$549.00 USD $299.00 USD
Shipping calculated at checkout.
Description
  • 70ms Ultra-Low Latency, 450ft Transmission Range.
  • SDI+HDMI Dual Interfaces, 4 APP Monitoring
  • Up to 1080p, 12Mbps Data Rate, 3 Scene Modes.
  • Smart Channel Scan, Direct Live Streaming.
  • Multiple Power Supply and Diverse Fan Control Modes.
  • Sturdy & Durable Zinc Alloy Shell.
  • Colorful Indicator Logos, Integrated Cold Shoe.
Options: Mars 400S Pro Ⅱ
Mars 400S Pro Ⅱ
Add to Wishlist
Guaranteed Safe Checkout
30-Day Free Return | 12-Month Warranty
Global Support
Free Shipping Over USD $99
Order before 12:00 p.m., ships within the same business day
0.07s Low Latency
450ft (150m) LOS Range
12Mbps Data Rate
SDI & HDMI Dual Ports
Flexible Monitoring Options
Smart Channel Scan
Multiple Fan Modes
Transcending Limits
Rectangle 1413.png__PID:de1098c8-c28c-45a8-9206-3f07c9598e67
Greater Range, Lower Latency
Mars 400S Pro II is a powerful video transmission device with several remarkable features. It offers a transmission range of up to 450ft (150m) and achieves a low latency of just 70ms. Additionally, Mars 400S Pro II is equipped with SDI+HDMI dual interfaces, supports multi-receiver setups, and allows monitoring through the Hollyview App.
Experience Crisp Clarity with12 Mbps Data Rate
Supports 12 Mbps data rate, enabling high-definition video transmission and delivering clear, refined image quality with rich details.
70ms Ultra-Low Latency 450ft (150m) Transmission Range
Group 1004.png__PID:4f157641-90b9-4b26-a4a7-44600b376523
Mars 400S Pro II raises the bar with an incredibly low latency of just 70ms. It outperforms Mars 400S Pro by reducing latency by 30% and providing a stable signal transmission range of up to 450ft. This ensures exceptional high-definition image quality and an immersive low-latency experience. Furthermore, Mars 400S Pro II is compatible with Mars 400S Pro, allowing them to be paired and used together.
Note: The LOS range of 450ft (150m) is based on interference-free laboratory measurements.
Rectangle 693.png__PID:4b4f6692-3079-441d-8b72-3159f6700d62
SDI + HDMI Dual Ports for Unmatched Compatibility
Rectangle 1416.png__PID:6b28e354-edd4-432d-85db-fa2406854619Rectangle 693.png__PID:4b4f6692-3079-441d-8b72-3159f6700d62
Equipped with both SDI and HDMI interfaces, Mars 400S Pro II provides enhanced device compatibility and convenient connections to various types of equipment. Whether it's a DSLR camera or a professional film camera, Mars 400S Pro II can fulfill your connectivity requirements.
Steady Shooting withSmart Channel Scan
Upon startup, Mars 400S Pro II automatically selects the best frequency channels. Additionally, channel scanning can be conducted using the receiver or the HollyView App, providing a visual representation of signal interference levels at each frequency. Allows for the swift identification of the most suitable frequency.
Group 971.png__PID:f6bf89f6-39bf-4e09-9ebc-6e7c2c9956aa
Monitoring on Up to 4 Devices
Mars 400S Pro II offers flexible solutions to meet monitoring needs, including team collaboration, multi-crew monitoring, and multi-member cooperation.
Group 972.png__PID:d1fb41b0-3107-4899-8203-1fd0dd071c4e
Flexible Fan Control Including Mute Option
Mars 400S Pro II is equipped with a three-speed fan adjustment feature (Off, Low Speed, Auto). Its intelligent cooling design allows it to perform optimally in various usage scenarios by reducing device temperature and ensuring stable signal transmission.
Rectangle 1416.jpg__PID:ab220a7a-c535-4b87-ac15-1d2203ef3204
Auto Mode
The device automatically adjusts the fan speed based on its temperature, ensuring effective heat dissipation.
Low-Speed Mode
The fan operates at the lowest speed, reducing noise generation. This mode is suitable for environments where low noise levels are required.
Off Mode
The fan is completely turned off, making it suitable for scenarios that require absolute silence.
Integrated Cold Shoe for Seamless Installation
Integrated with a cold shoe featuring a 1/4-inch threaded cold shoe simplifies the installation process. Simply connect the cold shoe of the Mars 400S Pro II to the cold shoe slot on the device, without the need for any cumbersome additional installation steps.
Group 935.png__PID:43a8852f-643a-4b24-ba7e-ac5baf770e4a
