Getting your microphone connected to a camera for the first time can feel more complicated than it should. Between ports, cables, adapters, and camera menus, there are several places where things go wrong. This guide explains three main connection choices for setup. You can choose a wired 3.5mm, XLR adapter, or wireless receiver mounting. Follow the matching option and get clean audio into the camera within ten minutes.
Choose Your Connection Method First
Before you start plugging in any cable or adapter, first check your microphone and camera connection type. The table below shows each path with the needed hardware and directs you to the right section.
Connection Method |
Cable or Hardware Needed |
Mic Type |
Camera Requirement |
3.5mm Wired |
TRS 3.5mm cable |
On-camera shotgun, wired lavalier |
3.5mm mic input jack |
XLR Wired (via adapter) |
XLR-to-3.5mm adapter or inline preamp |
Condenser, large-diaphragm, dynamic studio mic |
3.5mm mic input + adapter; phantom power for condenser mics |
Wireless Receiver |
Wireless receiver + 3.5mm TRS output cable |
Wireless lavalier system (e.g., Hollyland LARK M2) |
Having everything within reach prevents mid-step delays.
For a wired connection:
Camera with a 3.5mm external mic input port
3.5mm TRS cable (not TRRS)
Cold shoe adapter if you plan to mount the mic on the camera body
XLR-to-3.5mm adapter or inline preamp if your mic uses an XLR connector
For a wireless connection:
Wireless mic system (receiver unit and transmitter clip-on unit)
Cold shoe adapter for mounting the receiver on the camera
3.5mm TRS cable (usually included with systems like the Hollyland LARK M2)
Fully charged receiver and transmitter
How to Mount a Microphone Physically on Your Camera?
Physical mounting comes before any cable connection. A loose or incorrectly seated mic introduces vibration noise and can stress the mic input port if the cable is pulled at an angle.
Locate the hot shoe on your camera. It sits on top of the camera body, typically above the viewfinder. It is the rectangular metal bracket with a center groove and locking channel.
Attach a cold shoe adapter if needed. If your hot shoe is occupied by a flash or optical viewfinder attachment, or if you need the mic positioned at a different angle, slide a cold shoe adapter into the hot shoe and tighten the locking screw. Cold shoe adapters are passive and work with any standard mic mount.
Slide the microphone or receiver mount onto the shoe. Most on-camera shotgun mics and wireless receivers include a standard shoe foot. Align the foot with the shoe groove and slide it forward until it stops against the locking block.
Tighten or lock the mount. Rotate the thumb screw or locking wheel on the mic mount until the unit is firm. Give it a gentle side-to-side test – it should not wobble.
Orient the cable port toward the camera body. Before finalizing the position, confirm that the mic’s output port faces downward or toward the camera’s mic input. This keeps cable routing clean and reduces connector strain.
Confirm stability before attaching the cable. A mic that shifts after cabling is connected puts lateral pressure on the camera’s 3.5mm port, which is a common cause of port damage over time.
Note: When mounting a Hollyland LARK M2 receiver, the compact puck-style body seats directly onto a cold shoe adapter. Position the receiver so its 3.5mm TRS output port faces toward the camera body, which allows the cable to route cleanly downward to the camera’s mic input without a sharp bend at the connector.
How to Connect a Wired Microphone to a Camera?
Connecting a 3.5mm Wired Mic
Identify the camera’s 3.5mm mic input port. It is usually marked with a microphone icon and is distinct from the headphone output port, which carries a headphone icon. Check your camera’s body diagram in the manual if both ports look identical.
Use a TRS cable, not a TRRS cable. TRS plugs have two black rings; TRRS plugs have three. Plugging a TRRS cable into a camera mic input can cause signal crosstalk, stereo channel imbalance, or no signal at all.
Plug the cable firmly into the camera mic input. Press until you feel or hear a small click. A partially seated plug is the most common cause of no audio after connection.
Connect the other end to the microphone’s output port. For on-camera shotgun mics with a cable socket, plug in the same way. For clip-on lavalier mics, the cable is typically fixed and runs directly from the mic capsule.
Navigate to the camera’s audio menu and confirm the external input is active. Most cameras default to internal audio. Switch the audio source to the external mic. On Sony cameras, this is found under Menu > Audio > Audio Input. On Canon, go to Menu > Audio > Sound Recording.
Speak into the mic and watch the camera’s audio level meters. The meters should move in response to your voice. If they stay flat, recheck the cable connection and the audio input setting.
