Your iPhone mic is no longer picking up sound. Phone calls have no audio on your end, Voice Memos stays blank, and Siri doesn’t pick up any voice input. Before booking a repair appointment, most microphone failures trace back to a permissions block, a piece of debris, or a rogue Bluetooth connection. This guide walks you through eight ordered fixes that cover every software and hardware-adjacent cause, starting with the fastest and ending with the most thorough.
First, Figure Out What’s Actually Wrong
Knowing where the failure is happening saves you from running every fix unnecessarily. Answer these four questions before you start:
Is the problem limited to one app? If Voice Memos records audio fine but Zoom captures nothing, the issue is almost certainly a permissions block. Start with Fix 1.
Is the problem call-only? If people on phone calls cannot hear you but Voice Memos works, the cause is likely Bluetooth audio routing or Phone Noise Cancellation. Jump to Fix 4 or Fix 5.
Does the problem exist across every app? If no app picks up audio at all, the issue may be physical: debris in the mic port, a case blocking the opening, or hardware failure.
Did the problem start after connecting a Bluetooth device? AirPods, car systems, and Bluetooth speakers can silently reroute audio input. Disconnect all Bluetooth devices and retest before anything else.
iPhone mic locations to know:
Bottom edge — primary mic, located next to the Lightning or USB-C port
Rear camera array — secondary mic used primarily for video recording
Front earpiece slot — used during FaceTime and front-facing video capture
8 Ways to Fix iPhone Microphone Not Working
Work through each fix in order, then test your microphone in Voice Memos before moving to the next step. Open Voice Memos, tap the red Record button, speak, stop the recording, and play it back. Voice Memos is the most reliable baseline test because it accesses the microphone directly, with minimal app-layer interference.
Fix 1 — Check Microphone Permissions for the Specific App
This resolves the majority of app-specific mic failures. iOS silently blocks microphone access if a permission was denied at any point.
Open Settings.
Tap Privacy & Security.
Tap Microphone.
Locate the affected app in the list (Zoom, Instagram, WhatsApp, etc.).
Toggle the switch to the on (green) position.
Open the app and test audio immediately.
Note: iOS 14 and later introduced an “Ask Next Time” permission option. If a user selected it during the app’s first mic request, access was blocked after that single session. iOS 17 and later also allows one-time permission grants, which expire as soon as you leave the app. If the toggle is already on, try toggling it off, waiting five seconds, and switching it back on to force the permission handshake to reset.
Fix 2 — Remove Your Case and Inspect the Mic Port
Thick cases, pop sockets with adhesive mounts, and raised screen protector edges frequently sit directly over one or more of the iPhone’s three mic openings. The bottom-edge mic is the most commonly blocked.
Remove your iPhone case completely.
Remove any pop socket or adhesive accessory from the back of the phone.
Hold the phone under a light and visually inspect the bottom-edge port area and the rear mic pinhole near the camera.
Test Voice Memos with the bare phone.
If audio quality improves immediately, the case was the problem. Check the cutout alignment on your existing case against the mic positions before putting it back on, or switch to a case with properly aligned openings.
Fix 3 — Clean the Microphone Grille
Lint, pocket debris, and compacted dust are among the most common causes of muffled or missing mic audio. The bottom-edge mic sits right next to the charging port — exactly where debris accumulates over time.
Power off your iPhone before cleaning.
Use a dry, soft-bristle toothbrush.
Brush the mic grille and port opening in a gentle circular motion for 20 to 30 seconds.
Tap the phone lightly against your palm to dislodge loosened debris.
Power the phone back on and test with Voice Memos.
Note: Do not use compressed air at close range. The pressure can push debris deeper or damage the mic membrane. Avoid liquids, alcohol swabs near the ports, and any sharp or metal tools. A wooden toothpick at the very outer edge of the grille is acceptable, but do not probe inward.
