Connecting a microphone and hearing nothing can feel really annoying. Many people face this issue during remote work or home recordings. The setup usually has three main parts. First, connect the microphone to your computer correctly. Next, choose the right input device in your system settings. Then, pick the microphone inside the app you want. Missing even one step often causes sound problems. This guide explains every stage for Windows and macOS systems. It also uses the Hollyland LARK MAX 2 wireless microphone throughout.
Types of Microphones You Can Use on a Computer
Before connecting anything, identify which type of microphone you have so you can follow the correct path below.
USB microphone: Connects directly to any USB-A or USB-C port. Plug-and-play on both Windows and macOS, with no drivers required in most cases. Well suited for desktop recording, podcasting, and voice calls.
3.5mm / TRRS microphone: Plugs into your computer’s headphone jack if that port supports both audio input and output (a combo TRRS jack). Requires a TRRS splitter adapter on machines with separate headphone and microphone ports.
Wireless microphone with USB receiver: The transmitter clips to your clothing and broadcasts wirelessly to a USB receiver plugged into your computer. The receiver appears to the OS as a standard USB audio device. This guide uses the Hollyland LARK MAX 2 as the step-level demonstration for this connection type. Readers using compact clip-on mics for vlogging or travel, such as the Hollyland LARK M2 or LARK M2S, follow the same USB receiver workflow.
How to Connect Your Microphone to a Computer?
Connecting a USB Microphone
Locate an open USB-A or USB-C port directly on your computer chassis. Avoid USB hubs for the initial connection test.
Insert the microphone’s USB cable or the microphone itself if it has a built-in connector.
Wait 5 to 10 seconds. Windows will display a brief notification that a new audio device has been detected. On macOS, the device appears immediately in System Settings without a separate prompt.
Confirm recognition: On Windows, right-click the speaker icon in the taskbar and open Sound Settings.
On macOS, open System Settings > Sound > Input. Your USB microphone should appear in the input device list.
No driver installation is required on Windows 10/11 or macOS Monterey and later for standard USB audio class devices.
Connecting a 3.5mm Microphone
Inspect your laptop’s audio port. A single port with a headset icon supports both headphones and microphone through a TRRS connector. Two separate ports (one for headphones, one for a microphone) require separate plugs.
If your microphone has a standard 3.5mm TRS plug and your laptop has a single TRRS combo jack, use a TRRS-to-dual-TRS splitter adapter. Plug the microphone into the adapter’s microphone input and the adapter into the laptop port.
If your laptop has separate ports, plug the microphone directly into the dedicated microphone input, usually marked with a small microphone symbol or colored pink.
Open your OS sound settings and check the Input device list to confirm detection.
Note: Some thin ultrabooks have removed the 3.5mm jack entirely. If yours has only USB or USB-C ports, a USB microphone or a wireless mic with a USB receiver is the simpler path forward.
Connecting a Wireless Microphone: Hollyland LARK MAX 2 Walkthrough
Insert the USB receiver. Plug the LARK MAX 2 USB-C receiver into a direct USB port on your computer. Avoid USB hubs for the initial setup, since unpowered hubs may not supply enough current for reliable audio device enumeration.
Power on the transmitter. Press and hold the power button on the LARK MAX 2 transmitter until the LED activates. The LED will blink during the startup and searching phase.
Confirm pairing. Watch the LED indicators on both the transmitter and the USB receiver. A solid blue LED on both units indicates that they have successfully linked. A still-blinking LED means the devices are still searching for each other; wait a few more seconds or move them closer together.
Check OS detection. Once paired, Windows or macOS will recognize the USB receiver as a new audio input device. On Windows, you may see a brief notification in the system tray. On macOS, the device appears in the Input list in System Settings without any additional prompt.
Learn the mute toggle. Double-press the power button on the transmitter or USB-C receiver to mute or unmute. When the mic is muted, the LED indicator light will turn to solid red. Familiarize yourself with this indicator before entering OS settings, because a muted transmitter will show no input signal at the OS level, regardless of any other configuration.
How to Set Your Microphone as the Default Input on Windows?
Plugging in the microphone alone will not make it active. Windows also needs the correct input device selected manually.
Open Settings (Windows key + I) and navigate to System > Sound.
Under the Input section, click the dropdown labeled Choose your input device and select your microphone from the list. For the LARK MAX 2, this will appear as a “USB Audio Device” or under a Hollyland device name; confirm the exact label displayed on your machine.
