Android Microphone Not Working? 9 Fixes That Actually Work
Your Android microphone suddenly stops picking up sound. This makes calls, videos, and voice messages unusable. The problem might be something simple, like a switched setting, a changed app permission, or even dust blocking the microphone opening. This guide walks you through nine targeted fixes in order from quickest to most involved, so you can stop guessing and start recording again.
First, Figure Out What’s Actually Broken
Before running every fix on the list, spend sixty seconds narrowing down the cause. Three questions will point you directly to the most likely section.
Question 1: Does the mic fail in all apps, or just one?
  • Only one app (Zoom, TikTok, WhatsApp, etc.) → The problem is almost certainly a missing app permission. Start with Fix 2.
  • Every app, including the built-in Voice Recorder → The issue is OS-level or hardware. Check Fix 3 (privacy toggle) first, then continue down the list.
Question 2: Does it fail on calls but work in recording apps or vice versa?
  • Calls only → Android routes calls and recordings through different audio profiles. A Bluetooth device may be intercepting call audio. Check Fix 4.
  • Recording apps only → A permission or app conflict is the most likely cause. Check Fix 2, then Fix 5.
Question 3: When did the problem start?
  • After an Android update → The Android 12+ privacy microphone toggle may have been reset. Start with Fix 3.
  • After connecting a Bluetooth device or wired headset → Audio routing was redirected. Start with Fix 4.
  • Suddenly, with no obvious trigger → Start from the top with Fix 1 and work through in order.
Fix 1 — Check Physical Obstructions and the Mic Location
The microphone grille on most Android phones sits along the bottom edge, often beside the USB-C port. A thick case, a poorly fitted screen protector, or compacted pocket lint can block it completely.
  1. Remove your phone case and inspect the bottom grille for debris. Use a dry, soft-bristled toothbrush to gently clear any buildup.
  2. Open the built-in Voice Recorder app, tap record, and speak normally. Watch the audio level meter. If it stays flat, the mic is not picking up sound.
  3. If the meter responds after cleaning, reattach the case and retest. The case itself may be the culprit.
Fix 2 — Grant Microphone Permission to the App
Missing or incorrectly set app permissions are the single most common software cause of mic failure. This is always worth confirming before moving to more involved steps.
  1. Open Settings and tap Apps (labeled “Application Manager,” App management,” or “Manage Apps” on some devices).
  1. Tap App Settings.
  1. Choose the app.
  1. Tap Permissions, then tap Microphone.
  1. Select Allow or Allow only while using the app. If it is set to Deny, change it now.
  2. Reopen the app and test the microphone immediately.
Samsung One UI path: Settings → Apps → [App Name] → Permissions → Microphone.
Google Pixel path: Settings → Privacy → Permission Manager → Microphone → [App Name] → Allow.
Note: Apps such as Zoom, TikTok, and WhatsApp need proper permissions to work right. They require camera and microphone access set to “Allow while using the app.” If access was set to “Don’t allow” or limited before, change it back to “Allow while using the app,” then test again.
If granting permission does not help, try revoking it entirely, force-stopping the app through Settings → Apps → [App] → Force Stop, then relaunching and granting it again. This resets a stuck permission state that occasionally persists after an app update.
Fix 3 — Check Android’s Privacy Microphone Toggle (Android 12 and Later)
Android 12 added a microphone privacy switch in Quick Settings that many people miss. When it is turned off, all apps lose microphone access at the same time. This often causes the mic to stop working across every app without warning.
  1. Open Settings and tap Privacy.
  1. Tap Privacy Dashboard (Privacy Protection or Privacy Controls, depending on your Android skin).
  1. Look for the Microphone access toggle and confirm it is switched on.
  2. Alternatively, swipe down twice to open the full Quick Settings panel and look for a Mic tile. If it appears with a line through it, tap it to re-enable microphone access system-wide.
Note: Not all Android skins surface this toggle in Quick Settings by default. On Samsung One UI 4 and later, you can add it manually by tapping the pencil icon in Quick Settings and dragging the Mic tile into the active area.
Once the toggle is back on, open the built-in Voice Recorder app and confirm the mic is responding before testing inside a third-party app.
