How to Edit Audio Files on iPhone: Step-by-Step Methods That Actually Work
Editing audio on your iPhone is more capable than most people expect, and you may already have the tools you need. Whether you recorded a podcast interview, a class lecture, or a voice note, iOS gives you at least two built-in options to trim, cut, and refine files without touching a computer. This guide covers three practical methods, ranked from simplest to most powerful, so you can pick the right approach for your recording and skill level.
What iPhone Audio Editing Can and Can’t Do?
Your iPhone already includes tools for many everyday audio editing jobs. You can trim silent parts and remove unwanted sections. Also, lower background noise, change the volume, and save your audio in common file formats. What it cannot do natively is professional mastering, spectral repair, or complex studio-level mixing.
What iPhone Audio Editing Can (and Can’t) Do
Each method in this guide is made for a different editing need.
  • Voice Memos: Built-in and ready to use; best for quick trims of recordings captured inside the app
  • GarageBand: Free Apple app; handles cuts, fades, and basic multi-track assembly with more precision
  • Third-party apps: Fill specific gaps, including file format conversion, podcast editing, and non-destructive multi-region editing
Method 1: Trim and Edit Audio in Voice Memos (Fast, No Download Needed)
Voice Memos is already installed on every iPhone and requires no account or configuration. Its editing tools are intentionally minimal, but they cover the most common need: removing unwanted audio from a recording and applying a fast noise reduction pass.
Important: Voice Memos only edit recordings made within the app itself. If you have an imported MP3 or WAV file, skip to Method 2 or 3.
Steps to Edit a Recording in Voice Memos
  1. Open the Voice Memos app and choose the recording to edit.
  2. Tap the More button (represented by three horizontal dots), then select the Trim icon from the menu.
  1. Move the yellow trim markers around the section you want.
  1. Pinch outward on the waveform for a closer editing view.
  2. Press Play to preview the selected audio before making changes.
  3. Tap Trim to keep the selected section and remove everything else.
  4. Tap Delete instead if you want to erase the selected section.
  5. Select Apply, then tap Done to finish the editing process.
  6. Choose Save Recording to replace the original audio file.
  7. Select Save as New Recording to keep the original unchanged.
Limitations: Voice Memos cannot merge separate clips or add fade-ins and fade-outs. For those tasks, use GarageBand.
How to Export or Share the Edited File from Voice Memos
  1. Tap the three-dot menu (…) next to the edited recording and select Share.
  2. Choose a destination: Save to Files, AirDrop, Messages, email, or any compatible app.
  3. Voice Memos exports audio in M4A format by default. Most podcast hosts, messaging platforms, and video editors accept M4A without issue.
  4. If you need an MP3, convert it using a browser tool like CloudConvert at cloudconvert.com.
Method 2: Edit Audio in GarageBand for More Control
GarageBand is Apple’s free mobile DAW, either pre-installed on your iPhone or available as a free download from the App Store. It gives you significantly more precision than Voice Memos: you can cut sections from the middle of a clip, add fades, adjust volume region by region, and assemble multiple audio clips on a single timeline.
Steps to Edit Audio in GarageBand
  1. Open GarageBand and tap the “+” icon on the main screen to create a new project.
  1. Select Audio Recorder and Voice from the track type options.
  1. Once inside the project, tap the track view icon (the horizontal lines in the upper left corner) to switch to the timeline.
  1. Import your audio file using the method in the callout below.
  2. Your audio appears as a colored region on the timeline. Pinch the region horizontally to zoom in on the waveform for precise editing.
  1. To trim the start or end of a region, tap the region once to select it, then drag its left or right edge inward.
  2. To split a region, place the playhead where you want the cut to appear. Select the audio region, then tap it again to open the editing menu. Choose Split, then pull the scissors icon downward to finish the cut.
  1. To delete an internal section, split at two points bracketing the unwanted audio, tap the segment between them to select it, then tap Delete. Drag the remaining regions together to close the gap.
  1. When finished, tap the arrow to return to My Songs, then proceed to export.
How to Import an Existing Audio File into GarageBand
  • From the timeline view, tap the loop icon in the upper-right corner.
  • Select the Files tab, then tap Browse items from the Files app.
  • Locate your audio file (M4A, MP3, WAV, or AIFF), then tap it to place it on the timeline as a new region. If you do not see your file, confirm it has been saved to the Files app first.