Speak into the microphone and watch the Test your microphone bar below the dropdown. The bar should move in response to your voice, confirming an active signal.
If you have multiple audio devices and want all apps to default to this microphone, click the device name to open its properties and confirm it is set as the default communication device.
Enable microphone privacy permissions. Go to Settings > Privacy > Microphone. Confirm that Microphone access is turned on and that Allow apps to access your microphone is also toggled on. Individual apps can be toggled on or off in the list below. If this permission is off, your microphone will produce no signal inside any app even if it is correctly selected in Sound Settings.
How to Set Your Microphone as the Default Input on Mac?
Open System Settings (macOS Ventura or later) and click Sound in the sidebar.
Select the Input tab.
Click your microphone in the device list. For the LARK MAX 2, it will appear by its USB device name once the receiver is connected and the transmitter is paired.
Drag the Input volume slider to roughly 70 to 80 percent as a starting point. You can fine-tune this after testing.
Speak into the microphone and watch the Input Level meter below the slider. The meter bars should respond to your voice in real time. If the LARK MAX 2 transmitter is paired and not muted, this real-time response is the visual confirmation that both the hardware connection and OS recognition are working correctly.
Enable microphone privacy permissions on macOS. Go to System Settings > Privacy & Security > Microphone. Ensure that any app you plan to use is listed and toggled on. On first launch, macOS will prompt you to grant permission automatically; click Allow when that dialog appears.
Note: On macOS Monterey or earlier, the equivalent path is Apple menu > System Preferences > Sound > Input tab. The steps are otherwise identical.
How to Test Your Microphone and Adjust Input Levels?
Quick OS-Level Recording Test
Before opening any specific app, run a brief record-and-playback test to confirm everything is working at the system level.
On Windows: Open Sound Recorder (search for it in the Start menu; it may appear as “Voice Recorder” on Windows 10). Click the record button, speak for a few seconds, stop, and play back.
On macOS: Open QuickTime Player, go to File > New Audio Recording, click the small dropdown arrow next to the record button, select your microphone from the list, then record and play back a few seconds of audio.
The Voice Memos app works equally well for a quick check.
Understanding the Input Level Issues
Too high: The input signal clips, producing a harsh distortion that cannot be corrected after the fact.
Too low: Amplifying the recording later also raises background noise and hiss to unacceptable levels.
Aim for a level where normal speech peaks around -12 dB to -6 dB in a recording app, giving you headroom without dropping into the noise floor.
Adjusting Levels on the Hollyland LARK MAX 2
The LARK MAX 2 provides hardware-level controls before the signal ever reaches your computer:
Gain control: Use the HollyAudio app (popularly known as the LarkSound app) to adjust gain levels.
Or, you can use the camera receiver to tweak gain settings. The built-in display confirms the current level visually, so you can verify it without opening any software.
AI Noise Cancellation: Press the designated button on the LARK MAX 2 to toggle AI Noise Cancellation on or off. A green LED indicator confirms when the feature is active. Because this processing happens on thesystem itself, it reduces background noise before the audio signal reaches your OS or recording app.
32-bit Float Internal Recording: The LARK MAX 2 keeps a backup recording inside its own memory. It saves audio in 32-bit float format. This format avoids clipping no matter the gain level. It helps protect your audio if system gain settings are wrong during recording. To access these files, connect the receiver or transmitter to a computer via USB-C cable for transfer.
OWS earphone monitoring: If you have connected the LARK MAX 2’s OWS earphones via Bluetooth or 2.4GHz modes, you can hear the speaker in real-time with zero latency.
How to Select Your Microphone Inside Specific Apps?
The OS default input tells the system which microphone to use, but many applications maintain their own independent audio settings. If an app was already open when you connected your microphone, or if it previously saved a different device, it will ignore the OS default until you update it manually. Set the device inside each app separately.
Video Calls: Zoom
Open Zoom and click your profile icon in the top-right corner, then select Settings.
Go to the Audio tab.
Under Microphone, open the dropdown and select your device. The LARK MAX 2 will appear by its USB device label.
Click Test Mic to record a short clip and play it back inside Zoom. This is the most reliable in-app confirmation that signal is passing correctly.
Adjust the Input Level slider within Zoom’s Audio settings if the level is too quiet or too loud relative to your hardware gain setting.
Note: Google Meet and Microsoft Teams follow a nearly identical path. Click the settings or gear icon, navigate to the Audio or Devices section, and select your microphone from the dropdown.
