Your microphone sounds clear in Audacity and decent in Windows. Then it suddenly sounds much worse during Discord calls. Here's what's happening! Discord processes every voice signal through several audio settings. Many of those settings are turned on automatically. This guide covers six fixes, starting with the ones most likely causing the issue.
Why Discord’s Audio Processing Can Make a Good Mic Sound Bad
Discord’s voice engine applies multiple processing layers before your voice reaches anyone else on the call. Noise suppression powered by Krisp, echo cancellation, automatic gain control, and Opus codec compression all operate simultaneously, and every one of them modifies your audio signal. These settings exist for a good reason in many situations. They help laptop users in noisy coffee shops sound clear. But on clean microphones in quiet rooms, they add artifacts. Making the microphone sound worse than it really is.
Krisp, Discord’s AI noise suppression system, can be aggressive. It is designed to remove harsh background noise, but the same algorithm frequently targets lower-frequency vocal overtones, room resonance, and natural warmth as “noise.” The result is the metallic, hollow, or robotic quality that Discord users report most often. Automatic gain control compounds the problem when it fights against a microphone that already has a stable, well-structured gain level, creating audible pumping on sustained speech.
The right way to think about this before any fix is simple. Discord settings are usually the main cause, not the microphone itself. Most poor audio issues come from software changes alone. They can often be fixed without changing any hardware.
Quick Diagnostic: Match Your Symptom to the Right Fix
Use this table to jump directly to the fix most likely to solve your specific problem. If you are unsure, start with Fix 1 and work forward.
Symptom |
Most Likely Cause |
Go to Fix |
Robotic, metallic, or hollow voice |
Krisp or AGC over-processing |
Fix 1 |
Too quiet or near-silent input |
AGC conflict or wrong input device selected |
Fix 3 / Fix 4 |
Distorted, crackling, or clipping |
Microphone Boost or Discord input volume too high |
Fix 3 |
Sounds fine in recordings but bad on Discord |
Discord’s own processing pipeline, not OS-level |
Fix 1 / Fix 2 |
Fix 1 — Disable or Tune Discord’s Voice Processing Settings
Path: Discord → User Settings (gear icon) → Voice & Video → Voice
This fix matters most for many users and should come first. Discord’s Voice Processing area includes four settings that change how your voice sounds in calls. All four are turned on by default. Each setting can lower audio quality based on your mic and room.
Noise Suppression — Krisp, Standard, or None
Discord offers three noise suppression modes: Krisp (default), Standard, and None.
Krisp uses neural network-based processing to remove background noise. It is effective at suppressing keyboard clicks and HVAC hum but consistently over-processes voices that have natural warmth, reverb, or any room character. If your voice sounds robotic, hollow, or as though it is coming through a low-quality phone speaker, Krisp is almost certainly the cause.
What to change:
If you are in a quiet room, switch Noise Suppression to None. Your voice will pass through unaltered.
If you need some background noise filtering, try Standard first. It uses a lighter algorithm and introduces fewer artifacts than Krisp.
Only use Krisp if you are in a genuinely noisy environment where the trade-off in voice quality is acceptable.
Echo Cancellation
Echo Cancellation removes audio feedback between your microphone and speakers. It is essential if you are using external speakers. But, if you are using closed-back headphones or an IEM, echo is not a practical concern and the feature only adds unnecessary processing to a clean signal.
What to change: If you are on headphones, toggle Echo Cancellation off and check whether voice quality improves. If no echo is audible from others on the call, leave it off.
Automatic Gain Control (AGC)
AGC continuously adjusts your microphone’s input level in real time to keep output volume consistent. The problem is that AGC cannot distinguish between a deliberate volume change and a level that simply needs boosting. It also creates audible pumping artifacts when it conflicts with a microphone that already has a stable, well-configured gain structure.
What to change: Disable AGC entirely. After disabling it, set your input level manually using Discord’s Input Volume slider and your microphone’s own gain control if it has one. This gives you stable, predictable audio without the pumping side effects.
Advanced Voice Activity
Advanced Voice Activity is Discord’s voice detection algorithm. When the sensitivity threshold is misconfigured or too high, the first syllable of each sentence gets clipped off — words begin mid-way through because transmission triggers a fraction of a second too late.
What to change: Turn off Advanced Voice Activity.
First, make sure you have selected the "Custom" Input Profile.
Then, toggle off the Automatically Adjust Input Sensitivity option.
Scroll down to Advanced Voice Activity and toggle it off.
Note: In the latest Discord desktop application (2026), if you won't disable the Automatically Adjust Input Sensitivity option, the Advanced Voice Activity area will be greyed out.