TRS vs. TRRS: TRS stands for Tip-Ring-Sleeve and carries a mono or balanced stereo signal suited for camera mic inputs. TRRS adds a second Ring for a built-in microphone channel and is designed for smartphones and headsets. Using TRRS on a camera mic input frequently results in a dead left channel, phase issues, or a completely absent signal.
Connecting an XLR Microphone via Adapter
XLR microphones require either an XLR-to-3.5mm adapter or an inline preamp adapter to bridge the balanced XLR signal to your camera’s unbalanced 3.5mm input.
XLR Adapter Note: Condenser microphones require 48V phantom power to operate. Most basic XLR-to-3.5mm adapters do not supply phantom power. If your condenser mic needs it, use an active inline preamp adapter (such as the Rode VXLR+) that draws its own battery power and delivers 48V to the mic capsule. Dynamic XLR mics do not need phantom power and will work with a passive adapter.
How to Attach a Wireless Microphone to a Camera? (Step-by-Step with Hollyland LARK M2)
Wireless mic systems give speakers freedom of movement and eliminate camera-side cable management. The Hollyland LARK M2 is a compact dual-channel wireless lavalier system built for this exact camera-mount workflow. The receiver mounts on the camera hot shoe, the clip-on transmitter attaches to the speaker, and a single TRS cable bridges audio from the receiver to the camera. Every step below uses the LARK M2’s specific hardware and indicators.
Step 1: Mount the Receiver on the Camera Hot Shoe
Confirm a cold shoe adapter is seated on the camera’s hot shoe (or use the hot shoe directly if it is free).
Slide the LARK M2 receiver’s shoe foot into the cold shoe adapter and advance it fully forward until it stops.
Orient the receiver so its 3.5mm TRS output port faces toward the camera body for direct downward cable routing.
Step 2: Power On and Pair the Transmitter with the Receiver
Press and hold the power button on the receiver until its LED begins flashing. This signals it is searching for a transmitter.
Press and hold the power button on the transmitter until its LED also begins flashing.
Both LEDs will flash during the pairing search and turn solid blue once the connection is established. This typically takes 3 to 8 seconds.
If either LED remains flashing beyond approximately 10 seconds, power off both units. Power the receiver on first by pressing the power button for 6 seconds, and then repeat the same process with the transmitter. The units will search for each other and pair automatically.
Step 3: Connect the Receiver to the Camera’s Audio Input
Take the included 3.5mm TRS cable from the LARK M2 package.
Plug one end into the output port on the LARK M2 receiver (marked with a camera icon or “Out”).
Plug the other end into the camera’s 3.5mm external mic input port.
Press each plug firmly until fully seated. A partially inserted cable at either end is the leading cause of no audio at this stage.
The LARK M2 receiver outputs at mic level by default, which is correct for a camera’s mic input. If your camera offers a line-level input option, keep it set to mic level to match the receiver’s output.
Step 4: Clip the Transmitter onto the Speaker
Open the spring clip on the LARK M2 transmitter (9g) and attach it to the speaker’s lapel, collar, or shirt pocket approximately 15 to 20 centimeters below the chin.
Confirm the transmitter LED is solid blue. A steady blue indicator c confirms an active link to the receiver. A flashing LED means the transmitter is still searching – do not begin recording until both LEDs are solid.
Open the HollyAudio app (also known as the LarkSound app) on your smartphone and connect the Hollyland LARK M2. Choose Low, Medium, or High for the transmitter input level. Set the level that matches your recording environment best.
Turn on Environmental Noise Cancellation inside the app to reduce background sounds.
You can also press the yellow button on the transmitter or receiver.
Upgrading to the Hollyland LARK MAX 2 for Professional Use
For documentary, narrative, or interview work where a backup audio track is non-negotiable, the Hollyland LARK MAX 2 adds 32-bit Float Internal Recording directly on the transmitter, capturing audio at 48 kHz / 32-bit Float even if camera gain is misconfigured. The receiver also accepts the included OWS earphones for real-time wireless audio monitoring without interrupting the camera connection. Mounting and pairing follow the same steps as the LARK M2. A dedicated LED on the transmitter confirms 32-bit Float recording mode is active once powered on.
Adjust Your Camera Audio Settings After Connecting
Connecting the microphone is only half the process. Camera audio menus default to settings that actively undermine external mic performance.
Switch the audio input source to external. Open your camera’s audio or sound menu and change the input from built-in microphone to external mic or shoe-mount input. If this setting is skipped, the camera continues recording from its internal mic regardless of what is plugged in. In some models of Canon, you can choose “Manual” from the sound recording settings to allow camera to use your external mic.
