How to Connect a Microphone to a MacBook: Every Method Explained
Getting a microphone working on a MacBook comes down to two things. One is the connector type on your microphone, and the other is the MacBook port. Whether you’re connecting a USB condenser mic, a wireless lavalier system, or a professional XLR mic through an audio interface, each method has a specific setup path. This guide walks through every connection method step by step, then covers how to select and verify your mic in macOS.
Before You Start — Know Your MacBook’s Ports and Your Mic’s Connection Type
Before picking a method, confirm what you’re working with on both sides.
Your MacBook’s ports:
  • USB-C ports are found on all MacBook models from 2016 onward. Whereas the Thunderbolt support changes depending on the specific model.
  • 3.5mm combo headphone/microphone jack (present on many models; absent on some MacBook Pro configurations)
  • MagSafe charging port (power only — not relevant for audio)
Your mic’s connector type:
  • USB-A (older USB mics)
  • USB-C (connects directly to any MacBook port)
  • XLR (requires a separate audio interface)
  • 3.5mm TRRS or TRS plug
  • Wireless USB receiver (USB-C or USB-A dongle)
  • Bluetooth
Note: If your USB mic uses a USB-A connector, a simple USB-A to USB-C adapter is all you need to connect it to any modern MacBook. No drivers or additional software are required.
Method 1 — Connect a USB Microphone to Your MacBook
USB microphones are the easiest option for MacBook users. Most follow USB Audio Class rules, so macOS detects them without needing extra drivers.
Option A: USB-A mic with a USB-C adapter
  1. Plug a USB-A to USB-C adapter into one of your MacBook’s USB-C or Thunderbolt ports.
  1. Connect the USB-A end of your microphone cable to the adapter.
If the mic has a power-on indicator LED, it should now turn on.
  1. Wait a few seconds for macOS to detect the device.
  2. Open System Settings > Sound > Input (macOS Ventura 13 and later) or System Preferences > Sound > Input (macOS Monterey 12 and earlier).
  1. Locate your microphone by name in the input device list and click it to select it.
  2. Speak into the mic and watch the Input Level meter — the bars should animate in response to your voice.
Option B: USB-C mic (direct connection)
  1. Plug the USB-C end of your microphone cable directly into any USB-C or Thunderbolt port on your MacBook.
  2. Open System Settings > Sound > Input.
  1. Select your microphone by name from the input device list.
  2. Confirm the signal by checking the Input Level meter.
Note: macOS does not always switch automatically to a newly connected microphone. If your mic connects but the input list still shows “MacBook Microphone” as active, click your external mic’s name in System Settings to manually switch.
Method 2 — Connect a Wireless Microphone via USB Receiver (Hollyland LARK MAX 2 Walkthrough)
Wireless microphone systems that include a USB receiver offer one of the cleanest setups for MacBook users — no driver installation, no audio interface, and no extra software required. The following steps use the Hollyland LARK MAX 2 as the demonstration subject. Its USB-C receiver plugs directly into your MacBook, and macOS treats it as a standard USB audio input device from the moment it is inserted.
  1. Insert the USB-C receiver. Plug the LARK MAX 2’s USB-C receiver into any USB-C or Thunderbolt port on your MacBook. The receiver LED will light up to confirm it has power.
  1. Power on the transmitter. Press and hold the power button for 3 seconds on the LARK MAX 2 transmitter until the LED activates. The LED will flash during the initial pairing search phase.
  1. Confirm the pairing state. Watch the transmitter LED — it transitions from flashing blue (searching) to solid blue (paired). The receiver LED will mirror this state. When both LEDs show solid, the wireless link is established.
  2. Let macOS detect the device. Within a few seconds of receiver insertion, macOS automatically recognizes the LARK MAX 2 as a USB audio input device. No driver installation prompt will appear.
  3. Select the input in System Settings. Open System Settings > Sound > Input. You will see “LARK MAX 2” listed as an available device. Click it to set it as the active input.
  4. Verify the signal. Speak or make a sound near the transmitter’s microphone capsule. The Input Level bars in System Settings should animate in real time, confirming the signal is passing through.
  1. Adjust input gain. Use the Input Volume slider beneath the device list to set gain. Start at around 70% and adjust based on the meter response to your voice.
  2. Enable AI Noise Cancellation (optional). Press the dedicated noise cancellation button on the LARK MAX 2 transmitter.
Or open the Hollyland companion app (HollyAudio/LarkSound) and toggle AI Noise Cancellation on. An LED indicator on the transmitter, or the app interface, will confirm when the feature is active.
