to Special and select Loudness Radar.
Make sure the effect is selected to Target Loudness.
Press and hold the left click on the knob to set the value to -14 LUFS.
Note: LUFS and LKFS refer to the same loudness measurement system. The two terms can be used interchangeably in most audio situations. Both measure how loud the audio sounds to listeners overall. The measurement is based on perceived loudness relative to the digital full scale.
What Loudness Target Should You Use for YouTube?
The standard is straightforward: -14 LUFS integrated loudness with a true peak no higher than -1 dBTP.
Mixing louder than -14 LUFS provides no benefit. YouTube will reduce playback volume to match its target, meaning extra loudness never reaches the viewer and can introduce artifacts during encoding. Mixing significantly quieter than -14 LUFS means YouTube plays your audio as-is at a reduced volume, making it harder for viewers to hear without adjusting their own settings.
Keeping true peak at -1 dBTP (rather than 0 dBTP) provides headroom to absorb any level increases that occur during YouTube’s AAC encoding conversion.
Parameter |
Target Value |
Notes |
Integrated Loudness |
-14 LUFS |
Measured across the full file |
True Peak |
-1 dBTP or lower |
Prevents clipping after encoding |
Sample Rate |
48 kHz |
Recommended for video content |
Bit Depth |
24-bit (pre-export) |
Preserves dynamic range during editing |
Can You Normalize Audio on YouTube After Uploading?
The direct answer is no. YouTube Studio does not include a loudness normalization tool. YouTube Studio offers only basic audio editing controls for videos. You can mute the existing audio or replace it with music from YouTube's library. The available tools do not change or balance overall loudness levels.
If your uploaded video has audio that sounds too quiet or unbalanced, the correct fix is to return to your original project file, apply loudness normalization using the steps above, re-export, and replace the upload. This is why building normalization into your standard export checklist before every upload is the more practical long-term approach.
Tips for Consistent Audio Across Your YouTube Channel
Set -14 LUFS and -1 dBTP as your export standard for every video. Save it as a template or preset in your editor so it applies without thinking.
Export with a high-quality codec. H.264 video with AAC audio at 320 kbps is a reliable minimum for YouTube.
Use a loudness meter as a final checklist item before every upload, not only when something sounds off.
Start with clean source audio. Noisy recordings are harder to normalize without amplifying background hiss. For vloggers and creators shooting on location, a lightweight wireless mic like the Hollyland LARK M2 (9g, up to 40-hour battery life) captures clean audio at the source, giving normalization tools less noise to work around.
Does YouTube normalize audio automatically?
Yes. YouTube applies loudness normalization during playback, targeting approximately -14 LUFS integrated loudness. This is a playback-level adjustment only and does not change your uploaded file. Louder content is turned down; quieter content plays at a lower volume than it could reach.
What LUFS level should I use for YouTube?
Target -14 LUFS integrated loudness and keep your true peak at or below -1 dBTP. These two values together ensure your audio plays at the correct loudness and avoids distortion introduced during YouTube’s AAC encoding process after upload.
What is the difference between loudness normalization and peak normalization?
Peak Normalization focuses only on the highest audio point in a recording. It raises or lowers volume until that peak reaches a chosen limit, such as 0 dBFS. Loudness Normalization takes a different approach to volume adjustment. It measures average perceived loudness over time using LUFS. For YouTube videos and broadcast content, Loudness Normalization is usually the better choice. It reflects how people hear volume during real-world playback.
How do I normalize audio for free?
Audacity is a free desktop audio editor with a built-in Loudness Normalization function. DaVinci Resolve is a free video editor with normalization built into its Fairlight audio page. Youlean Loudness Meter is a free, standalone tool for checking LUFS levels before and after export.
Will normalizing audio in YouTube Studio fix my volume issues?
No. YouTube Studio does not include a loudness normalization feature. The only audio options in Studio are muting or replacing your audio track. To fix volume issues, normalize the audio in your editing software, re-export the video, and upload the corrected file.
YouTube adjusts audio automatically. But that doesn't mean there is nothing more you should do. When you are editing audio for YouTube, set it to -14 LUFS and -1 dBTP. You can do this in Audacity, DaVinci Resolve, or similar editors. Include loudness normalization in your regular export routine every time. Keep it alongside resolution and codec checks before publishing. This simple step helps every video maintain consistent audio quality. It also makes your channel sound more polished from video to video.