How to Export Your GarageBand Project as MP3 or WAV
  1. Tap the arrow to exit the project and return to My Songs.
  2. Long-press your project thumbnail until a menu appears, then tap Share.
  1. Select Song from the share options.
  1. Tap Share and choose Save to Files, AirDrop, or another destination.
  2. Note on MP3: GarageBand does not export MP3 natively. Save the file to Files as M4A, then use an online converter to produce an MP3 if your publishing platform requires it.
Method 3: Best Third-Party Apps When Native Tools Aren’t Enough
Voice Memos and GarageBand cover most day-to-day editing needs, but three specific gaps remain: podcast-level editing with chapter support, reliable file format conversion, and a lightweight waveform editor for users who find GarageBand’s project interface too complex. The apps below address exactly those gaps.
App
Best For
Key Features
Cost
Ferrite 3 Recording Studio
Podcast editing
Chapter markers, silence trimmer, chapter-level EQ, multi-track mixing, voice processing
Free (basic); ~$29.9 for full unlock
AudioShare
File format conversion and audio file management
Read and play MP3, WAV, FLAC, M4A, and more; serves as a central audio hub across apps
~$4.99 (one-time)
Hokusai Audio Editor
Destructive waveform editing
EQ, compression, reverb, multi-region selection, unlimited undo history
Free (basic); Hokusai Pro Pack 2 for $9.99
When to use each:
  • Choose Ferrite if you are editing podcast episodes or recorded interviews that need chapter markers or consistent vocal levels across segments.
  • Pick AudioShare if your only goal is playing a file from one format to another. It is faster and more reliable than browser-based converters for on-device use.
  • Hokusai is a better choice if you like seeing the entire waveform. You can edit audio through simple cut, copy, and paste actions. Besides, the undo and redo options allow you to correct mistakes easily.
Quick Comparison: Which Method Should You Use?
Voice Memos
GarageBand
Third-Party Apps
Skill Level
Beginner
Intermediate
Beginner to Advanced
Main Use Case
Quick trims of in-app recordings
Cutting, fading, multi-track assembly
Format conversion, podcast editing, and non-destructive editing
Cost
Free (pre-installed)
Free (pre-installed or App Store)
Free to ~$30
Export Formats
M4A only
M4A, WAV (no native MP3)
MP3, WAV, M4A, FLAC (varies by app)
Limitations
In-app recordings only; no multi-clip editing
Non-obvious import process; no native MP3 export
Feature depth varies; some capabilities require a paid unlock
Pro Tip: Start With Cleaner Audio to Edit Less
The fastest way to cut editing time is to capture better audio at the source. A plug-and-play wireless mic like the Hollyland LARK A1 connects directly to your iPhone via USB-C or Lightning and applies three-level intelligent noise cancellation at the point of capture, so background hiss, room rumble, and handling noise never enter your recording in the first place. Less noise means far less trimming, noise reduction work, and frustration in Voice Memos, GarageBand, or whatever editing app you choose.
Can I edit MP3 files directly on an iPhone?
Yes. GarageBand and apps like Hokusai Audio Editor accept MP3 files directly through the Files app. Import the file using GarageBand’s Files browser or open it in Hokusai, and you can cut, trim, and apply effects without any prior conversion. Voice Memos works differently from the other apps. It only lets you edit recordings made inside the app. Audio files imported from other sources cannot be edited there.
How do I cut out the middle of an audio file on an iPhone?
GarageBand is the best native option. In the timeline, place the playhead where the unwanted section begins. Select the audio clip, tap it again, choose Split, and pull the scissors icon downward. Repeat these steps where the unwanted section ends. Delete the separated middle piece, then slide the remaining clip until both sections connect smoothly.
Does iPhone have a built-in audio editor?
Yes, your iPhone includes two. Voice Memos handles basic trimming and automatic noise enhancement for recordings made inside the app. GarageBand provides a full timeline editor with region splitting, fades, volume automation, and multi-track support. Both are free and available on any iPhone running the latest iOS.
How do I convert an audio file to MP3 on iPhone?
Open Safari, visit cloudconvert.com, upload your file, select MP3 as the output format, and download the result to your Files app. GarageBand does not offer a native MP3 export option without an additional conversion step.
Will editing a voice memo delete the original recording?
Voice Memos gives you different save options after editing your recording. Choosing "Save as New Recording" creates a separate copy of the file. Selecting "Save Recording" replaces the original recording with your edited version. The Replace tool also records new audio over existing sound. During your first edits, save a new copy until you confirm everything sounds right.
For most iPhone users, the right tool is already installed. Use Voice Memos for quick trims, GarageBand when you need to cut internal sections or add fades, and a third-party app like Ferrite for podcast-level editing. Pick the method that matches your current task and move up as your needs grow.