Fix 2 — Turn Off Discord’s Bypass System Audio Input Processing
Path: Discord → User Settings → Voice & Video → Bypass System Audio Input Processing
Discord provides two audio subsystem options: Standard and Legacy. In the current version, this option has been removed. It is replaced by Bypass System Audio Input Processing. According to Discord’s official representative on their Reddit thread, “It does the same thing as what legacy once did.”
Once you disable Bypass System Audio Input Processing, your mic on Discord should stop picking up background sounds and PC audio.
Go to User Settings.
Click the Voice & Video tab from the left sidebar menu.
Scroll down the options under the Voice section. Look for the Bypass System Audio Input Processing toggle and turn it off.
Fix 3 — Adjust Mic Input Volume and Remove Microphone Boost
Two separate gain issues frequently appear together and are often confused for the same problem.
Issue 1 — Discord Mic Input Volume too high: The Mic Volume slider in Discord’s Voice & Video settings is a gain control, not just a detection threshold. Set it above 80–90% on a sensitive condenser or large-capsule microphone, and the signal will clip before Discord can transmit it cleanly, producing harsh distortion on louder speech. Start at around 70–80% and use the live level bar to confirm no red peaks during normal conversation.
Issue 2 — Windows Microphone Boost: Windows applies a Microphone Boost of +20 dB by default on many recording devices, set at the driver level before the signal reaches any application. Combined with Discord’s own input gain, this pushes the signal well into saturation.
How to recognize clipping: Your voice sounds clear at low volume but hard and distorted at normal conversational level. The Discord input level bar consistently peaks into the red zone during normal speech.
Steps to check and remove Microphone Boost on Windows:
Open Control Panel → Sound → Recording tab.
Right-click your active microphone and select Properties.
Click the Levels tab.
Locate the Microphone Boost control (listed separately from the main volume slider).
Set Microphone Boost to 0 dB unless your microphone is genuinely quiet and requires amplification.
Click Apply, return to Discord, and check the input level bar again.
Also confirm that Automatic Sensitivity is disabled in Discord’s Voice & Video settings and that you have set the voice detection threshold manually. Automatic Sensitivity allows Discord to continuously alter the effective input level, which interferes with a manually calibrated gain structure.
Fix 4 — Check Physical Connection and Input Device Selection
Before assuming a settings problem, run through this physical checklist. Several common hardware issues produce symptoms that look identical to software misconfigurations.
USB port selection: Try moving a USB microphone to a different port, preferably a USB 2.0 port directly on the motherboard rather than a USB 3.0 hub. Some USB 3.0 implementations introduce high-frequency interference that appears as broadband hiss.
3.5mm connection: Confirm the plug is fully seated. If your PC has separate headphone and microphone jacks, plug into the dedicated mic jack, not the headphone output. If your headset uses a single combined TRRS connector, use a TRRS splitter adapter to connect correctly.
Correct input device in Discord: Open Settings → Voice & Video → Voice → Microphone and confirm the dropdown shows your intended microphone by name. Windows sometimes defaults to “Default Communications Device,” which may map to a built-in laptop mic or a different device.
Inline volume control: Some headsets have a volume wheel or mute switch on the cable. Confirm it is turned up and not engaged at the hardware level.
Microphone position: Keeping the mic 6–12 inches from the mouth at a slight downward angle reduces plosive hits on “p” and “b” sounds that cause low-frequency clipping and can trigger noise suppression algorithms unnecessarily.
Fix 5 — Update or Reinstall Microphone Drivers
Driver problems are less common than settings issues but become relevant when the microphone disappears from the Input Device dropdown, sample rate settings revert after a reboot, or audio breaks following a Windows update.
Press Windows + X and open Device Manager.
Expand Sound, video and game controllers.
Right-click your microphone device and select Update driver → Search automatically for drivers.
If no update is found and problems persist, select Uninstall device, confirm, then physically unplug and replug the microphone. Windows reinstalls the driver automatically.
Restart the PC and confirm the device reappears correctly in Discord’s Input Device dropdown.
Note: Most USB microphones are class-compliant and use the built-in USB audio drivers already present in Windows and macOS. Proprietary companion software is only needed for microphones that ship with dedicated app-based controls for gain, EQ, or DSP.
Fix 6 — When Software Fixes Aren’t Enough: Upgrade Your Microphone
Every fix above addresses software and configuration. If you have worked through all of them and your audio still sounds poor on Discord, the problem is the microphone itself. Laptop built-in microphones and low-quality headset mics have integrated noise. This creates a constant background sound even when you stay silent. They also cannot capture the full range of sound well. No Discord or Windows setting can fully fix these limits. Software noise suppression can mask some of that noise, but only at the cost of the voice artifacts described in Fix 1. The microphone capsule is the ceiling.