  1. Monitor audio in real time via OWS earphones. Connect the included OWS earphones wirelessly with LARK MAX 2. These provide low-latency monitoring so you can hear your input audio in real time while recording, useful for catching any issues before they reach your final file.
32-bit Float Internal Recording: The LARK MAX 2 simultaneously records audio to its onboard storage at 32-bit Float resolution, entirely independent of your MacBook connection. This backup recording captures every take, even if a wireless dropout or software crash interrupts the main session. After recording, retrieve this file from the transmitter as a safety net.
For vloggers and compact travel setups: The Hollyland LARK M2 uses the same plug-and-play USB receiver workflow in a noticeably smaller form factor. If minimal gear weight is a priority for run-and-gun shooting or travel content, the LARK M2 follows every step above with no meaningful difference in the macOS setup process.
Method 3 — Connect an XLR Microphone via an Audio Interface
XLR microphones do not connect to a MacBook directly. A USB audio interface is required to bridge the XLR signal and your MacBook’s USB-C port.
  1. Connect the XLR mic to the interface. Plug the XLR cable from your microphone into the XLR combo input on your audio interface.
  2. Connect the interface to your MacBook. Use a USB-C to USB-C cable, or a USB-A to USB-C adapter if your interface has a USB-A cable. Plug into any USB-C or Thunderbolt port.
  3. Wait for macOS to recognize the interface. macOS will detect it as a USB audio device and list it in System Settings by its interface model name — for example, “Focusrite USB Audio” or “Scarlett Solo USB” — not by the microphone’s name.
  4. Open System Settings > Sound > Input and click the interface name to select it as the active input.
  5. Set the gain on the interface hardware. Use the gain knob on the interface’s front panel. Watch the Input Level meter in macOS to gauge the level.
Note on phantom power: Condenser microphones require phantom power (+48V) supplied by the interface. Look for a “48V” or “Phantom Power” button on your interface and enable it before recording. Dynamic microphones do not need phantom power and should work immediately after the gain is set.
Method 4 — Connect a 3.5mm Microphone to a MacBook
Some MacBook models include a 3.5mm combo jack that supports both headphone output and microphone input on a single port. Before plugging in, check your connector type:
  • TRRS connector (four-band plug): carries both mic and audio signals. Plugs directly into the combo jack and is recognized immediately.
  • TRS connector (three-band plug): carries audio only. Requires a TRRS splitter adapter to separate the microphone and headphone signals before connecting.
Once plugged in, open System Settings > Sound > Input and select the 3.5mm input from the device list. Keep in mind that many MacBook Pro and MacBook Air models released from 2019 onward no longer include this port. If yours does not, a USB adapter or wireless USB receiver is the more practical path forward.
Method 5 — Connect a Bluetooth Microphone to a MacBook
  1. Open System Settings > Bluetooth and confirm Bluetooth is turned on.
  2. Put your Bluetooth microphone into pairing mode (refer to your mic’s documentation for the specific button sequence).
  3. Select the device from the discovered devices list and click Connect.
  4. After pairing completes, open System Settings > Sound > Input and select the Bluetooth device from the input list.
Note: macOS Bluetooth audio input uses the SCO or mSBC codec by default, which delivers mono, compressed audio at reduced quality. This is acceptable for voice calls and conference meetings, but is not suitable for podcasting, video production, or any recording where audio fidelity matters. For content creation, use a USB or wireless USB receiver connection method instead.
How to Select and Configure Your Microphone as the Active Input in macOS?
No matter which connection method you use, this step stays the same for everyone. Plugging in a microphone does not mean macOS will pick it automatically. You must select it yourself in the settings.
Selecting and verifying the active input:
  1. Click the Apple menu and open System Settings (macOS Ventura 13+) or System Preferences (macOS Monterey 12 and earlier).
  2. Click Sound, then select the Input tab.
  3. Review the list of available audio input devices. Click your microphone or audio interface name to make it the active input.
  4. Speak into your microphone and watch the Input Level meter. Moving bars confirm that the signal is reaching macOS from the correct device.
  5. Use the Input Volume slider to set the capture level. A starting point of 60 to 80% works well for most setups — adjust based on how the level meter responds.
Note: macOS does not automatically switch the active input device every time a new mic is plugged in. Always return to System Settings after connecting a new microphone to verify the selection has updated correctly.
