A microphone that keeps cutting out mid-call, mid-recording, or mid-stream can disrupt an entire session. The annoying thing is that sound cutting out does not have one clear cause. It may come from a loose cable connection. A damaged driver can also create this problem. Power settings in Windows may interrupt the audio too. Wireless signal issues can also cause sudden dropouts. This guide goes through each possible cause step by step. It helps you find where the audio problem is coming from. You can then apply the correct fix without guessing.
Start Here: Figure Out the Kind of Audio Dropout
Before working through any fix, identify which dropout pattern you are experiencing. This routes you to the right section and saves time.
The mic fully disconnects from the OS (disappears from the device list or stops being recognized): Start with physical connections, then move to USB power management and drivers.
Audio cuts out only inside one specific app (Zoom, OBS, Discord) but works normally elsewhere: Skip to Application and Software Conflicts.
Wireless signal drops intermittently mid-recording or mid-call: Go directly to the Wireless Microphone section.
Audio drops out intermittently across all apps on any input device: Work through the OS audio settings and driver sections first.
Check Physical Connections and Hardware First
Before changing any software settings, check the basic wired connection first. A damaged or weak cable is often the main reason for sound dropouts. These cable issues can look like software problems because the mic still connects at times. The connection just does not stay stable.
Inspect the cable end to end: Look for fraying near the connectors, bent or corroded XLR pins, and kinks that suggest internal wire damage. A cable that looks fine at a glance can still have a broken internal conductor.
Swap the cable for a known-good one: This is the fastest hardware test available. If the dropout stops, the cable was the cause.
Try a different USB port: If you use a USB microphone, move it to a port directly on the computer chassis. Avoid USB hubs entirely, as they introduce power instability that leads to intermittent disconnections.
Check the audio interface connection and power supply: If your mic runs through an audio interface, confirm the interface cable is fully seated, and the unit is receiving enough power. Bus-powered interfaces can drop signal when the host USB port cannot supply enough current for consistent operation.
Verify the 3.5mm jack is fully seated: A headset or lavalier plugged into a combo jack requires a firm, complete insertion. A connector that is 90% inserted will still pass some audio but will drop the signal during slight movement.
Note: Dirty or oxidized connector pins can interrupt the signal. These faults often appear only when the cable moves slightly. That makes the issue seem random during use. Cleaning the connector with contact cleaner can often fix it for good.
Update or Reinstall Your Audio Driver
Old or broken audio drivers often cause USB microphone dropouts. This happens a lot after Windows updates. The system may replace the original driver with a basic or wrong version. Just checking for updates is not enough. A full reinstall is often needed. It removes leftover broken files that simple updates do not fix.
On Windows
Press Windows + X and select Device Manager.
Expand Sound, video and game controllers.
Right-click your audio device and select Uninstall device.
In the confirmation dialog, check Delete the driver software for this device if the option appears.
Restart the computer. Windows will reinstall a driver automatically on reboot.
If dropouts continue after the restart, download the manufacturer’s driver directly from the interface or microphone maker’s support page and install it manually.
Note: The Microsoft generic USB audio driver (usbaudio.sys) is often more stable than certain third-party drivers on specific interfaces. If a manufacturer driver is already installed and causing problems, allowing Windows to install the generic version after uninstall is a valid and practical fallback.
On Mac
Core Audio, the macOS audio engine, can develop transient faults that produce dropout without any driver change having occurred. Restarting the process is the fastest first step.
Open Terminal and run: sudo killall coreaudiod
Enter your password when prompted. Core Audio restarts automatically within a few seconds.
If dropouts persist after the restart, go to System Settings → Privacy & Security → Extensions and review any installed third-party audio extensions. Disable them one at a time to isolate the conflicting component.
Fix Your OS Audio Settings
Wrong system audio settings can cause sound to cut in and out. This often looks like a hardware or driver problem. Two common causes are Exclusive Mode in Windows and mismatched sample rates on both platforms.
Windows: Exclusive Mode and Sample Rate
Right-click the speaker icon in the taskbar and select Sounds.
Go to the Recording tab, right-click your microphone, and select Properties.
Open the Advanced tab.
Uncheck Allow applications to take exclusive control of this device. Exclusive Mode allows a single application to lock the mic input, which causes other apps and sometimes the OS itself to lose the signal entirely while that application is active.
Set the Default Format to match your recording software’s project settings. A common mismatch is a mic configured at 44100 Hz while the DAW project runs at 48000 Hz. This forces constant sample rate conversion and introduces buffer artifacts that present as dropout.
Optional: Go to the Enhancements tab and select Disable all enhancements. Windows audio processing can suppress or distort the signal in ways that closely resemble dropout.
Note: The Enhancements tab is not available in all Windows versions.
Mac: Audio MIDI Setup and Input Level
Open Audio MIDI Setup, found in Applications → Utilities.
Select your input device from the left column.
Confirm the sample rate matches the rate set in your recording application. Adjust it here if a mismatch exists.
