Don't want to ruin your video? Then fix that bad audio in your vlog? Viewers may accept shaky video or uneven lighting in scenes. But they leave fast when the audio sounds noisy, thin, or echoey. The good part is that better sound is possible on any budget. This guide shows six simple ways to improve your audio step by step. Start with gear, then fix your space, then adjust settings, then edit.
Start With the Biggest Change — Upgrade Your Microphone
Built-in microphones on phones and cameras are not made for vlogging. They stay far from your mouth and capture all room noise. They also lack any form of sound isolation for clean voice pickup. No level of editing can fully fix that weak starting point.
Swapping to a dedicated microphone is the single highest-leverage change you can make to vlog audio quality. The right type depends on your shooting style:
Wireless lavalier (clip-on) microphone clips near your collar and stays consistent whether you’re sitting at a desk, walking through a city, or filming B-roll on the move. Because the capsule is a few inches from your mouth instead of a few feet away, background noise becomes a much smaller fraction of the signal.
On-camera shotgun microphone mounts to your camera’s hot shoe and captures audio directionally in front of the lens. It works well for sit-down formats or single-camera setups where you stay in frame, but it loses effectiveness as you move further from the camera.
For most vloggers, a wireless lavalier is the better investment. Here are the recommended options by use case:
Mic Type |
Best Use Case |
Recommended Option |
Wireless lavalier (general) |
Everyday vlogging, travel, talking-head content |
Hollyland LARK M2 |
Wireless lavalier (active/sports) |
Outdoor sports, fitness content, and active shoots |
Hollyland LARK M2S |
Smartphone plug-and-play |
iPhone/Android vlogging, beginners on mobile |
Hollyland LARK A1 |
Advanced wireless lavalier |
Serious content, interviews, run-and-gun |
Hollyland LARK MAX 2 |
The Hollyland LARK M2 is a superb starting choice for most vloggers. It weighs only 9 grams, so it clips on without pulling clothes. It also stays small and does not draw attention on camera. The total battery lasts up to 40 hours with the case. This easily covers a full day of recording without charging stress. Its wireless range gives you freedom to move while recording. You are not limited to dealing with cables like wired setups.
For active vloggers filming sports, fitness routines, or fast-moving outdoor content, the Hollyland LARK M2S is designed specifically for that context. Its titanium clip-on transmitter weighs just 7 grams, offers a no-logo invisible fit, and provides 30-hour battery life — built to stay in place during movement without distracting from the shot.
If you are just starting out and shooting entirely on a smartphone, the Hollyland LARK A1 removes the setup friction completely. It connects directly via USB-C or Lightning with no pairing required and includes 3-Level Intelligent Noise Cancellation — a meaningful upgrade over a phone’s built-in mic without requiring any additional hardware or configuration.
For vloggers producing more serious content — interviews, documentary-style videos, or any scenario where audio cannot be re-recorded — the Hollyland LARK MAX 2 adds capabilities that matter at that level. Its 32-bit Float Internal Recording at 48 kHz captures audio directly to the transmitter as a backup, AI Noise Cancellation actively processes the signal, and OWS earphone monitoring lets you hear exactly what is being recorded in real time.
Optimize Your Recording Environment Before You Press Record
A better microphone helps significantly, but the room itself shapes the audio that the microphone captures. Hard, flat surfaces (concrete, tile, bare drywall, glass) reflect sound and create the boxy, echoey quality common in bedroom vlogs. Fixing your recording space does not need studio panels or treatment. It depends on picking and adjusting places you already use daily.
Indoor recording tips:
Choose rooms with soft furnishings. Rugs, carpeted floors, upholstered furniture, heavy curtains, and bookshelves full of books all absorb sound reflections. A living room with a couch and rug will almost always sound better than a kitchen or bathroom.
Avoid rooms with hard parallel walls and high ceilings without any soft surfaces. Tile bathrooms, empty offices, and stairwells produce the worst results regardless of microphone quality.