Fix 4 — Disconnect Bluetooth Devices and Headsets
When a Bluetooth headset, earbuds, or car kit is connected, Android automatically routes mic input to the Bluetooth device’s microphone rather than the phone’s. This happens silently in the background and is one of the most frequently overlooked causes of apparent mic failure.
  1. Open Settings → Bluetooth (or tap the Bluetooth icon in Quick Settings).
  2. Identify any currently connected audio device and tap its name.
  3. Look for Audio settings or a Hands-free audio toggle and disable it, or tap Disconnect to remove the device entirely.
  4. Return to the app that was failing and test the microphone again.
For wired headsets: If a 3.5mm or USB-C headset is partially inserted, Android may switch to the headset mic while that mic is faulty or clogged. Fully remove any wired accessory and retest the built-in mic on its own.
Fix 5 — Clear Cache for the Affected App (and the Phone App)
Corrupted cached data can lock an app’s access to hardware resources, including the microphone. This fix is particularly effective after an app update that did not install cleanly.
  1. Open Settings → Apps → [App Name].
  2. Tap Storage (or Storage and Cache).
  1. Tap Clear Cache. Do not tap Clear Data or Clear Storage yet — that erases all account settings and saved data.
  1. Restart the app and test the mic.
For call-only mic failures: The Phone or Dialer app has its own cache. Navigate to Settings → Apps → Phone (you may need to enable “Show system apps”) and repeat the steps above.
If clearing the cache does not resolve the issue, return to tap Clear Data / Clear storage as mentioned above. You will need to sign back into the app afterward, but this clears any deeper corruption that the cache clear missed.
Fix 6 — Boot Into Safe Mode to Isolate Third-Party App Conflicts
Safe mode starts Android with only system apps active. If the microphone works in safe mode, a third-party app you have installed is monopolizing mic access or interfering with audio routing.
  1. Press and hold the power button until the power menu appears.
  2. Long-press the Power off option until a “Reboot to safe mode” prompt appears, then tap OK.
  3. Once in safe mode (you will see “Safe mode” at the bottom of the screen), open the built-in Voice Recorder app and test.
  4. If the mic works, restart normally and review recently installed apps. Screen recorders, background voice assistants, and call recorder apps are the most common culprits.
  5. Uninstall suspected apps one at a time and retest after each removal until the mic behaves normally in standard mode.
Note: On some Samsung devices, long-press Power off on the power menu screen rather than in the hardware button sequence — the prompt appears differently across One UI versions.
Fix 7 — Check for Pending Android System Updates
Known audio driver bugs in specific Android builds have occasionally broken microphone input for certain devices, and a pending system update may already include the patch. Navigate to Settings → System → System Update and install any available update. Restart after updating and retest the mic. A system update alone rarely resolves a microphone issue with no other software cause, but it reliably rules out a known OS-level regression before you move to more involved steps.
Fix 8 — Reset App Preferences
Resetting app preferences returns all app permissions to default settings. It also restores default apps and background data limits. Personal files and photos stay on your device.
  1. Open Settings → System.
  1. Tap Reset options (on Samsung: General Management → Reset).
  1. Tap Reset app preferences.
  1. Tap Reset apps to confirm.
Note: This resets microphone permissions for every app on the device, not just the one causing the problem. After the reset, reopen each app you use regularly and grant mic access again when prompted.
The Mic Is Physically Damaged — Use a Wireless External Microphone Instead
If the mic stays silent in all apps, including Voice Recorder, the hardware is likely damaged. Safe mode tests confirm no software conflict in this case. Damage may come from drops, water, or debris inside. You can send the phone for repair service next. Another option is using an external wireless microphone instead. It often gives a quicker setup and clearer sound quality.
The Hollyland LARK A1 is a direct plug-and-play solution for Android. Its USB-C receiver plugs straight into your phone’s USB-C port with no driver installation, no Bluetooth pairing, and no companion app required. Here is how to get it running:
  1. Connect the receiver. Plug the LARK A1 USB-C receiver into your Android phone’s USB-C port. Confirm the LED indicator lights up solid blue — this means it is connected and ready to capture audio.
