How to Get Rid of Wind Noise in DaVinci Resolve (Step-by-Step)
Wind noise often creates problems for outdoor video creators. DaVinci Resolve Fairlight includes tools that reduce unwanted wind sound. You do not need extra plugins for basic audio cleanup work. This guide explains three methods depending on noise damage level. One method uses a high-pass filter for quick sound cleanup. Another method applies stronger noise reduction inside Fairlight editing tools.
What Makes Wind Noise Difficult to Remove?
Unlike a steady electrical hum or a consistent tape hiss, wind noise does not sit at a single frequency. It spans a wide range, from deep low-frequency rumble (below 100 Hz) up through turbulent mid-range crackling, and that overlap with the human voice is what makes it genuinely tricky to remove cleanly.
When listening back to wind-affected audio, you will typically notice:
  • A deep, low-frequency rumble underneath all other sound
  • Muffled or “woolly” dialogue from the mid-range turbulence
  • Sudden bursts of crackling or blasting when gusts hit the mic directly
Because no single band covers all of these characteristics, one tool alone is rarely enough for moderate or severe wind.
Method 1: Apply a High-Pass Filter Using Fairlight EQ
This is the fastest fix available and works in both the free and Studio versions of DaVinci Resolve. A high-pass (low-cut) filter removes the low-frequency rumble that sits below intelligible speech, which is often the most audible and distracting part of wind noise.
Steps:
  1. Open your project and click the Fairlight tab at the bottom of the screen.
  1. Double-click the audio clip you want to fix, or select the track.
  2. Open the Equalizer by clicking the EQ button in the mixer panel.
  1. Now, activate the EQ by clicking the EQ space on the dedicated track.
  2. Activate the leftmost band (Band 1) and set its type to High Pass. A High Pass filter
Note: In an EQ type, a high-pass is shown with a curved line. It drops on the left side and rises into a flat line. This shape means low frequencies are reduced. Higher frequencies continue through without much change. It is often used to remove low-end rumble.
  1. Set the cutoff frequency to 80 Hz as your starting point.
  1. Set the filter slope to 12 dB/oct for a moderate cut, or 24 dB/oct for a steeper, more aggressive roll-off. But since you have already used the High Pass type in Band 1, this adjustment will be by default.
  2. Play the clip and slowly sweep the cutoff frequency upward toward 120 Hz until the rumble becomes inaudible.
  3. Stop sweeping as soon as dialogue starts to sound thin or hollow — that is the point where you are cutting into the voice.
Note: Most male voices have fundamental energy starting around 85–100 Hz, and female voices around 165–255 Hz. Starting at 80 Hz is safe for most recordings. Move to 100–120 Hz only if rumble persists and the voice still sounds natural.
When to Use This as Your Only Fix?
A high-pass filter alone is sufficient for light wind recorded at a distance, where turbulence stays mostly in the low frequencies. If the wind noise still sounds present after applying the filter, particularly as a muffled quality or crackling in the mids, continue to Method 2.
Method 2: Use the Fairlight Noise Reduction Plugin
For moderate to severe wind, the Fairlight Noise Reduction plugin is the most effective built-in tool DaVinci Resolve offers. It works by sampling a section of the unwanted noise and then subtracting that noise profile from the rest of the audio.
Steps:
  1. In the Fairlight page, open the Effects Library panel on the left side (click the Effects icon or press Shift+8).
  1. Search for “Noise Reduction” in the search bar.
  1. Drag the Noise Reduction plugin onto the audio clip or the track header.
  1. The plugin window will open. Before adjusting sliders, locate a section of your audio that contains only wind noise and no dialogue — ideally 0.5 to 1 second long.
  2. Play that section and click the Learn button inside the plugin to let it sample the noise profile.
  1. Once the print is captured, stop playback and click Learn again to lock the profile.
  2. Play a section with dialogue and wind together. Gradually increase the Reduction amount until the wind drops, then back off slightly.
  3. Adjust the Threshold slider so the plugin only activates on louder wind bursts rather than processing the entire track continuously.
Tuning guidance: The most common mistake here is over-processing. If the voice starts to sound watery, bubbly, or robotic, the Reduction amount is set too high. A setting between 40–65% Reduction is a reasonable starting range for most wind recordings. Aim for the lowest Reduction value that still makes dialogue clearly intelligible.
Noise Reduction vs. De-Hum: Don’t Confuse the Two
The Fairlight Effects Library also contains a De-Hum plugin, which targets a fixed electrical hum at 50 or 60 Hz and its harmonics. De-Hum is the correct tool for buzzing from fluorescent lighting or power interference. For wind noise, use the Noise Reduction plugin.
