Hearing audio in only one ear while editing in Premiere Pro is one of the most disorienting problems you can run into mid-project. The good news: it almost always comes down to a software setting, not a corrupted file or broken hardware. This guide walks through every likely cause and gives you a clear fix for each one, starting with the simplest check and moving to the most thorough solution.
Why Audio Plays in Only One Ear in Premiere Pro
Before jumping into fixes, it helps to know which problem you’re actually dealing with. Three root causes cover the vast majority of cases:
The pan or balance knob is off-center. A knob accidentally dragged to the left or right in the Audio Track Mixer or Effects Controls will push all audio to one side.
The source clip’s channels are mapped incorrectly. Mono audio recorded to a single microphone channel is often imported with that signal routed only to the left channel (Channel 1), leaving the right side silent.
The audio track type does not match the clip type. Placing a mono clip on a stereo track, or mismatching in other ways, forces Premiere to make an assumption about channel routing that is usually wrong.
Scan that list and identify which scenario fits your situation, then jump to the corresponding fix below.
Fix 1 – Reset the Pan/Balance Knob in the Timeline
This is the fastest check and the most common mistake beginners make without realizing it. Panning can be set at both the track level and the clip level, so check both.
Check the Audio Track Mixer:
Go to Window > Audio Track Mixer to open the panel.
Locate the track that contains your problem clip.
Look at the circular pan/balance knob near the top of the track channel strip.
If it is turned left or right, double-click it to snap it back to center (0.0).
Check the Effects Controls panel:
Click the clip in your timeline to select it.
Go to Window > Effects Controls.
Expand the Audio section and look for the Panner > Balance value.
If it reads anything other than 0.0, double-click the value and type 0 to reset it.
Play the clip again. If audio now comes through both ears, this was your issue.
Fix 2 – Correct the Audio Channel Mapping in the Clip
This is the most common cause for editors working with footage from cameras, wireless microphones, or any single-channel recording device. Premiere imports the clip and assigns its audio to Channel 1 only, which maps to the left ear by default.
Access the Audio Channels dialog:
In the Project panel, right-click the source clip (not the sequence clip).
Select Modify > Audio Channels.
The Audio Channels dialog opens. Look at the Clip Channel assignments on the left and where they are routed on the right.
What incorrect mapping looks like: - Preset is set to Stereo, but only Channel 1 has a source assigned. Channel 2 is empty, producing silence on the right.
How to correct it:
In the Preset dropdown at the top of the dialog, change the setting from Stereo to Mono.
Confirm that the single channel maps to both the left and right output.
Click OK.
When a clip is set to Mono, Premiere automatically distributes the signal to both ears during playback without requiring any additional effects.
Setting |
Channel 1 Source |
Channel 2 Source |
Result |
Stereo (incorrect) |
Mic L |
Empty |
Audio in left ear only |
Mono (correct) |
Mic L |
Mic L (auto) |
Audio in both ears |
Important: Apply this fix in the Project panel before dragging the clip to your timeline. If the clip is already in your sequence, right-click it there as well and repeat the same steps to update the sequence instance.
Fix 3 – Match the Audio Track Type to the Clip
When a mono clip sits on a stereo track, Premiere may route the signal only to the left channel because it treats the mono source as the left half of a stereo pair. This is common when recording from a single lavalier microphone or from one camera audio channel.
Check the track type:
Look at the left side of your timeline at the track headers.
The icon next to the audio track name indicates its type. A waveform with two bars is stereo; a single bar is mono.
If your mono clip is sitting on a stereo track, you need to move it.
Add a Mono audio track and move the clip:
Right-click in the track header area of the timeline and select Add Track.
In the Add Tracks dialog, under Audio Tracks, set Track Type to Mono and click OK.
Cut the clip from the stereo track and paste it onto the new mono track.
Play the clip to confirm audio is now balanced across both ears.
This scenario comes up most often with footage from a single-channel camera input or a wireless lav rig that records to only one track.
Fix 4 – Apply the Fill Left or Fill Right Audio Effect
If remapping channels is not an option because you are working with a locked or delivered file, the Fill Left and Fill Right effects offer a fast workaround. Use this approach when you cannot access or modify the original clip’s channel mapping.
Open the Effects panel (Window > Effects).
In the search bar, type Fill Left or Fill Right.
Drag the effect onto the problem clip in your timeline.
No configuration is needed. The effect immediately mirrors one channel across both outputs.
Which one to use: If audio is coming from the left ear only, apply Fill Left (it copies the left channel to the right). If audio is coming from the right ear only, apply Fill Right.
This is a remedial fix that solves the symptom without correcting the underlying channel mapping. Use Fix 2 whenever possible for a cleaner result, and reserve this effect for situations where the source file cannot be modified.
Quick Diagnostic Checklist
Run through this list before and after applying any fix to confirm everything is set correctly:
Pan/Balance knob is at 0.0 in both the Audio Track Mixer and the Effects Controls panel.
Audio Channels dialog is set to Mono (or channels are mapped to both L and R) for any single-channel source clip.
Audio track type matches the clip type – mono clips are on mono tracks, stereo clips are on stereo tracks.
Fill Left or Fill Right effect is applied if working with a file that cannot be remapped at the clip level.
Fix was applied in the Project panel before dragging the clip to the sequence, to avoid needing to re-edit existing cuts.
Why does my audio sound fine in Premiere but play in one ear after export?
This usually means the sequence audio settings and the export codec settings are not aligned. Go to Sequence > Sequence Settings and confirm the audio output is set to stereo. When exporting, open the Audio tab in the Export Settings dialog and verify that the Channels field is set to Stereo, not Mono or a single-channel output. A mismatch between these two settings is the most frequent cause of exports that differ from timeline playback.
Why is only one audio track showing in my timeline?
The camera or recording device likely captured audio on only one channel. Before troubleshooting inside Premiere, open the original source file in VLC or QuickTime and check how many active audio channels it contains. If only one channel has signal in the source file, the problem exists upstream of Premiere. Fix 2 (Audio Channels remapping to Mono) is still the correct solution, but it helps to know the issue begins at the recording stage.
Does this fix apply to audio imported from a wireless microphone?
Yes. Wireless lavalier and clip-on microphone systems frequently record mono audio to a single channel, which Premiere maps to the left channel by default. Fix 2, setting the Audio Channels dialog to Mono via Modify > Audio Channels, is the correct resolution. The issue is not the microphone itself but the channel assignment Premiere makes on import. Remapping the clip to Mono distributes the signal correctly to both ears.
For most editors, Fix 2, the Audio Channels remapping via Clip Modify > Audio Channels, resolves the one-ear audio problem. Apply it in the Project panel before placing the clip in your sequence to keep your timeline clean. If you are building out your project settings from scratch, also review your sequence audio configuration to prevent the issue from reappearing on the next import.
Suggested next step: See the related guide on configuring sequence audio settings and exporting stereo audio correctly in Premiere Pro.