  1. Confirm transmitter pairing. The transmitter and receiver are pre-paired from the factory. Check the receiver LED: a blue steady light means already paired; flashing means press the pair button on the transmitter until both LEDs sync and hold steady.
  1. Verify Android input routing. Check that your Android phone detects the external USB microphone correctly. Most Android devices switch to connected USB microphones automatically. If the audio does not switch properly, check the USB routing setting manually. Open your recording app and choose the external USB microphone as the input source. If problems continue, open Developer Options inside Android settings. Then make sure “Disable USB audio routing” stays turned off.
  2. Check the mute toggle. The LARK A1 TX’s power button also acts as a mute button. Double-press the button to activate the mute function. If you have two transmitters, then press the power button twice to mute TX1 and thrice to mute TX2. A red LED means muted — press again to unmute before recording.
  3. Set the noise cancellation level. The LARK A1 offers three levels of intelligent noise cancellation. You can enable it by pressing the physical noise-canceling button or through the HollyAudio (LarkSound) app. For indoor voice recording, Level 2 (Medium) is a practical starting point that reduces background hum without thinning out the vocal tone.
  1. Test the recording. Open Android’s built-in Voice Recorder, record a short clip, and play it back. You should hear clear audio captured through the LARK A1 rather than the damaged built-in mic.
For vloggers or interview setups where a cable is not practical: The Hollyland LARK M2 is a fully wireless clip-on system that transmits over its own 2.4 GHz link, keeping the USB-C port free while delivering the same broadcast-quality audio.
When to Seek Hardware Repair
If the built-in mic is confirmed non-functional through safe mode testing and an external microphone like the LARK A1 works correctly when connected, the mic element needs physical replacement. Start by checking whether your device is still under the manufacturer’s warranty or a carrier protection plan. A warranty repair is typically free or low-cost and preserves the original water resistance seal.
If your device is out of warranty, find an authorized repair center. Samsung, Google, and OnePlus list service centers on their websites. You can also choose a trusted repair shop with good reviews. Avoid replacing the microphone yourself without hardware experience. The mic is often soldered or placed under delicate parts. Factory reset will not fix physical damage at this stage.
Why does my Android microphone work in some apps but not others?
App permissions are often the main reason the mic fails. Each app must get microphone access allowed in settings first. Open Settings, go to Apps, choose the app, then open Permissions. If it still does not work, system microphone access may be off. Pull down quick settings and switch microphone access on. Close all running apps from the recent apps screen. Then open the app again and check the microphone.
My microphone stopped working after an Android update: what do I do?
Start with the Android 12+ privacy toggle: go to Settings → Privacy and confirm the microphone access switch is on. Major OS updates occasionally reset this setting without warning. If the toggle was already on, clear the cache for the affected apps and test again. If neither step resolves it, run Fix 8 — Reset App Preferences — to restore all permission states to their defaults.
My microphone works on calls but not in recording apps (or vice versa) — why?
Phone calls use the “communication” audio profile; recording apps use the “media” audio profile. Android can route these two profiles differently, including to different mic inputs. Confirm the recording app has microphone permission, then check whether a connected Bluetooth device is intercepting only one of these profiles. Disconnecting Bluetooth and retesting usually reveals whether audio routing is the underlying cause.
Will a USB-C wireless microphone work with any Android phone?
Most Android phones with USB-C support USB Audio Class (UAC) devices natively, meaning a plug-and-play mic like the Hollyland LARK A1 works without drivers or additional apps. A small number of budget devices with USB-C ports used solely for charging may not support USB audio out. If you are unsure, check your manufacturer’s spec sheet for “USB audio” or “USB OTG” support before purchasing.
Go through fixes in order, starting with permissions first. Then check the Android privacy toggle in Security and privacy. Next, disable Bluetooth and remove any connected devices. Clear the app cache and test the microphone again. Use safe mode to check for software conflict issues. Install system updates and restart the device afterward. Reset app preferences if the problem continues. Most software mic issues are fixed before finishing all steps.
If the built-in mic still fails, the hardware may be damaged. Hollyland LARK A1 restores clear audio on Android quickly. Plug the USB-C receiver in and start recording right away. For wireless setup, the Hollyland LARK M2 also works well. It gives similar audio quality without using cables. It keeps your device port completely free for use.