Method 3: Fine-Tune with Parametric EQ Notching
After applying a high-pass filter and the Noise Reduction plugin, residual wind turbulence sometimes lingers in the 200–600 Hz range as a dull, muffled quality layered under dialogue. Parametric EQ notching is the finishing pass that addresses this.
Steps:
  1. Return to the EQ or open a Parametric Equalizer plugin on the track.
Note: Do not get confused with the term “Parametric Equalizer.” It is not a separate plug-in but another name for the same “6 Band” built-in equalizer in Davinci Resolve.
  1. Select a Bell (peak/notch) band and narrow the Q value to create a tight, focused cut.
  2. Reduce the band’s gain by about -6 dB temporarily to hear the band clearly.
  3. Sweep the center frequency slowly through the 200–600 Hz range while listening.
  1. Stop at any frequency where the muffled, boxy quality peaks.
  2. Set your final cut to -3 to -6 dB at that frequency.
  3. Repeat with a second band if needed.
Common problem frequency ranges for residual wind artifacts:
  • 200–300 Hz: Low-mid boxy or boomy quality
  • 300–500 Hz: Thick, muffled turbulence covering vocal clarity
  • 500–600 Hz: Remaining upper warmth from mid-range gusts
Keep all cuts moderate. Aggressive notching in this range will thin out vocal warmth and make the voice sound unnatural.
Free Version vs. DaVinci Resolve Studio: What You Can and Can’t Do
Both of the core wind removal methods in this guide are available at no cost. Here is a quick reference for what each version supports:
Feature
Free Version
Studio Version
Fairlight EQ (High-Pass Filter)
Yes
Yes
Yes
Yes
Parametric EQ
Yes
Yes
Spectral Recovery
No
Yes
Third-Party VST Plugin Support
No
Yes
Spectral Recovery (Studio only) is worth noting for worst-case recordings where wind has completely saturated the audio signal. It attempts to reconstruct frequencies that were clipped or masked, though it works best as a complement to the methods above rather than a replacement. Third-party VST support in Studio also opens the door to more specialized tools if the built-in options fall short.
How to Avoid Wind Noise Before It Reaches Post-Production?
The most reliable way to handle wind noise is to reduce it at the recording stage. Physical solutions like a dead cat windshield or a foam windscreen absorb turbulent air before it reaches the capsule and are inexpensive additions to any outdoor kit. Positioning also helps: turning the microphone slightly away from the wind direction, or recording with the subject’s body blocking the mic from the wind, can reduce severity significantly.
For vloggers, travel creators, and outdoor shooters, the microphone choice matters the most. Conditions outside can change quickly and audio suffers easily. Wind noise is one of the most common issues in such recordings. Fixing it later in editing rarely gives clean results. A wireless mic with built-in noise cancellation helps reduce that problem during recording itself. The Hollyland LARK MAX 2 applies AI Noise Cancellation at capture alongside 48 kHz / 32-bit Float audio, which means wind artifacts are far less severe before they ever reach DaVinci Resolve. For active and sports shooting, the Hollyland LARK M2S — a 7g clip-on with a titanium build designed for movement — is purpose-built for exactly the environments where wind damage is most common.
Q: Why does my wind noise removal sound robotic or watery in DaVinci Resolve?
This is a sign of over-processing. Lower the Noise Reduction plugin’s Reduction amount and raise the Threshold so the plugin only targets the loudest wind bursts rather than processing the full audio signal continuously. Small adjustments make a significant difference. Aim for the minimum Reduction level that still makes dialogue clearly understandable.
Q: Can I remove wind noise from video clips directly in the Edit page, without going to Fairlight?
Partially. The Inspector panel in the Edit page includes a basic audio EQ that can apply a low-cut filter to reduce rumble. However, the full Noise Reduction plugin is only accessible inside the Fairlight page, where you also get more precise control over the cutoff frequency, slope, and reduction amount.
Q: Does DaVinci Resolve have a dedicated wind noise removal tool?
No dedicated one-click solution exists in DaVinci Resolve. The most effective results come from combining the Low-Cut EQ filter with the Noise Reduction plugin, as covered in Methods 1 and 2 above. For the most damaged recordings, adding parametric EQ notching as a final pass gives you the best chance of restoring dialogue clarity.
Start with a high-pass filter to remove low rumble. Next, capture a noise print for wind reduction. Apply Noise Reduction plugin to reduce broadband wind noise. Use parametric EQ (6-band Equalizer) notching to clear mid-range turbulence. Light wind often needs only high-pass filter applied. Heavy outdoor audio needs all three steps in order.. From here, similar Fairlight techniques apply to dialogue cleanup and room tone replacement if your audio needs further restoration.
