Adobe Audition gives you several dedicated tools to eliminate background noise from recordings — but choosing the wrong one leads to wasted time or degraded audio. This guide covers the three most effective methods in order of control and precision: the Noise Reduction (Process) effect, Adaptive Noise Reduction, and the DeNoise effect. Whether you’re cleaning up a podcast interview, a voiceover, or a YouTube video, you’ll find a repeatable workflow here.
Why Background Noise Is Hard to Remove Without the Right Method
Not all background noise behaves the same way. A consistent hum from an air conditioner or the steady hiss of a room tone is a different problem from wind gusts, shifting traffic, or noise that changes intensity throughout a recording. Audition’s noise removal tools are each designed for a different scenario — using the wrong one means either not removing enough or damaging the audio you actually want to keep.
The core challenge is that noise and voice occupy overlapping frequency ranges. Any tool aggressive enough to kill the noise can also strip warmth, clarity, and naturalness from vocals. That’s why each method below includes a preview step and recommended safe ranges before you commit.
Note: The cleanest path to noise-free audio starts at the recording stage, not in post. A wireless mic like the Hollyland LARK MAX 2 records at 48 kHz / 32-bit Float with on-board AI Noise Cancellation, which means significantly less noise entering the file in the first place — and far less correction work in Audition.
Method 1 — Use Noise Reduction (Process) with a Noise Print (Best for Consistent Noise)
This is the most precise and widely used method in Adobe Audition. It works by sampling a short clip of pure background noise — called a Noise Print — and then using that profile to selectively remove that exact noise signature from the rest of the audio. It performs best when the noise is consistent throughout the recording, such as HVAC hum, electrical hiss, or steady room tone.
Step 1 — Select a Noise-Only Segment
Find a section of your audio that contains only background noise — no voice, music, or intentional sound. A gap before the speaker starts talking or a pause between sentences works well. Aim for 0.5 to 2 seconds of clean noise.
Open your audio file in the Waveform Editor (not the Multitrack session).
Click and drag to highlight that noise-only region.
Make sure the selection is long enough to give Audition an accurate noise profile — too short and the sample may not be representative.
Step 2 — Capture the Noise Print
With the noise-only segment still selected, go to Effects > Noise Reduction / Restoration > Noise Reduction (Process).
In the dialog box that opens, click “Capture Noise Print” at the top.
Audition will analyze the selected region and store the noise profile. You’ll see the frequency graph update to reflect the noise signature.
Step 3 — Apply Noise Reduction to the Full Clip
Select the entire audio clip by pressing Ctrl+A (Windows) or Cmd+A (Mac).
Re-open Effects > Noise Reduction / Restoration > Noise Reduction (Process). Your captured Noise Print will still be loaded.
Set “Noise Reduction” to a starting value of 70–80%. Avoid pushing it to 100% — maximum reduction almost always introduces processing artifacts.
Click Preview and listen carefully to the result. Check both that the noise is gone and that the voice sounds natural and unaffected.
If satisfied, click Apply.
Tips for Dialing In the Settings
Getting the right result often means adjusting a few parameters beyond the main reduction slider:
Noise Reduction %: This controls how aggressively the tool attenuates the identified noise frequencies. A range of 60–85% is the practical sweet spot for most voice recordings. Higher values risk making the audio sound hollow, robotic, or “underwater.”
Smoothing: This blends the noise reduction transitions over time. A value of 1–2 is typically safe. Higher values reduce “musical noise” artifacts but can soften transients.
Spectral Decay Rate: Controls how quickly the effect releases after a noise burst. Values between 5–10% work well for voice; too high and the audio sounds smeared.
Over-processing warning: If your audio sounds unnatural after applying — voice quality is metallic or bubbling — lower the Noise Reduction % and re-apply.
Audition’s noise removal is destructive in the Waveform Editor, so always use Ctrl+Z / Cmd+Z to undo before re-trying.
Method 2 — Use Adaptive Noise Reduction (Best for Variable or Changing Noise)
When background noise shifts throughout a recording — outdoor environments, fluctuating fan noise, or a room where traffic comes and goes — a static Noise Print won’t capture it accurately. Adaptive Noise Reduction solves this by continuously analyzing the audio and adjusting its noise removal in real time. No Noise Print capture is required.
This method trades some precision for flexibility. It’s faster to apply and handles dynamic noise situations well, but it has slightly less surgical control than Method 1 for a simple, clean noise floor.
Steps:
Open your audio file in the Waveform Editor.
Select the full clip (Ctrl+A / Cmd+A) or the specific region you want to process.
Go to Effects > Noise Reduction / Restoration > Adaptive Noise Reduction.
In the dialog, adjust the key parameters:
Reduce Noise By: Start at 7–8db , same conservative approach as Method 1.
Spectral Decay Rate: Adjust between 5–20% depending on how quickly the noise changes. Higher values help with fast-shifting noise.
Broadband Preservation: Raises this value (50–100) to protect broadband audio content like voice from being treated as noise. Increase it if vocal quality sounds thin.
