How to Make Audio Come From Both Sides in Premiere Pro (Step-by-Step)
If your audio is only coming from one side in Premiere Pro, you are not alone. This is one of the most common editing frustrations, and it has a straightforward fix. Most of the time, the clip is a mono recording that Premiere has assigned to a single channel. This guide covers three proven methods to get audio playing from both sides, plus a quick check to make sure your export sounds correct too.
Why Your Audio Is Only Coming From One Side
When you import a mono audio clip, Premiere Pro assigns it to a single channel, typically the left. This is expected behavior, not a bug. The software cannot assume you want the signal duplicated to both channels, so it does not do it automatically. The fixes below work by either remapping the channel assignment or copying the mono signal across both sides.
Fix 1 — Modify Audio Channels at the Clip Level (Recommended)
This is the most reliable and permanent solution. It tells Premiere exactly how to interpret the audio data for that clip.
  1. Right-click the clip in your timeline.
  2. Select Modify > Audio Channels.
  3. In the dialog box, find the Channel Format dropdown. If it shows Mono, change it to Stereo.
  4. In the channel mapping grid, set both the Left and Right output channels to read from Channel 1 (the source channel that contains your audio).
  5. Click OK and play back the clip.
Audio should now come through both speakers.
How to Apply This to Multiple Clips at Once
You do not need to repeat these steps clip by clip.
  1. In the timeline, click one affected clip, then hold Shift and click the remaining clips to select all of them.
  2. Right-click any selected clip and choose Modify > Audio Channels.
  3. Apply the same settings from Fix 1 above and click OK. Premiere applies the change to every selected clip at once.
Fix 2 — Use the Fill Left or Fill Right Audio Effect
This is the fastest fix for a single clip and requires no dialog boxes.
  1. Open the Effects panel (Window > Effects).
  2. Navigate to Audio Effects > Special.
  3. If your audio signal is on the left channel only, drag Fill Left onto the clip. This copies the left channel signal to the right so both sides play audio.
  4. If your signal is on the right channel only, drag Fill Right onto the clip instead.
  5. Play back the clip to confirm both sides are active.
Note: Fill Left and Fill Right are a quick patch, not a deep fix. For a cleaner, more scalable solution across multiple clips, Fix 1 is the better approach.
Fix 3 — Adjust Panning in the Audio Clip Mixer
If your clip is stereo but sounds weighted to one side, a panning adjustment may solve it. Note that this is a workaround and does not remap channels, so it may not resolve all export issues.
  1. Open the Audio Clip Mixer (Window > Audio Clip Mixer).
  2. Click the clip in the timeline to select it.
  3. Find the pan/balance knob in the mixer and drag it to center, setting the value to 0.
A true mono-mapped clip will still export incorrectly if you rely on panning alone, so combine this with Fix 1 if you need a permanent result.
Make Sure Your Export Also Has Audio on Both Sides
Fixing the timeline does not automatically update your export settings. Before you render, check the following:
  • Go to File > Export > Media, or open Adobe Media Encoder.
  • Click the Audio tab in the Export Settings panel.
  • Confirm Output Channels is set to Stereo, not Mono.
  • Apply the setting and export.
How to Prevent One-Sided Audio From the Start
The simplest way to avoid this problem is to record in dual-channel stereo at the source. If you use a wireless microphone system like the Hollyland LARK MAX 2, confirm the transmitter output is set to dual-channel before recording. Importing a proper stereo file means Premiere has no ambiguity about channel assignment from the start.
Why does my audio only play from the left side in Premiere Pro headphones?
Your clip is most likely a mono track mapped to the left channel only, which is Premiere’s default behavior for single-channel audio files. Use Fix 1 (Modify Audio Channels) to remap the signal to both left and right channels. After applying the change, playback should come through evenly on both sides.
Will changing audio channels in Premiere affect the original file?
No. Premiere Pro is a non-destructive editor. Channel mapping changes only affect how Premiere reads the file within your sequence. The original media file on your drive remains completely untouched, so you can always revert if needed.
Why is my audio still one-sided after export?
The timeline fix does not carry over to export settings automatically. Open Export Settings, click the Audio tab, and confirm Output Channels is set to Stereo before rendering. This is the most commonly missed step and the most frequent reason an exported file still sounds one-sided.
For a permanent fix across your entire project, use Fix 1 (Modify Audio Channels) at the clip level. For a fast patch on a single clip, apply the Fill Left or Fill Right effect. For a quick playback balance adjustment, use the Audio Clip Mixer pan control. Whichever method you choose, always confirm your Export Settings are set to Stereo before you hit render.