Streaming: OBS Studio
Open OBS Studio and go to Settings > Audio.
Under Global Audio Devices, find the Mic/Auxiliary Audio dropdown and select your microphone from the list.
Click OK to save.
Back in the main OBS window, locate the Audio Mixer panel. Your microphone should now appear as an active channel. Speak into the mic and watch the level meter respond to confirm that the signal is reaching OBS.
Right-click the microphone channel in the Audio Mixer to add filters such as a noise gate or equalizer if needed.
Recording: Audacity
Open Audacity and go to Edit > Preferences.
Under the Recording section, open the Device dropdown and select your microphone. The LARK MAX 2 will appear by its USB device name.
Click OK, press record briefly, speak, then stop and play back to verify the signal.
Pro Tip: If you are using the LARK MAX 2’s OWS earphone monitoring for real-time feedback while recording in Audacity, leave Audacity’s Software Playthrough option turned off. Enabling hardware monitoring and software playthrough simultaneously will produce an echo in your headphones.
Microphone Not Working on Your Computer? Quick Fixes
If audio is not coming through after connecting your microphone, work through this list before digging deeper.
Wrong default input selected: Open Sound Settings on Windows or System Settings > Sound > Input on macOS and confirm your microphone is actively selected, not just listed.
OS privacy permission blocked: On Windows, check Settings > Privacy & Security > Microphone. On macOS, check System Settings > Privacy & Security > Microphone. A disabled toggle here silences all input regardless of any other setting.
App using a different input: Open the audio settings inside the specific app you are using and manually select your microphone there. The OS default does not always propagate automatically.
Loose cable or wrong port: For USB devices, try a different port directly on the computer chassis. For 3.5mm mics, confirm you are in the microphone input jack rather than the headphone output.
USB hub causing non-recognition: Unpowered hubs may not enumerate audio devices reliably. Connect the USB receiver directly to the computer and retry.
LARK MAX 2 transmitter not paired: If the transmitter LED is still blinking rather than showing a solid blue light, the receiver has not established a wireless link, and no audio will pass to the computer. Hold the pairing button on the receiver for 6 seconds and follow the re-pairing sequence until both LEDs show the solid paired state.
LARK MAX 2 battery low: The transmitter LED behavior changes at low battery. If the LED is flashing in an irregular pattern, check the battery status and recharge via USB-C before continuing.
Hardware mute active: The LARK MAX 2 transmitter’s mute feature will silence the microphone at the hardware level. Verify the LED confirms the mic is live before assuming a software problem.
Can I use a wireless microphone with a computer?
Yes. Wireless microphones that include a USB receiver connect to a computer like any other USB audio device. The Hollyland LARK MAX 2, for example, uses a compact USB receiver that Windows 10/11 and macOS Monterey and later recognize automatically as a standard audio input. No drivers or additional software installation is required.
Why is my microphone showing in settings but not capturing audio?
Several issues usually cause missing microphone sound in setups. Sometimes the device is not set as the default input. Apps may route audio to another input source instead. Also, check the hardware mute switch on the microphone before recording. Open app audio settings and confirm the correct device is selected.
How do I reduce background noise from my computer microphone?
Move the microphone physically closer to your mouth to improve the signal-to-noise ratio, and lower input gain slightly in your OS settings to reduce room noise pickup. If your microphone has onboard noise processing, use it. The LARK MAX 2’s AI Noise Cancellation filters background noise at the hardware level before the signal reaches your computer or any recording software.
Do I need an audio interface to use a professional microphone on a computer?
Only if your microphone has an XLR output. USB microphones and wireless mics with USB receivers connect directly to any computer without an interface. The LARK MAX 2 handles all analog-to-digital conversion internally through its USB receiver, so no external interface or additional hardware is required.
My laptop has only one 3.5mm port. Can I still use a microphone?
Yes. A single combo jack on a modern laptop typically supports both headphone output and microphone input through a TRRS connector. You will need a TRRS-to-dual-TRS splitter adapter if your microphone has a standard 3.5mm plug. Using a USB microphone or a wireless mic with a USB receiver bypasses this limitation entirely.
Microphone setup on a computer follows three main steps. First, plug in the microphone hardware. Next, choose it as the main input in your system settings. Then select it inside the application you are using. Many problems happen when that last step is ignored. After the microphone shows up in system sound settings, it is ready for recording, streaming, or calls.