Turn off HVAC systems, fans, refrigerators, and any appliances with constant noise output before you record. These create broadband hiss that is difficult to remove cleanly in post.
A clothes closet packed with hanging garments works as a surprisingly effective DIY vocal booth for sitting or standing takes. The fabric absorbs reflections from all sides.
Outdoor recording tips:
Wind is the primary outdoor audio enemy. A wind muff (sometimes called a dead cat) on a lavalier or shotgun mic significantly reduces low-frequency wind rumble. Do not skip this accessory if you film outdoors regularly.
Position yourself with the wind at your back rather than blowing directly toward the microphone.
Avoid open corridors, building overhangs, and narrow passages that funnel and amplify wind.
Outdoor vs. Indoor Quick Checklist
Indoors: Soft furnishings? HVAC off? Away from appliances? Door closed?
Outdoors: Wind muff attached? Wind direction checked? Away from traffic and crowd noise? Mic close to mouth?
Set Your Gain and Input Levels Correctly at Recording Time
The phrase “garbage in, garbage out” applies directly to audio. Noise reduction and EQ can improve clean audio, but they degrade audio with clipping or extreme noise floor problems. Getting gain staging right at the recording stage protects the quality ceiling of everything that follows in post.
How to set gain correctly for vlog audio:
Set your target input level. For spoken voice, aim for peaks between –12 dB and –6 dB on your recording device’s input meter. This leaves enough headroom to avoid clipping while keeping the signal well above the noise floor.
Never let the signal clip. Clipping — when the input level exceeds 0 dB — creates distortion that cannot be repaired. It is a hard cap on what is recoverable in post. Watch your meter and reduce gain before clipping occurs.
Monitor with headphones during recording. Plugging headphones into your camera’s headphone jack (or monitoring through your wireless receiver’s output) lets you hear exactly what is being captured, including any interference, handling noise, or unexpected background sounds.
Understand the two gain stages. On a wireless lavalier system, the transmitter (the capsule near your mouth) has its own gain control, and the camera input has a separate gain control. Set the transmitter gain first based on your voice level, then set the camera input gain to bring the combined signal into your target range.
Adapt for run-and-gun scenarios. In static environments (seated interviews, desk setups), set levels once and leave them. In dynamic situations (walking tours, event coverage), check levels between locations and keep a safety margin below your usual peak to accommodate unexpected loud moments.
Apply Noise Reduction in Post-Production
Noise reduction is the most-searched post-production audio task among vloggers, and for good reason. Even well-recorded audio often contains low-level hiss from the recording environment, a faint electrical hum, or ambient noise from traffic or appliances. Post-production noise reduction addresses what the recording technique could not fully eliminate.
How the noise profile workflow works:
Identify a section of your audio clip where only the background noise is present and your voice is silent — even one or two seconds is sufficient.
Use your editing software to capture a “noise print” or “noise profile” from that section. This tells the software what the consistent background noise sounds like.
Apply the noise reduction filter to the full clip. The software subtracts the noise profile from the entire signal.
Adjust the reduction amount conservatively. Over-applying noise reduction introduces a metallic, robotic artifact into speech. Start at 50–60% reduction and increase only if needed.
Tool options by budget and complexity:
Tool |
Cost |
Best For |
Audacity |
Free |
Simple broadband noise (hiss, hum) on isolated clips |
Free |
Built-in noise reduction dialogue; solid for general vlog audio |
Adobe Audition |
Subscription |
Stronger noise reduction with more precise control |
Final Cut Pro |
One-time purchase |
Basic noise reduction built in; easy workflow for Mac editors |
iZotope RX |
Paid (various tiers) |
Severe audio problems; best-in-class dialogue isolation |
For most vlogging scenarios, DaVinci Resolve Fairlight or Audacity handles broadband noise reduction adequately at no cost. iZotope RX is the tool to reach for when background noise is severe — a loud air conditioning unit, outdoor wind bleed, or crowd noise behind a dialogue track. Its Dialogue Isolate module separates voice from background noise more aggressively than standard noise reduction and produces better results on difficult source material.
