DaVinci Resolve Screen Recording: How to Capture, Import, and Edit
DaVinci Resolve is one of the most powerful video editors available, but creators often hit a wall when they try to record their screen directly inside it. If you are building tutorials, software demos, or workflow walkthroughs, you need to know exactly how the process works. This guide covers the full pipeline: choosing the right capture tool, importing your footage correctly, and editing it cleanly inside DaVinci Resolve.
Does DaVinci Resolve Have a Built-In Screen Recorder?
No. DaVinci Resolve does not include a native screen recording feature. It is purpose-built for editing, color grading, and audio post-production – not screen capture. What it does exceptionally well is take footage recorded elsewhere and give you a professional-grade environment to trim, grade, mix audio, and export it.
The practical workflow has two stages: capture your screen using a dedicated recording tool, then bring that file into DaVinci Resolve to edit. The sections below walk you through both stages in order.
Best Screen Recording Tools to Use with DaVinci Resolve
Three tools cover the needs of most creators without adding cost or unnecessary complexity. Each produces a format that imports cleanly into DaVinci Resolve.
Tool
Platform
Cost
Best For
Output Format
Xbox Game Bar
Windows
Free
Quick desktop capture
MP4 (H.264)
QuickTime Player
macOS
Free
Clean system-level recording
MOV (H.264/HEVC)
OBS Studio
Win/Mac/Linux
Free
Full control, audio mixing
MP4, MKV, MOV
Xbox Game Bar (Windows)
Xbox Game Bar is already installed on Windows 10 and 11. It requires no additional setup and outputs MP4 files that DaVinci Resolve handles without issues.
  1. Open Settings > Gaming > Xbox Game Bar and toggle it on.
  2. Press Win + G to open the Game Bar overlay.
  3. Click the Capture widget and select your audio source (microphone or system audio).
  4. Press Win + Alt + R to start and stop recording.
  5. Find your file in Videos > Captures.
QuickTime Player (macOS)
QuickTime Player is included with every Mac and produces MOV files compatible with DaVinci Resolve on macOS.
  1. Open QuickTime Player from your Applications folder.
  2. Go to File > New Screen Recording.
  3. Click the dropdown arrow next to the record button to select your microphone.
  4. Enable Show Mouse Clicks if you are recording a tutorial.
  5. Click the Record button and choose your capture area (full screen or selection).
  6. Press Command + Control + Esc or click the stop icon in the menu bar to end recording.
OBS Studio (All Platforms)
OBS Studio gives you the most control over output quality, making it the best choice when your screen recording will go through significant editing or color work in DaVinci Resolve. You can set codec, bitrate, and audio tracks independently. The learning curve is steeper than the native tools, but the payoff in quality is real.
  1. Download and install OBS Studio from obsproject.com.
  2. In the Sources panel, click the + icon and add Display Capture.
  3. Go to Settings > Output > Recording and set the format to MP4 (not MKV – see the import section for why).
  4. Set the encoder to H.264, bitrate to at least 8,000 kbps.
  1. Under Settings > Audio, assign separate tracks for your microphone and system audio.
  1. Go to Settings > Video and set the frame rate to 60fps.
  1. Click Start Recording in the main panel when ready.
How to Import Screen Recordings into DaVinci Resolve
Once you have your screen recording file, bringing it into DaVinci Resolve is straightforward – as long as your project settings align with your capture settings.
  1. Open DaVinci Resolve and create a new project.
  2. Before importing, go to File > Project Settings and set the timeline resolution and frame rate to match your recording (1080p/60fps or 4K/60fps are the most common for screen content).
  3. Navigate to the Media page and open your screen recording file’s folder in the media browser panel.
  4. Drag the file directly into the Media Pool.
  1. From the Media Pool, drag the clip onto the Edit or Cut page timeline.
  2. If a frame rate mismatch warning appears, select Change to update the timeline to match the source clip.
Important note for OBS users: If your OBS output was set to MKV, DaVinci Resolve may not recognize it or may have playback issues. Either change your OBS output format to MP4 before recording, or use OBS’s built-in Remux Recordings option (under File) to convert existing MKV files to MP4 before importing.
Editing Screen Recordings in DaVinci Resolve
Screen recording content has specific editing needs that differ from traditional camera footage. Here is how to handle the most common tasks.
Trimming and Cutting with the Cut Page
The Cut page is the fastest way to remove dead air, hesitations, and mistakes from a screen recording session. Use the Smart Indicator and the Source Tape view to scrub through your footage quickly, then split and delete unwanted segments without switching tools constantly.
