DaVinci Resolve includes a set of AI-powered voice tools that most editors never find because they live inside the Fairlight audio module, not the Edit page. Whether you are cleaning up noisy dialogue, extracting speech from a busy background, or shifting a voice’s pitch for a creative effect, the right tool likely exists natively in Resolve. This guide walks through every AI voice feature, where to find it, and how to use it step by step.
What “AI Voice Convert” Actually Means in DaVinci Resolve
“AI voice convert” is a broad search term that maps to several distinct features inside DaVinci Resolve, and conflating them leads to a lot of frustration. Here is what each term actually refers to:
Voice Isolation uses a neural network to strip ambient noise and background sound and extract clean dialogue.
AI Noise Reduction removes a consistent broadband noise floor, such as hiss, hum, or room tone, through machine learning analysis.
Pitch Shifting and Formant Control alters voice character for stylistic or creative transformation.
Voice cloning or identity conversion (converting one person’s voice to another’s) is not available natively in DaVinci Resolve at all.
Every AI voice tool lives exclusively on the Fairlight page. They are not accessible from the Edit page timeline or the Inspector panel. If you cannot find them, that is almost certainly the reason.
Free vs. Studio availability at a glance:
Feature |
Free Version |
Voice Isolation (AI) |
Not available |
Available |
AI Noise Reduction |
Not available |
Available |
Pitch Shifter (FX) |
Available |
Available |
Full Fairlight FX Library |
Limited |
Full access |
Speech-to-Text Transcription |
Limited |
Full feature |
If you are on the free version and need Voice Isolation, a third-party VST plugin is the most practical workaround.
Key AI Voice Tools Available in DaVinci Resolve
Fairlight hosts four AI-adjacent voice tools. Each serves a distinct role in the dialogue post-production chain.
Voice Isolation
Voice Isolation uses a neural network to separate spoken dialogue from everything else in a recording, including music, crowd noise, HVAC hum, and reverb. It is the most searched feature in this category and the closest Resolve gets to true AI voice cleanup. A Studio license is required.
AI Noise Reduction
AI Noise Reduction targets a consistent broadband noise floor rather than complex mixed backgrounds. It complements Voice Isolation well: apply Noise Reduction first to flatten the floor, then use Voice Isolation to extract the dialogue cleanly. Also Studio-only.
Pitch Shifter and Voice Transformation Effects
The Fairlight FX chain includes a Pitch Modifier that adjusts pitch and formant values independently. This is where stylistic voice transformation happens natively: lowering pitch for a deeper voice, raising it for a lighter tone, or combining extreme settings with reverb and modulation for robotic or character voice effects. Available in both free and Studio versions.
Auto Transcription / Speech Recognition
Speech-to-text transcription is a separate AI voice workflow in Resolve. It converts audio to a text transcript for subtitle generation and rough-cut navigation, but it does not modify or transform the voice audio itself. Do not confuse it with voice conversion.
Step-by-Step: How to Use Voice Isolation in DaVinci Resolve
Studio License Required: Voice Isolation is only available in DaVinci Resolve Studio. If you are running the free version, you will not see it in the Resolve FX library. Jump to the next section for pitch tools available to all users.
Step 1: Open the Fairlight page and add the clip. Click the Fairlight icon in the bottom navigation bar. Click the clip you want to process.
Step 2: Make sure Vocal Isolation is visible. Click the three-dot icon beside the “Mixer” label to reveal the submenu. Go to Visible Track FX and check Voice Isolation.
Step 3: Apply the Voice Isolation Effect. Select the target clip, then hover over the “Voice Iso” tab until a dot appears. Click on it to activate; it will turn into yellow text.
Step 4: Configure the Isolation Strength slider. The primary control runs from 0 to 100. Start between 50 and 70 rather than jumping straight to 100. High values aggressively suppress all non-voice content, which introduces a hollow, over-processed quality when too much source room tone is present.
Step 5: Preview and handle render cache if needed. Press play to monitor the result. If playback stutters, go to Playback > Render Cache > User and right-click the clip to force a render. Voice Isolation is processor-intensive and may not play smoothly in real time on all systems.
Step 6: Finalize and export. Once the result sounds right, export normally through the Deliver page. The processed audio is baked into the output automatically.
Step-by-Step: Converting and Transforming Voice Characteristics
For stylistic voice transformation, including pitch changes, deepened character voices, or robotic effects, the Fairlight Pitch Modifier is the right tool. This workflow works in both the free and Studio versions.
Step 1: Select the audio clip in the Fairlight timeline. Click the specific clip you want to modify. Applying the effect at the clip level gives you precise per-clip control rather than affecting the entire track.
Step 2: Open the FX panel and navigate to Pitch Modifier. Open the FX panel by clicking on the “+” icon. After that, select Pitch > Pitch.