Noise reduction tools address broadband noise (consistent hiss, electrical hum, room tone). Transient noise events — a car horn, a door slam, a passing truck — require different treatment, such as manual clip splitting, volume automation, or iZotope RX’s De-click and De-rustle modules.
Use EQ and Compression to Polish Vocal Clarity
Noise reduction cleans up the floor of your audio. EQ and compression shape and balance the voice itself. These two steps are where vlog audio goes from “acceptable” to “clear and professional-sounding,” and most vloggers skip both entirely.
EQ for spoken voice:
Equalization adjusts the volume of specific frequency ranges within your audio signal. For vlog voiceover and talking-head audio, three adjustments do most of the work:
Low-cut (high-pass) filter at 80–120 Hz. Everything below this range is low-frequency rumble — handling noise, footsteps, HVAC vibration, traffic resonance. Cutting this cleanly does not affect your voice but removes the muddy weight underneath it.
Reduce boxy or nasal resonance at 300–500 Hz. If your voice sounds hollow, boxy, or like you are speaking inside a cardboard box, a small cut (2–4 dB) in this range can open it up significantly.
Gentle boost at 2–5 kHz for presence and intelligibility. This range is where consonants and speech clarity live. A slight lift here helps your voice cut through without sounding harsh.
Compression for consistent volume:
A compressor automatically reduces the volume of audio that exceeds a set threshold, which keeps your voice at a consistent perceived level throughout the clip. Without compression, variation in your distance from the mic or natural changes in vocal delivery create noticeable volume swings between sentences.
For spoken word, recommended starting settings are:
Parameter |
Starting Value |
Purpose |
Ratio |
3:1 to 4:1 |
Controls how much louder peaks are reduced |
Attack |
10–20 ms |
Lets the initial consonant through before compressing |
Release |
100–200 ms |
Allows natural decay before the compressor resets |
Threshold |
Set so gain reduction shows on louder phrases |
Activates compression at the right level for your voice |
Makeup gain |
As needed |
Restores overall level after compression reduces peaks |
Both EQ and compression plugins are included in Adobe Premiere Pro, Final Cut Pro, DaVinci Resolve, and most other NLEs at no additional cost. You do not need a separate DAW or third-party plugins to apply these to vlog audio.
Normalize and Master Your Audio for Consistent Output Levels
After noise reduction, EQ, and compression, the final step before export is loudness normalization — setting your overall audio level to a consistent output standard.
YouTube normalizes uploaded content to approximately –14 LUFS integrated loudness. If your audio is louder, YouTube turns it down. Mastering to –14 LUFS ensures your audio arrives at the level YouTube expects without any platform-level adjustment.
LUFS vs. peak dB: Peak normalization sets the loudest single moment in your audio to a target level, but that tells you nothing about perceived loudness — a track with a few loud spikes and mostly quiet audio will peak-normalize to a similar number as a consistently louder track, but sound much quieter. LUFS (Loudness Units Full Scale) measures perceived loudness over time, which is why platforms use it as their standard.
Practical tools for normalization:
Adobe Audition Match Loudness: Batch-normalizes clips to a target LUFS in one step.
DaVinci Resolve Fairlight Loudness Meter: Lets you monitor LUFS in real time during your edit.
Auphonic: A free online tool that normalizes audio files to broadcast standards without requiring any DAW knowledge — useful for quick, standalone audio file processing.
For vlogs recorded across multiple locations or sessions, room tone matching between clips prevents the noticeable shifts in background sound that make a well-edited video feel inconsistent. Recording 10–15 seconds of room tone at each location gives you material to fill gaps and smooth transitions.