Fix 4 — Disconnect Bluetooth Devices and Check Audio Routing
When AirPods, a car Bluetooth system, or a Bluetooth speaker is connected, iOS routes audio input through that device rather than the iPhone’s built-in mic. The iPhone mic appears completely dead, but the actual problem is audio routing.
Swipe down to open Control Center.
Tap the AirPlay icon in the audio tile and confirm audio output is set to iPhone.
Open Settings > Bluetooth.
Disconnect every listed device by tapping the device name and selecting Disconnect (or Forget This Device to remove it entirely for testing purposes).
Open the Phone app and place a test call, or use Voice Memos.
During a live call, tap the audio source icon at the bottom of the call screen and confirm the active source is set to iPhone or Speaker, not a Bluetooth device.
Fix 5 — Disable Phone Noise Cancellation
Phone Noise Cancellation is designed to reduce ambient sound during calls, but when enabled, it can suppress audio in ways that make the microphone appear non-functional — particularly if the phone is held slightly away from the ear or a case is altering proximity sensor readings.
Open Settings.
Tap Accessibility.
Tap Audio/Visual.
Locate Phone Noise Cancellation and toggle it off.
Place a test call and confirm the other party can hear you clearly.
This setting affects only phone calls, not Voice Memos or third-party apps. A call-only problem that passes the Voice Memos test is a strong indicator that this setting or Fix 4 is the culprit.
Fix 6 — Force Restart Your iPhone
A force restart clears transient OS-level audio driver glitches without erasing any data. It forces the processor to reset, clearing cached states that a standard power cycle may not address.
For Face ID models (iPhone X and later): 1. Press and quickly release the Volume Up button. 2. Press and quickly release the Volume Down button. 3. Press and hold the Side button until the Apple logo appears, then release.
For Home button models (iPhone 8 and earlier): 1. Press and hold the Home button and the Side (or Top) button simultaneously until the Apple logo appears.
After the phone restarts, open Voice Memos immediately and record a short clip to confirm audio is restored before testing in any other app.
Fix 7 — Install the Latest iOS Update
iOS point releases have both introduced and resolved microphone permission bugs and audio driver regressions across multiple generations. If your mic problem appeared after a recent iOS update, a follow-up patch may have already addressed it.
Back up your iPhone first: Settings > [your name] > iCloud > iCloud Backup > Back Up Now.
Open Settings.
Tap General.
Tap Software Update.
If an update is available, tap Download and Install and follow the prompts.
After the update completes and the phone restarts, test the microphone function in Voice Memos.
Note: If the mic issue appeared after a specific iOS update, still install any newer available update. Apple typically issues point releases to address regressions introduced in prior versions.
Fix 8 — Reset All Settings
Reset All Settings is the final software step before concluding that the fault is hardware. It resets every system configuration to factory defaults — network settings, privacy permissions, accessibility toggles, keyboard preferences, and display settings — without removing photos, apps, or personal data.
Open Settings.
Tap General.
Tap Transfer or Reset iPhone.
Tap Reset.
Select Reset All Settings (not “Erase All Content and Settings”).
Enter your passcode if prompted, then confirm.
After the device restarts, open Voice Memos and test microphone function.
After this reset, you will need to re-enter Wi-Fi passwords, re-grant app microphone permissions (revisit Fix 1 for each app), and reconfigure any accessibility or display preferences. If the mic still does not work after this step, the failure is hardware, not software.
Built-In Mic Still Broken? Use an External Wireless Mic as an Immediate Fix
If you have worked through all eight fixes and the iPhone microphone still does not work, you are almost certainly dealing with damaged hardware. Repair appointments take time but the Hollyland LARK A1 gives you a fully functional microphone in under a minute with zero software configuration required.
x
The LARK A1 uses a direct Lightning or USB-C receiver that plugs into your iPhone’s charging port. There is no Bluetooth pairing, no app to download, and no settings page to navigate. iOS recognizes it instantly as an audio input device the moment it is seated in the port.