Click Preview and compare the treated vs. untreated audio.
Click Apply when the result is acceptable.
Method 1 vs. Method 2 at a glance: Use Method 1 (Noise Print) when noise is steady and uniform throughout the clip — it gives you tighter, more predictable control. Use Method 2 (Adaptive) when noise varies or you don’t have a clean noise-only segment to sample from. Both methods are equally destructive, so preview before committing.
Method 3 — Use the DeNoise Effect for a Quick Fix
The DeNoise effect is Audition’s fastest noise removal option and requires the least setup. It’s a good choice when you need a clean-enough result quickly and don’t need fine-tuned control over the output.
You can find it in two places: - Effects > Noise Reduction / Restoration > DeNoise - The Essential Sound panel (Window > Essential Sound), under the Dialogue preset group
Steps:
Select the audio region you want to treat.
Open Effects > Noise Reduction / Restoration > DeNoise.
Drag the Amount slider to set reduction strength. Start low (around 40–50%) and preview.
Click Apply when satisfied.
Limitation: DeNoise is less transparent at higher reduction amounts than the Noise Reduction (Process) method. At settings above 70–80%, it tends to create noticeable artifacts faster. Use it for quick turnarounds, but return to Method 1 when audio quality matters most.
Pro Tips to Get the Best Noise Removal Results
These refinements help protect vocal quality and make your noise removal process more consistent across projects:
Always preview before applying. Noise reduction in the Waveform Editor is destructive — once applied and the project is saved, you can’t easily reverse it. Use the Preview button every time, and keep Ctrl+Z / Cmd+Z ready.
Record a dedicated noise floor sample at the start of every session. Before speaking or playing music, let the mic run for 2–3 seconds of silence in the recording environment. This gives you a reliable Noise Print source without hunting through the clip later.
Don’t stack multiple noise removal tools on the same clip. Running Method 1 and then Method 2 on the same audio multiplies the risk of artifacts. Choose the best method for the clip and apply it once.
Apply noise reduction before other effects in the chain. Noise reduction should come before EQ, compression, or limiting. Applying it after compression can make artifacts worse and harder to correct.
Apply in the Waveform Editor, not directly on a Multitrack clip. The Noise Reduction (Process) and Adaptive Noise Reduction effects are only available as offline processes in the Waveform Editor. Open the clip there, process it, then return to the Multitrack session.
Start cleaner, fix less in post. If you find yourself fighting noise on every recording, the problem is likely at the capture stage. The Hollyland LARK MAX 2 records at 48 kHz / 32-bit Float with on-board AI Noise Cancellation, which dramatically reduces ambient noise before it ever reaches Audition — leaving you with less aggressive processing to do and better-sounding final audio.
Why does my audio sound robotic after noise reduction in Audition?
This is the most common over-processing artifact. It happens when the Reduce Noise By percentage is set too high — typically above 85–90%. Lower the slider to the 65–75% range, use the Preview function to check, and re-apply. You can also try slightly increasing the Smoothing value to reduce the metallic edge.
Can I remove background noise from the entire project at once in Audition?
Not directly in the Multitrack session — the Noise Reduction (Process) and Adaptive Noise Reduction effects work in the Waveform Editor only. For batch processing, you can save your settings as a Favorite (Favorites > Start Recording Favorite)
and apply it to multiple files via Edit > Export > Batch Process. The DeNoise effect is also available as a real-time effect in the Multitrack Effects Rack.
What’s the difference between Noise Reduction and Adaptive Noise Reduction in Audition?
Noise Reduction (Process) requires you to capture a Noise Print — a sample of the exact noise you want to remove. It works best for consistent, unchanging noise. Adaptive Noise Reduction analyzes noise dynamically as it processes the audio, making it better for variable or shifting background noise where a single noise profile wouldn’t be accurate enough.
Does Adobe Audition’s noise removal affect voice quality?
Yes — at higher reduction amounts, it can thin out vocals, remove natural room presence, or introduce metallic artifacts. The key is staying in the 65–80% reduction range and using the Preview function to catch quality degradation before it’s committed. Treating a conservatively cleaned track sounds more natural than one that has been over-processed.
Can I use Audition’s noise removal on music recordings?
You can, but with significant caution. Music contains a dense range of frequencies, and the noise removal tools have a high risk of treating musical content as noise — especially sustained notes, reverb tails, and high-frequency overtones. Start at 40–50% reduction, preview extensively, and consider whether the noise is audible enough to justify the risk to the mix.
For most recordings, Method 1 — Noise Reduction (Process) with a Noise Print is your most reliable starting point. It gives you precise, repeatable control for consistent noise like hum and room tone. Reach for Adaptive Noise Reduction when noise shifts throughout a clip, and use DeNoise when you need a fast result and fine control isn’t a priority. Regardless of method, the Preview step is non-negotiable — it’s the only way to protect your audio quality before a destructive edit locks in.
Ready to go further? Explore how to set up a proper podcast recording chain in Audition or how to use the Essential Sound panel to streamline your entire post-production workflow.