Advanced configuration with Audio MIDI Setup:
For users who need to set a specific sample rate (such as 48 kHz to match a video project) or combine two audio inputs into one virtual device, open Audio MIDI Setup via Applications > Utilities. You can adjust per-device format settings here, or click the “+” button at the bottom-left to create an Aggregate Device that merges multiple inputs. This goes beyond basic mic setup but is useful for more complex recording workflows.
How to Test Your Microphone Is Working on a MacBook?
Once your microphone is selected in System Settings, use either of these quick methods to confirm it is capturing audio correctly before you start a session.
QuickTime Player Recording Test
  1. Open QuickTime Player from your Applications folder or via Spotlight.
  2. Go to File > New Audio Recording.
  1. Click the small arrow next to the record button to open the input selector dropdown. Choose your microphone from the list.
  2. Press the record button and speak for five to ten seconds.
  3. Stop the recording and play it back. Clear audio confirms the microphone is configured and working correctly.
Troubleshooting — MacBook Not Recognizing Your Microphone
  • Mic not appearing in the System Settings input list: Use another USB-C port on the MacBook directly. Remove and reconnect the cable, or try a different one. If you are connecting through a USB hub or dock, bypass it and connect the mic or receiver directly to the MacBook. Restart the mic or receiver and wait for macOS to re-detect the device.
  • Mic is listed in System Settings, but the Input Level meter shows no movement: Check for a physical mute button on the microphone body and confirm it is not engaged. Make sure the Input Volume slider is not set to zero. Test with a louder sound source close to the capsule.
  • Wireless USB receiver not detected by macOS: Connect the receiver directly to a USB-C port on the MacBook rather than through a hub or dock. Some receivers require a direct connection to enumerate correctly as a USB audio device.
  • LARK MAX 2 specific: If the receiver LED is flashing rather than showing a solid state, the transmitter has not paired successfully. Power the transmitter on and wait for both LEDs to go solid before opening System Settings. A flashing LED on either unit indicates an unresolved pairing state.
  • To manually re-pair the LARK MAX 2, first turn off the receiver and transmitters. Then, press and hold the pairing button (functions via the power button) for 6 seconds on the transmitter until the LED begins flashing. Bring the transmitter close to the receiver. Do the same with the receiver. When both LEDs return to solid blue, the link is restored.
  • macOS keeps reverting to the built-in microphone after restart or between sessions: After selecting your external mic in System Settings, also check the audio preferences inside each app you use for calls or recording. Browsers, Zoom, Teams, and similar tools maintain their own audio input settings that can override the System Settings selection independently.
Does MacBook have a built-in microphone input for XLR mics?
No. MacBook does not include an XLR input. XLR microphones require a separate USB audio interface connected to your MacBook via USB-C. The interface provides the XLR input, handles analog-to-digital conversion, supplies phantom power for condenser mics when needed, and appears in macOS as a USB audio device.
Can I use a wireless lavalier mic directly with my MacBook?
Yes, provided the wireless system includes a USB or USB-C receiver dongle. The Hollyland LARK MAX 2, for example, uses a USB-C receiver that macOS recognizes as a plug-and-play audio input device within seconds of insertion. No driver installation is required, and it appears in System Settings > Sound > Input immediately.
Why does my MacBook keep switching back to the built-in microphone?
The most common cause is app-level audio settings. Browsers, video conferencing tools, and some DAWs maintain their own input device preferences that override macOS System Settings. Open the audio or device settings within the specific app and manually select your external microphone there, in addition to setting it in System Settings.
Do I need to install drivers to connect a USB microphone to a MacBook?
In almost all cases, no. Most USB microphones are USB Audio Class compliant, and macOS recognizes them automatically on connection. Exceptions are rare and will be explicitly documented in the manufacturer’s packaging or product documentation. If no driver notice appears, your mic is working as plug-and-play.
Can I record from two microphones at the same time on a MacBook?
Yes. Open Audio MIDI Setup via Applications > Utilities, click the “+” button, and select Create Aggregate Device. Check the boxes next to each microphone you want to combine. The Aggregate Device will then appear in any recording app’s input selector as a single virtual device capturing both sources simultaneously.
The correct connection method depends on your microphone type. USB mics connect directly or through an adapter. XLR microphones require an external audio interface device. Wireless systems use a dedicated USB receiver device. Bluetooth works for casual calls and simple recording only. After connecting, confirm the selection in System Settings Sound Input. Then check the input level meter before recording.