Mobile Vlogging Audio Tips (Smartphones and Action Cams)
For vloggers shooting on iPhone, Android, or action cameras like GoPro, a few specific adjustments make a meaningful difference:
Disable automatic gain control (AGC) if your camera app allows it: AGC automatically adjusts recording levels, which sounds helpful but often introduces pumping artifacts and boosts background noise during pauses. Apps like Filmic Pro (iOS/Android) give you manual control over input levels.
Use an external mic via USB-C or Lightning: The Hollyland LARK A1 connects directly to a smartphone with no app pairing or Bluetooth setup — plug in and record. This single change eliminates almost every problem caused by the phone’s built-in mic.
Hold the phone in landscape orientation while recording: Portrait grip often places your hand over or near the microphone location, muffling the signal. Landscape grip keeps hands away from mic ports.
Avoid digital zoom during recording: Zooming moves your subject farther from the phone’s built-in mic without moving the mic closer, which worsens the signal-to-noise ratio.
GoPro and action cams: Use the manufacturer’s external mic adapter if available, and keep wind protection (foam or furry cover) on the microphone in any outdoor conditions. GoPro’s built-in wind reduction settings help, but do not replace physical wind protection.
Common Vlog Audio Mistakes and How to Avoid Them
Mistake |
Fix |
Relying on the built-in camera or phone mic |
Upgrade to an external lavalier or clip-on mic as the first priority |
Placing a wireless transmitter under thick clothing |
Clip the transmitter on the outside of the fabric or use a single layer between the mic and the clothing |
Over-applying noise reduction |
Use conservative reduction (50–60%) and check for metallic artifacts before rendering |
Not monitoring audio during recording |
Use headphones connected to the camera or receiver to catch problems before they are baked in |
Inconsistent mic-to-mouth distance between clips |
Maintain a consistent clip position on clothing throughout the shoot; re-clip after wardrobe changes |
Ignoring room tone for cutaway shots |
Record 15 seconds of ambient room tone at every location; use it to fill gaps in the edit |
What is the most effective single change I can make to improve vlog audio?
The biggest jump in audio quality comes from replacing the built-in mic with a wireless lavalier. This single change has the most impact on overall sound. No software can fully match better mic placement and capsule quality at the source. Once the recording is clean, everything in editing becomes much easier.
Can I fix bad audio in post-production without a better microphone?
Post-production tools can reduce noise and improve clarity in moderately flawed recordings, but they cannot fully recover audio from a poor source or a bad acoustic environment. Every noise reduction pass introduces some artifact risk. Fixing at the source — through mic selection, placement, and environment — always outperforms software fixes applied afterward.
What loudness level should I target for YouTube vlogs?
YouTube normalizes uploads to approximately –14 LUFS integrated loudness. Mastering to –14 LUFS ensures your audio is not artificially lowered on playback and sounds consistent with other content on the platform. Use your NLE’s loudness meter or a tool like Auphonic to verify the target before export.
Is 32-bit float recording necessary for vlogging?
Not necessary for controlled recording environments, but it is a practical safety net for run-and-gun or interview scenarios where gain cannot be constantly monitored. It prevents clipped audio from being unrecoverable in post, which makes it valuable in high-stakes recording situations where a retake is not possible.
Do I need paid software to enhance vlog audio?
No. DaVinci Resolve (Fairlight page), Audacity, and most major NLEs include noise reduction, EQ, and compression tools at no cost. Paid tools like iZotope RX provide meaningfully superior results for severely damaged audio, but they are not required for typical vlog audio enhancement, where the recording quality is reasonable to begin with.
Follow the steps in a clear order for the best results. Start by upgrading your microphone first. Then improve your recording space next. After that, set the proper gain before recording. Finally, add light edits during post-production. Each step improves the next one in the chain. A better mic gives cleaner audio for editing tools. Correct gain settings reduce noise issues later. This also makes editing less heavy and time-consuming. Work on your weakest point instead of doing everything at once. If you still use a built-in mic, start there. If your mic is fine but the room sounds poor, fix the space next.