Adding Titles, Captions, and Annotations
For tutorial content, on-screen labels and callouts are essential. In DaVinci Resolve, the Fusion page gives you access to Text+ nodes, which let you create animated lower-thirds and callout labels that can be keyframed to appear over specific UI elements.
To highlight a specific button or area on screen, use the Zoom transform in the Edit page Inspector to push in on a region of the frame. Pair this with a Text+ overlay and a keyframed position to guide your viewer’s eye. For arrow or shape annotations, create them inside Fusion using the Shape node or import transparent PNG overlays directly into the Media Pool.
Color Grading Screen Recordings
Screen recordings are typically already high-contrast and saturated – they do not need the same treatment as camera footage. A light touch works best: use Lift, Gamma, and Gain in the Color page to add subtle contrast if the image looks flat, and reduce saturation slightly if colors appear harsh. Skip camera LUTs entirely; they are not designed for screen-captured content and will push the image in the wrong direction.
Syncing and Editing Voiceover Audio
If your voiceover was recorded separately from your screen capture, use the Fairlight page to sync and clean it up. Place your microphone track and your system audio track on separate audio lanes so you can control each independently.
For narration cleanup, apply the Noise Reduction plugin to remove background hum, then use the EQ to roll off low-frequency rumble below 80Hz. Normalize your narration level to target -12 to -6 dB for a clear, broadcast-style volume. Keep system audio (interface clicks, notification sounds) on its own track so you can lower or mute it without affecting the voiceover.
Export Settings for Screen Recording Videos
Use the Deliver page to export. The right settings depend on where the video is going.
Destination
Format
Codec
Resolution
Frame Rate
Bitrate
YouTube / Web
MP4
H.264
1920x1080 or 3840x2160
Match source (60fps)
8-16 Mbps
Local Archive / Client
MOV
ProRes 422
Match source
Match source
High/Auto
For YouTube uploads, H.264 at 1080p/60fps with a bitrate of 8-16 Mbps delivers clean results without inflating file size. If you are delivering to a client for further editing or archiving in high quality, ProRes 422 in a MOV container preserves detail and gives the recipient flexibility in post.
Pro Tips for Higher-Quality Screen Recordings
A few adjustments before and during capture make a noticeable difference in your final edit.
  • Record at 1080p minimum, 4K if your display supports it. Downscaling in DaVinci Resolve always looks sharper than upscaling a low-resolution source.
  • Use 60fps for all screen recordings. Fast-moving UI elements, scrolling, and cursor movement stutter visibly at 30fps. Sixty frames per second eliminates this entirely.
  • Close unnecessary applications before recording. Reducing CPU load prevents dropped frames, especially during extended OBS sessions at high bitrates.
  • Record system audio and microphone as separate tracks in OBS. This gives you independent control in Fairlight and prevents you from having to choose between the two during editing.
  • Invest in your voiceover audio. Built-in laptop microphones pick up keyboard noise, fan hum, and room reverb that are difficult to remove in post. A compact wireless microphone like the Hollyland LARK M2 – which weighs just 9 grams and runs for up to 40 hours – clips to your collar and captures clean narration without desk noise or cable clutter, which is a practical upgrade for anyone recording tutorials at a workstation.
Q: Can DaVinci Resolve record screen directly without additional software?
No. DaVinci Resolve is an editing, color grading, and audio post-production application – it has no screen capture module built in. You need a separate screen recorder such as OBS Studio, Xbox Game Bar, or QuickTime Player to capture the footage first, then import the resulting file into DaVinci Resolve for editing and export.
Q: What is the best format for screen recordings to import into DaVinci Resolve?
MP4 with H.264 encoding is the most compatible and reliable format across both Windows and macOS. For higher-quality work intended for archiving or heavy color grading, MOV with ProRes 422 is the better choice on macOS. If you use OBS, avoid importing MKV files directly – change your OBS output format to MP4 or use the Remux Recordings option before importing.
Q: Why does my screen recording look blurry or pixelated in DaVinci Resolve?
The two most common causes are a low recording bitrate and a resolution mismatch between your source file and the DaVinci Resolve timeline. Set your OBS bitrate to at least 8,000 kbps during capture, and confirm that your timeline resolution and frame rate in DaVinci Resolve match the original recording settings exactly.
Recording your screen for use in DaVinci Resolve is a two-step process: capture with a free external tool, then import and edit inside DaVinci Resolve. With OBS Studio, Xbox Game Bar, or QuickTime Player handling the capture side, and DaVinci Resolve managing everything from cuts to color to audio, the full workflow is accessible at zero cost. For a deeper dive into the next stage, explore a dedicated guide on the best export settings in DaVinci Resolve or how to edit voiceover audio in Fairlight to get the most out of your finished recordings.