In System Settings → Sound → Input, verify that the input volume slider is not set near its minimum. When the input level is extremely low, macOS may suppress the signal and treat it as silence, which the recording application registers as dropout.
Disable USB Power Management (Windows)
Windows power settings can turn off USB devices to save battery. This includes USB microphones and wireless receivers. This can cause the mic to stop working for a few seconds. It then connects again on its own. Many people think it is a driver or hardware issue.
Method 1: Power Plan settings:
Open Control Panel → Power Options.
Click Change plan settings next to the currently active plan.
Click Change advanced power settings.
Expand USB settings → USB selective suspend setting.
Set it to Disabled for both the On battery and Plugged in states.
Method 2: Per-device Power Management:
Open Device Manager.
Expand Universal Serial Bus controllers.
Right-click each USB Root Hub entry and select Properties.
Go to the Power Management tab and uncheck Allow the computer to turn off this device to save power.
Repeat this step for every USB Root Hub listed.
Note: This setting applies equally to USB wireless receiver dongles. If a wireless microphone receiver is plugged in via USB and dropping signal at a fixed interval, USB selective suspend is a likely cause that sits entirely outside the wireless hardware itself.
Wireless Mic Keeps Cutting Out: Signal, Battery, and Pairing Fixes
Wireless microphone dropouts follow a different pattern than wired ones. Check each possible cause in order. Do this before assuming the hardware is faulty.
RF Interference and Physical Range
The 2.4 GHz band used by most consumer wireless microphones is shared with Wi-Fi routers, Bluetooth devices, baby monitors, and other wireless microphones operating nearby. Congestion on this band is the most frequent cause of wireless audio dropout.
Move the receiver as close to the transmitter as practically possible during initial testing.
On the computer or phone connected to the receiver, temporarily disable Wi-Fi and Bluetooth, then retest.
Reposition the receiver so it has a clear line of sight to the transmitter. Avoid mounting the receiver behind the camera body, inside a bag, or adjacent to metal surfaces. Each of these obstructions can reduce effective range by 50% or more.
If other wireless microphones are active nearby, power them off during testing to eliminate band congestion as a variable.
Note: A wireless mic’s stated range works best in open space. Indoors, walls and objects reduce that range a lot. For example, a 200-meter outdoor range can drop to 20 or 40 meters inside a room with reflective surfaces.
Battery-Related Signal Degradation
A transmitter does not maintain full signal strength right up until the battery dies. Below roughly 20% charge, many transmitters begin producing intermittent signal loss that looks exactly like RF interference. This is one of the most consistently misdiagnosed wireless dropout causes.
Check the battery level indicator before every recording session.
Charge both the transmitter and receiver to full before recording.
Avoid recording while the transmitter is actively charging, as some chargers introduce electrical noise into the audio path.
Pairing and Connection State Instability
A transmitter and receiver that are not fully paired produce the same dropout symptoms as interference. An incomplete pairing sequence is especially common after a firmware update or when multiple units are powered on together in the same space.
Power off both the transmitter and receiver completely.
Power the receiver on first and allow it to reach its ready state.
Power on the transmitter and allow the auto-pair sequence to complete fully before testing audio.
Avoid initiating pairing in the same physical area as other active wireless microphones operating on the same frequency band.
Diagnosing Wireless Dropout on the Hollyland LARK MAX 2
The steps above describe the general wireless diagnostic process. The Hollyland LARK MAX 2 provides specific, readable feedback at each diagnostic step through its LED indicators and companion app, which removes the guesswork from wireless troubleshooting.
Reading the LED states first:
Start every wireless diagnostic session here before touching any other setting.
Transmitter solid blue: Paired and transmitting normally.
Transmitter rapid blue blinking: In pairing or searching mode. Audio is not transmitting yet.
Transmitter red LED or slow red flash: Low battery. Charge before continuing any diagnosis.
Receiver solid blue: Connected and receiving signal. If the receiver LED is blinking while the transmitter shows solid green, pairing is one-sided and a full re-pair is required.
Re-pairing the LARK MAX 2:
Hold the multi-function button on the transmitter for around 6 seconds when the unit is in the off state until the LED switches to rapid blinking.
Repeat the same process on the receiver unit.
Wait for both LEDs to return to solid blue, confirming a successful connection.
Checking gain and clipping:
There are two ways to check gain on Hollyland LARK MAX 2.
Way 1: HollyAudio App
Connect the LARK MAX 2 to the app and go to the transmitter's settings page.
Scroll down to the Dynamic Gain section and select High, Medium, or Low gain.
To manually adjust gain, use the Set gain to slider to adjust the gain intensity.
Way 2: LARK MAX 2 Camera Receiver
Ensure both TX and RX units are paired.
Press the round button on the RX body to open the menu.
Rotate the wheel above the round button on the RX and enter Mic Settings.
Select the Mic Gain option.
Choose Auto or Custom gain from the gain settings to adjust levels.
