How to Allow TikTok to Access Your Camera and Microphone (iPhone and Android)
If TikTok is showing a black screen, recording no audio, or keeps asking for permissions you’re not sure how to grant, you’re not alone. This usually happens when the app was denied access to your camera or microphone during setup, either by accident or by default. The fix takes less than a minute once you know where to look. This guide will show you the step-by-step process for both iPhone and Android. It also explains what to do if TikTok still does not work after changing the settings.
How to Allow TikTok to Access Your Camera and Microphone (iPhone & Android)
Why TikTok Asks for Camera and Microphone Access?
TikTok needs camera access to record video and microphone access to capture audio when you create content. If you tapped “Don’t Allow” during the initial permission prompt — or if the prompt never appeared — TikTok won’t be able to record anything, leaving you with a black screen or silent audio.
How to Allow TikTok Camera and Microphone Access on iPhone (iOS)?
The fastest way to fix this on iPhone is through the main Settings app. You don’t need to go through a separate Privacy menu — iOS lets you manage all permissions for a specific app in one place.
Steps to Enable on iPhone
  1. Open the Settings app on your iPhone.
  2. Scroll down and tap TikTok.
  3. Under the permissions list, toggle Camera to ON (green).
  4. Toggle Microphone to ON (green).
  5. Return to TikTok — the app will now have access to both.
Note: If you don’t see TikTok listed in Settings, the app may not have triggered a permission request yet. Open TikTok and attempt to record — this will prompt the request. If TikTok still doesn’t appear, delete and reinstall the app to reset the permission flow.
How to Allow TikTok Camera and Microphone Access on Android
On Android, permission settings are found in the app management menu. The labels may differ slightly depending on your device brand, but the steps are similar on most Android versions.
Steps to Enable on Android
Note: The steps below are shown on an Infinix phone running Android version 10.
  1. Open Settings on your Android device.
  1. Tap App management (sometimes listed as Apps or Application Manager, depending on your device).
  1. Tap App Settings.
  2. Find and tap TikTok from the app list.
  1. Tap Permissions.
  1. Tap Camera → select Allow.
  1. Tap Microphone → select Allow.
Now, the Camera and Microphone should appear under the “Allowed” section.
  1. Reopen TikTok and try recording.
Note: On Samsung devices, the path is typically Settings → Apps → TikTok → Permissions. The steps are nearly identical across most Android versions, including Android 11, 12, 13, and 14.
TikTok Still Can’t Access Your Camera or Microphone? Try These Fixes
If you’ve granted permissions but TikTok’s camera or microphone still isn’t working, one of these steps will usually resolve the issue:
  • Force close and reopen TikTok — permission changes don’t always take effect until the app fully restarts. Swipe it closed and relaunch.
  • Update TikTok — an outdated version can cause permission conflicts. Check for updates in the App Store or Google Play.
  • Restart your device — a full reboot ensures the operating system applies the new permission settings cleanly.
  • Check for system-level restrictions — Screen Time on iOS or Digital Wellbeing on Android can override app-level permissions independently. Make sure TikTok isn’t blocked at the system level.
  • Reinstall TikTok — as a last resort, deleting and reinstalling the app wipes all stored permission states and prompts you fresh on first launch.
Want Better Audio for Your TikTok Videos?
Even after fixing your permissions, your phone’s built-in mic can still struggle, especially in noisy spots or when you’re a bit far away. Many creators switch to a tiny wireless clip-on mic for cleaner sound. The Hollyland LARK M2 is made for this. It weighs just 9g, clips onto clothes without being noticeable, lasts up to 40 hours, and connects straight to your phone without a bulky receiver. It’s an easy way to improve TikTok audio while keeping your setup light.
Q: Can I use TikTok without giving it camera or microphone access?
Yes, you can browse and watch TikTok content without granting either permission. But both camera and microphone access are required for recording and posting videos. If you only want to consume content, you can safely leave those permissions off — just enable them when you’re ready to create.
Q: Why does TikTok keep asking for camera and microphone access?
This typically means you’ve previously denied the permission or dismissed the prompt. TikTok may ask again after an app update resets its permission state. The permanent fix is to grant access directly through your device’s Settings as outlined above — that overrides the in-app prompt behavior.
Q: Does allowing microphone access let TikTok listen all the time?
No. On both iOS and Android, the operating system restricts active microphone use to when the app is open and running in the foreground. iOS also displays an orange indicator dot at the top of the screen whenever any app is actively using the microphone, so you can always tell when it’s in use.
Fixing TikTok’s camera and microphone access takes under a minute on either platform — navigate to TikTok in your iPhone’s Settings or in Android’s app permissions, and toggle both switches to Allow. If it’s still not working after that, a force-close or device restart almost always clears it up. Once everything is running, you’re ready to record.
