Solidcom C1 Pro Wired Headset for Hub
$129.00
Add to Wishlist
Key Features
  • Connects to Hub via 10-Pin Connector
  • Link up to 8 Solidcom C1 Pro Remotes
  • Two-Mic Environmental Noise Cancellation
  • Reliable 1.9 GHz DECT 6.0 Technology
  • Comfortable Single-Ear Headset Design
  • Wide Frequency Response for Clear Audio
  • Mute/PTT Button or Rotate Boom to Mute
The Hollyland Solidcom C1 Pro Wired Headset is equipped with dual-mic Environmental Noise Cancellation (ENC) feature, making it suitable for use in noisy environments. It can be connected to the hub (available separately) through a 10-pin connector, serving as the primary headset in this full-duplex wireless DECT intercom system. The system can accommodate up to 9 users simultaneously, and additional hubs can be daisy-chained to accommodate more headsets, allowing for further expansion.
$129.00
$129.00