The Hollyland LARK MAX 2 addresses this at the hardware level in three ways directly relevant to the problems in this guide:
Onboard AI Noise Cancellation processes background noise at the transmitter before the signal reaches Discord, eliminating the need for Krisp and the robotic artifacts it introduces.
Native 48 kHz output delivers a signal that matches Discord’s expected sample rate exactly, with no OS-level resampling and no phase artifacts.
Studio-grade capsule delivers the frequency response and dynamic range that Discord’s Opus codec can actually preserve, rather than a compressed headset signal that loses definition before the codec processes it.
Connecting the LARK MAX 2 to Your PC
Clip the LARK MAX 2 transmitter to your collar or lapel and press the power button to turn it on.
The blue LED on the transmitter confirms it is powered on and paired to the receiver.
Plug the LARK MAX 2 receiver into your PC’s USB-C port. If your PC does not have USB-C, use the included USB-C to USB-A adapter. No driver installation is required. The receiver appears as a USB audio device in both Windows and macOS automatically.
On Windows, open Settings > System > Sound and check under the Input section to confirm that the LARK MAX 2 or USB Microphone (or similar) name shows up.
On Mac, check Settings > Sound > Input to confirm if the LARK MAX 2 appears in the section.
To enable AI Noise Cancellation, press the multi-function button once on the transmitter body. The LED will turn solid green to confirm that noise cancellation is now active.
Alternatively, open the HollyAudio App, navigate to the transmitter settings screen, and toggle the NC Level (AI Noise Cancellation) switch on. This screen also displays gain level, output mode, and any EQ options relevant to voice optimization.
Use the app to set Dynamic Gain. You can also set custom gain from the Set gain to section. The LARK MAX 2 uses 32-bit Float internal recording and will not clip internally, but Discord’s input stage still needs a calibrated signal level for clean transmission.
Configuring Discord After Connecting the LARK MAX 2
Open Discord → User Settings → Voice & Video → Input Device.
Click the Input Device dropdown and select LARK MAX 2 from the list. It will appear by name once the USB-C receiver is connected.
Speak at your normal conversational volume and watch the input level bar in the microphone test section. The bar should respond consistently in the green range without triggering red peaks. Adjust the transmitter gain control if needed until the level is stable.
Disable Noise Suppression and Automatic Gain Control. The LARK MAX 2’s noise cancellation is already handling both tasks at the source. Leaving Discord’s processing enabled creates double-processing artifacts that degrade the clean signal the hardware is delivering.
Use Discord’s built-in “Mic Test” option to confirm clean, natural output. You should hear your voice without any of the robotic, muffled, or distorted characteristics described earlier in this guide.
Why does my mic sound robotic on Discord?
The most common cause is Discord’s Krisp AI noise suppression over-processing your voice signal. Go to Settings → Voice & Video and switch Noise Suppression from Krisp to None if your environment is quiet, or to Standard if you need some filtering. If the robotic quality persists after disabling noise suppression, also disable Automatic Gain Control, which can introduce pumping and metallic distortion independently of Krisp.
Why does my mic sound fine in recordings but bad on Discord?
Discord changes your microphone audio before other people hear it. When voice processing features are enabled, they add effects like echo removal, noise reduction, and automatic volume control. Recording programs such as Audacity capture the original microphone signal instead. To get audio that sounds closer to your recordings, turn off Discord’s extra voice processing features. Set input sensitivity manually and make sure other apps are not changing microphone volume automatically.
Does Discord reduce microphone audio quality by default?
Yes. Discord sends audio through the Opus codec. This compresses the sound data. Bitrates start at 64 kbps and can reach 384 kbps on boosted servers. Plus, it enables features like Krisp noise suppression and AGC by default. Together, these settings can remove some audio detail. The effect is often more noticeable on higher-quality microphones with cleaner sound.
My mic sounds bad only in Discord but works fine in everything else — why?
Discord uses a separate audio processing stack that runs independently of the OS audio engine. Problems isolated to Discord are almost always caused by one of Discord’s own voice processing settings (Fix 1) or the Audio Subsystem setting (Fix 2). If every other application handles the microphone correctly, the fault is inside Discord’s configuration, not at the driver or OS level.
Most Discord microphone problems resolve by disabling or reducing Noise Suppression in Fix 1. If those do not fully resolve the issue, work through Fixes 3 through 5 in order. If audio quality remains poor after every software fix, the microphone is the issue, and an upgrade to a device with hardware-level noise cancellation eliminates the problem at the source.