Using the HollyAudio app for battery and processing diagnosis:
Open the HollyAudio app and navigate to the battery readout screen. The app displays real-time battery percentage for both the transmitter and receiver. Confirm that the battery is not the cause of dropout before advancing to interference testing.
Then go to the AI Noise Cancellation toggle (NC Level) in the app settings and temporarily disable AI NC. Noise cancellation processing can sometimes create audio glitches. These can sound like brief signal drops. This happens more often in busy or complex background noise.
Using 32-bit float internal recording as a diagnostic backup:
The LARK MAX 2 captures a 32-bit float recording directly on the transmitter during every session. If the wireless output to your camera or phone dropped audio in a take, access the transmitter’s onboard recording to determine whether clean audio was captured at the source. If the backup recording is clean, the dropout was a wireless transmission failure between the transmitter and receiver. If the backup recording is also affected, the problem originated at the transmitter before the signal was ever sent, pointing toward gain or physical placement as the cause.
Monitoring with OWS earphones:
Connect the wireless OWS earphones and walk through the recording environment while listening live through the earphones to identify the distance threshold at which dropout begins. This produces a precise range limit for your specific environment rather than an estimate from the spec sheet.
LARK M2 - Another Super Hit Wireless Mic Model from Hollyland: For the LARK M2 used in everyday content creation scenarios, position the transmitter on the chest or collar rather than in a pocket or bag interior. Body mass between the transmitter and receiver significantly reduces effective range. The LARK M2 LED follows the same solid-blue paired versus rapid-blinking searching pattern for quick status confirmation in the field.
When a microphone cuts out only inside one specific application but performs normally everywhere else, the application itself is the source of the problem rather than the hardware or OS. Most of the time, one of two things is happening. The app may be holding full control of the microphone input. Or the audio buffer in a DAW may be set too low, so the system cannot process sound in time without losing samples.
Close background applications that may have captured the microphone input before the affected app was opened. Video conferencing tools such as Zoom, Teams, and Google Meet frequently hold the mic input open even when minimized.
Verify the correct input device is selected in the application’s own audio settings. Applications often default to the OS system device, which may differ from the specific interface or microphone you intend to use.
In DAW software, increase the audio buffer size to 256 or 512 samples as a starting point. A buffer set to 32 or 64 samples under heavy plugin load creates real-time processing dropout that sounds indistinguishable from intermittent signal loss.
On macOS, check microphone access permissions at System Settings → Privacy & Security → Microphone. An app without explicit microphone permission will receive no signal, or will receive signal inconsistently if permissions were granted but not retained across an OS update.
Why does my microphone cut out every few seconds?
When audio cuts out at regular short gaps, Windows power settings are often the reason. USB selective suspend may be turning the device off on a timer. Turning off USB selective suspend in Power Options usually fixes this. Another common reason is a driver conflict. The system keeps reconnecting the device again and again. This creates a repeating pattern of audio dropouts every few seconds.
Why does my mic only cut out in one app but not others?
The most likely cause is that the application has claimed exclusive control of the mic input, preventing other apps from accessing the signal while it is active. Disable Exclusive Mode in Windows Sound settings and verify the application’s own audio input settings to confirm it is using the correct device and not applying conflicting processing.
Why does my wireless microphone keep cutting out even when I am close to the receiver?
Being close to the receiver does not always mean a stable signal. Other issues can still affect performance at short range. Nearby Wi-Fi or Bluetooth signals may cause interference. The device may also be only partly paired or not fully connected. Too much gain can create clipping noise. Low battery levels can also weaken transmission. Start by checking the transmitter LED status. Do this before blaming distance for the problem.
Can a low battery cause a microphone to cut out before it dies completely?
Yes. Most wireless transmitters begin producing intermittent signal loss when battery charge falls below roughly 20%, well before the unit shuts down completely. Many users misread this as interference or a pairing problem. Always check battery level first and charge to full before each recording session to eliminate this variable early.
Why does my USB microphone keep disconnecting from my computer?
The most common cause on Windows is USB selective suspend, which powers the device down automatically to conserve energy. The second most common cause is an unstable or underpowered USB hub. Move the microphone to a port directly on the computer chassis and disable USB selective suspend. If disconnections continue after both changes, reinstall the audio driver.
Does Wi-Fi interference affect wireless microphone performance?
Yes, particularly for wireless microphones operating on the 2.4 GHz band, which is shared with most Wi-Fi routers and Bluetooth devices. Temporarily disabling Wi-Fi on the recording device during a session can confirm whether interference is the cause. Setting the router to broadcast on 5 GHz instead of 2.4 GHz reduces congestion on the band your microphone uses.
Follow the checks step by step. Begin with cables and hardware. Then move to drivers on your system. After that, review your audio settings. Once done, check USB power settings. Then test wireless signal and pairing issues. And finish by checking problems inside the app itself. Remember, doing the sequence-wise diagnosis helps you find the real cause faster. Whereas random fixes usually waste more time.