Before you purchase, choose the correct receiver version:
iPhone Model |
Receiver Type Needed |
iPhone 14 and earlier |
Lightning receiver |
iPhone 15 and later |
USB-C receiver |
How to connect and use the LARK A1:
Plug the LARK A1 receiver into your iPhone’s Lightning or USB-C port. iOS recognizes it immediately — the receiver’s LED indicator lights up to confirm an active connection. No pairing button press, no app launch, no driver installation required.
Clip the transmitter to your collar or lapel near your mouth.
Press and hold the power button on the transmitter body until the transmitter LED activates and turns solid blue. The transmitter and receiver link automatically.
Open Voice Memos, Camera, FaceTime, or any recording or calling app. iOS automatically routes microphone input from the LARK A1 receiver — no manual source selection is needed inside the app.
To adjust noise reduction, press the noise cancellation button on the transmitter or receiver.
To set LARK A1’s 3-Level Intelligent Noise Cancellation, open the HollyAudio (LarkSound) app, make sure your mic is linked, and then select Low, Medium, or High levels from the noise cancellation section. A lower setting for quiet indoor spaces, a higher setting for outdoor or noisy environments.
Record a short Voice Memos clip and play it back to confirm clean audio before using the setup on a live call or video recording.
Because the LARK A1’s signal travels from the transmitter through the receiver and directly into the iPhone’s port, the internal mic hardware is not in the signal chain at all. It works even if the built-in microphone is physically damaged.
When to Contact Apple Support?
If all eight fixes failed and cleaning produced no improvement, the microphone hardware itself is likely damaged from physical impact, water exposure, or component wear. A software workaround cannot restore a physically failed mic.
Here’s what you should do:
Apple Support chat or phone: Start here for remote diagnosis and to confirm whether the fault is covered under warranty or AppleCare+
Genius Bar appointment: In-person inspection to identify the specific hardware damage
Review repair costs before committing: Check your AppleCare+ coverage status first; out-of-warranty mic repairs can be significant in cost
Q: Why does my iPhone microphone work in Voice Memos but not during phone calls?
Phone calls use a different audio routing path than recording apps. Two settings specifically affect call audio: the Phone Noise Cancellation toggle (Fix 5) and active Bluetooth devices hijacking mic input (Fix 4). If Voice Memos records audio cleanly, the built-in hardware is intact. Disconnect all Bluetooth devices first, then disable Phone Noise Cancellation, and retest with a live call.
Q: Why can’t people hear me on FaceTime or Zoom on my iPhone?
A common cause of mic issues in Zoom is blocked access. Open Settings, then go to Privacy & Security and Microphone. Turn on the switch for the app you are using. If everything looks fine or FaceTime still has trouble, check if a Bluetooth headset is routing the microphone. You can also record in Voice Memos to test the mic. If that recording works, the problem is not hardware but the app.
Q: Can an iOS update really fix a microphone problem?
Yes. Microphone permission bugs and audio driver regressions have appeared across iOS releases and been resolved in follow-up point updates. If your mic stopped working after a recent iOS upgrade, installing the latest available update is a legitimate fix, not just routine maintenance. Back up your device via iCloud first, then update through Settings > General > Software Update.
Q: If my iPhone’s built-in mic is damaged, will an external mic still work?
Yes. The Hollyland LARK A1 uses a Lightning or USB-C receiver that skips the phone’s built-in microphone. Sound moves from the wireless transmitter straight into the receiver and then through the port. The faulty internal mic is not part of this path at all. This gives a quick fix when hardware problems happen and also serves as a solid upgrade for calls, videos, and recording content.
Start with microphone permissions and physical inspection. These two steps alone resolve the majority of iPhone mic failures in under five minutes. Work through the settings and software fixes in order, and treat Reset All Settings as your final software gate before concluding hardware failure. If the built-in mic is damaged and you need audio now, the Hollyland LARK A1 plugs directly into your Lightning or USB-C port with no setup required. If none of the software fixes helped, book a Genius Bar appointment for a detailed hardware diagnosis.