Disable AGC (Auto Gain Control). AGC automatically adjusts recording levels and produces audible pumping during quiet passages. Disable it and switch to manual audio control. On Sony, navigate to Menu > Audio > Audio Rec Level > Manual. On Canon, go to Menu > Audio > Auto Level > Off.
Set the manual recording level to a safe starting point. With AGC off, adjust the input level until loud speech peaks between -12 dB and -6 dB on the camera’s audio meter. This leaves headroom for sudden loud moments without clipping.
Record a short test clip and review it. Confirm the audio meter responds to speech during recording, then play the clip back through headphones to verify the external mic is the source and the tone sounds natural.
Monitor through the headphone output if your camera supports it. Real-time monitoring lets you catch issues such as hum, one dead channel, or distortion before committing to a full take.
Note: Setting a moderate gain level on the LARK M2 transmitter via the HollyAudio app before the signal reaches the camera reduces how hard the camera’s internal preamp needs to work. A well-set transmitter gain paired with a conservative camera level produces a noticeably lower noise floor than under-amplifying at the transmitter and compensating with high camera gain.
[Image anchor: Hollyland App gain adjustment screen shown alongside the camera audio meter display.]
Quick Fixes If Audio Isn’t Working After Connection
No signal at all (meters not moving)Cause: Cable not fully seated, or camera still set to internal mic input. Fix: Reseat the 3.5mm cable at both ends. Confirm the camera audio input source is set to external. For the LARK M2: check the receiver LED – solid blue means the transmitter link is active; a flashing or off LED means the units have lost pairing. Power both off, then re-pair with the receiver powering on first.
Audio is low or noisyCause: Camera gain set too low, or noise cancellation is not active. Fix: Increase the manual recording level on the camera until peaks approach -12 dB. In the HollyAudio app, confirm AI Noise Cancellation is toggled on.
Audio appears in only one channelCause: The camera is set to stereo input but only one channel carries a signal, or the pan balance is off-center. Fix: Open the camera audio menu and set the channel mode to mono so the signal is duplicated to both channels. Some cameras require selecting a “mono mic” input mode rather than stereo. Adjust L/R panning to center if a dedicated pan control is available.
Can I attach a microphone to a camera that doesn’t have a 3.5mm jack?
Yes, but you need a specific audio adapter. You may also need a media mod or a compatible wireless system. Action cameras like the GoPro HERO series require proprietary media adapters. Such as a GoPro Pro 3.5mm Mic Adapter or a USB-C mic adapter. Generic USB-C to 3.5mm adapters usually will not work properly. Wireless mic systems with USB-C receivers provide direct workarounds.
Do I need a special adapter for an XLR microphone on a camera?
Most regular cameras do not include XLR inputs. So an XLR-to-3.5mm adapter cable is needed for dynamic mics. Condenser microphones need 48V phantom power for smooth functioning. But an external audio interface or portable recorder with built-in preamps can be a good alternative. Devices from Zoom or Tascam often provide this support. Some camera cages and audio handles include built-in XLR preamps. They send a 3.5mm output, giving a clean, professional XLR setup.
How do I know my microphone is actually being picked up after connecting it?
Watch the external audio meters on your camera screen, audio interface, or recording device while speaking. The bars should move up and down with your voice. If they stay flat, the device is not receiving any external signal. You can also record a short 10-second test clip. Play it back using headphones to check the source and sound quality.
Can a wireless microphone be used with any camera?
A wireless mic with a 3.5mm TRS output (such as the Hollyland LARK M2) is compatible with any camera that has a 3.5mm mic input, including DSLRs, mirrorless cameras, and camcorders. For cameras without a 3.5mm port, a compatible adapter is required. Compatibility depends on the camera’s input type, not the wireless system’s design.
What is the difference between a TRS and a TRRS cable for cameras?
TRS (Tip-Ring-Sleeve) has two bands on the plug and carries a mono or stereo audio signal suited for camera mic inputs. TRRS (Tip-Ring-Ring-Sleeve) has three bands and adds a microphone channel designed for smartphones and headsets. Using a TRRS cable in a camera mic input frequently causes signal loss, channel crosstalk, or audio recorded in only one channel. Always use TRS for camera connections.
There are three ways to connect a microphone to a camera. A 3.5mm wired connection offers a direct and simple setup without extra steps. Using XLR with an adapter supports studio-grade microphones in a proper way. A wireless receiver mount allows recording without cables getting in the way. After connecting, switch the camera audio input to external. You should also turn off AGC since it can affect sound levels. Once that is done, test the gain in your real shooting environment before recording.