Step 3: Adjust Semi-Tones, Cents, and Mix settings. Either turn the control knobs or edit the raw value at the bottom.
Semi-Tones shifts the tonal frequency in whole-step increments. A setting of -3 to -5 semitones produces a noticeably deeper voice.
Cents allows fine-tuning between semitones (100 cents equals one semitone). Use this for subtle adjustments after dialing in the rough semitone value.
Wet/Dry Mix blends the processed and dry signals. Keep it below 80% for natural-sounding results.
Step 4: Layer additional FX for creative effects. For robotic or otherworldly character voices, stack a Ring Modulator or Modulation effect after the Pitch Modifier in the FX chain. Add light reverb to blend the result into the scene. Note that full voice identity conversion, converting one person’s voice to match another person’s, requires dedicated external AI software and is beyond what Resolve handles natively.
Tips for Getting the Best AI Voice Conversion Results
Start with the cleanest source audio you can get. AI processing works significantly better on low-noise recordings. Using a high-fidelity wireless mic like the Hollyland LARK MAX 2 (48 kHz / 32-bit Float capture with built-in AI Noise Cancellation) reduces the correction burden on DaVinci Resolve’s Voice Isolation before post begins.
Apply Voice Isolation before pitch or formant tools. Always sequence cleanup first, transformation second. Pitch-shifting a dirty recording creates artifacts that no downstream processing can fully remove.
Apply effects at the clip level when possible. Target only the sections that need correction rather than blanketing an entire track, which preserves natural dynamics in clean passages.
Export an intermediate stem before heavy processing. Bounce a clean audio file before committing to high Isolation Strength values. If the result introduces artifacts, you have a recovery point.
Match your project sample rate to the source file. A 44.1 kHz file in a 48 kHz project creates subtle pitch drift that compounds during AI processing. Confirm settings under Fairlight > Project Settings > Master Settings before starting.
Limitations to Know Before You Start
Voice Isolation is a dialogue extraction tool, not a voice cloning engine. It cannot convert a female voice to a male voice, replicate another speaker’s identity, or perform any identity-level transformation. The Pitch Modifier handles stylistic shifts, but realistic voice identity conversion requires external AI plugins or standalone software.
Both Voice Isolation and AI Noise Reduction are locked behind a DaVinci Resolve Studio license. Free-version users should evaluate third-party VSTs such as iZotope RX, Waves Clarity Vx, or NVIDIA RTX Voice, all of which integrate into Fairlight’s VST chain.
Heavy AI processing often requires rendering for smooth playback, so factor that into deadline-driven workflows. Finally, pushing Isolation Strength to 100% on already-decent recordings typically degrades quality more than it helps. Treat Voice Isolation as a corrective tool, not a substitute for good recording practice.
Is AI Voice Isolation free in DaVinci Resolve?
Voice Isolation requires DaVinci Resolve Studio (the paid version). The free version includes the Pitch Shifter FX and basic audio tools, but AI-driven Voice Isolation and AI Noise Reduction are Studio-only features. If you need these capabilities on the free tier, third-party VST plugins integrated through Fairlight are the most viable workaround.
Can DaVinci Resolve change one person’s voice to sound like another person?
No. Resolve’s native tools support pitch and formant shifting for stylistic transformation, but they cannot replicate another speaker’s vocal identity. Voice cloning and voice-to-voice conversion require dedicated AI software or third-party plugins that operate outside of Resolve’s native feature set.
Where is the voice conversion tool in DaVinci Resolve?
All AI voice tools are on the Fairlight page, inside the Audio FX panel on the channel strip. Go to Resolve FX > Restoration for Voice Isolation and AI Noise Reduction, or Resolve FX > Audio for the Pitch Modifier. These tools are not accessible from the Edit page timeline.
Why does Voice Isolation degrade the audio quality?
The most common cause is pushing Isolation Strength too high too fast. Start the slider at 50 to 70 percent, preview the result, and increase gradually. Over-application introduces a hollow, watery quality. Clean source audio also significantly improves output at any strength level.
Does DaVinci Resolve have a voice changer for real-time use during recording?
No. Fairlight’s AI effects are post-production tools applied to recorded audio in the timeline. DaVinci Resolve does not function as a real-time voice monitoring chain during recording. For live voice transformation, a dedicated hardware or software voice processor outside of Resolve is required.
What to Do Next
DaVinci Resolve’s AI voice workflow follows a clear two-stage structure: use Voice Isolation and AI Noise Reduction in Fairlight for dialogue cleanup, then apply the Pitch Modifier and formant controls for stylistic transformation. Both stages work within a single FX chain on the same track. If your project requires voice identity conversion or real-time effects beyond what Resolve handles natively, integrating a third-party VST plugin through Fairlight’s FX browser is the logical next step.
