How to Record Gameplay for YouTube Shorts (PC, Console & Mobile)
YouTube Shorts is one of the fastest-growing formats for gaming content, but recording gameplay specifically for it isn’t as straightforward as hitting a record button. The vertical format, strict time limit, and resolution requirements change how you need to capture and prepare your footage. This guide walks you through the exact workflow for PC, console, and mobile — so you can start posting polished gameplay Shorts without the guesswork.
What YouTube Shorts Requires from Gameplay Footage
Before you record a single frame, understand the format. Shooting or editing to the wrong specs wastes time and can prevent YouTube from classifying your video as a Short at all.
Here are the core requirements:
  • Aspect ratio: 9:16 (vertical) — this is non-negotiable for native Shorts formatting
  • Resolution: 1080×1920 is the standard target; 720×1280 is the minimum for acceptable quality
  • Maximum duration: 60 seconds (YouTube has begun rolling out 3-minute Shorts in select regions — verify your current limit)
  • Frame rate: 60fps is strongly recommended for gaming footage; 30fps is acceptable but looks noticeably less fluid on fast-paced gameplay
  • File format: MP4 with H.264 encoding is the most compatible option across all upload methods
The biggest adjustment most creators face is that nearly all PC and console games run in 16:9 (horizontal). That footage has to be reframed or cropped before it qualifies as a proper Short. Mobile gameplay is the exception — portrait-mode games record natively in 9:16, which removes one step entirely.
How to Record Gameplay for YouTube Shorts on PC
PC gives you the most control over recording quality and settings. Two tools cover the vast majority of use cases: OBS Studio for creators who want full flexibility, and Xbox Game Bar for anyone who wants a fast, no-setup clip.
Using OBS Studio (Free & Flexible)
OBS Studio is free, open-source, and capable of recording at any resolution and frame rate you need — including a native 1080×1920 vertical scene if you want to skip the cropping step later.
  1. Download and install OBS Studio from obsproject.com.
  2. Create a new Scene in the Scenes panel (bottom left). Name it something obvious like “Shorts Recording.”
  3. Add a Source by clicking the “+” in the Sources panel. Choose Game Capture for most PC games, or Display Capture if Game Capture doesn’t detect your game.
  1. Select “Capture any fullscreen application”:Once you click back to the game, OBS will automatically detect it and start monitoring.
  1. Set your canvas resolution. Go to Settings → Video. For a native vertical output, set Base (Canvas) Resolution to 1080×1920 and Output (Scaled) Resolution to the same. For standard horizontal recording (to crop later), use 1920×1080.
  1. Set frame rate to 60fps in the same Video settings menu.
  2. Configure output format. Go to Settings → Output → Recording. Set the recording format to MP4 and the encoder to your GPU’s hardware encoder (NVENC for NVIDIA, AMF for AMD) for lighter CPU impact. Set bitrate to at least 8,000 Kbps for clean 1080p footage.
  1. Click Start Recording when you’re in-game.
Pro Tip: If you set OBS to a 1080×1920 canvas and scale your game capture source to fill the frame, you capture natively vertical footage. This works especially well for mobile game emulators or when you want a specific portion of the gameplay centered in the frame from the start.
Using Xbox Game Bar (Built-In, Zero Setup)
Xbox Game Bar is already installed on Windows 10 and 11. It’s the fastest way to grab a clip without touching any settings.
  1. Open your game and start playing.
  2. Press Win + G to open the Game Bar overlay.
  3. Click the Capture widget (or press Win + Alt + R to start recording immediately without opening the overlay).
  4. To save just the last 30 seconds of gameplay as a clip, press Win + Alt + G.
  5. Recordings save automatically to **C:[YourName]* in MP4 format.
  6. To adjust clip length, go to Settings → Gaming → Captures in Windows and change the background recording duration.
When to use it: Xbox Game Bar records in 1920×1080 (horizontal only). It’s the right choice for quick, low-friction clips you plan to crop in editing. It’s not the right choice if you want native vertical output or advanced quality settings.
Note: GeForce Experience / NVIDIA ShadowPlay is a strong alternative for NVIDIA GPU users. The Instant Replay feature (Alt + F10 by default) works similarly to Xbox Game Bar’s background recording and captures the last few minutes of gameplay in high quality with minimal performance hit.
How to Record Gameplay for YouTube Shorts on Console (PS5 & Xbox)
Both PlayStation 5 and Xbox Series X|S include built-in capture hardware. For most Shorts creators, this is all you need.
Using Your Console’s Built-In Capture
On PS5: 1. Press the Create button (left side of the DualSense controller) to open the Create menu. 2. Select Save Recent Gameplay to capture the last 15, 30, or 60 seconds automatically, or choose Start New Recording to record manually. 3. Set your default clip length in Settings → Captures and Broadcasts → Captures. For Shorts, 30–60 seconds is ideal. 4. Transfer clips to your phone or PC via USB drive, the PS App, or PlayStation’s media gallery share options.
On Xbox Series X|S: 1. Press the Share button (small button on the top of the controller) to save the last 30 seconds automatically. 2. For longer or custom recordings, press and hold the Share button to open capture options, then select Start Recording. 3. Manage and share clips through the Xbox app on PC or mobile, or move them via USB.
Resolution note: PS5 captures at up to 4K; Xbox captures up to 4K on Series X. For Shorts, you’ll downscale to 1080p during editing — recording at higher resolution gives you more reframing flexibility.
Using a Capture Card for More Control
A capture card sits between your console and your PC, sending your gameplay video to OBS or similar software running on your computer. The signal path is: console video output → capture card → PC via USB or PCIe → OBS records the feed.
This setup is worth it if you want to edit on PC with full-quality footage, add overlays during recording, or avoid the transfer step entirely. Look for cards with at least 1080p60 capture capability — brands like Elgato and AVerMedia are the most widely supported. USB capture cards (like the Elgato HD60 X) are easier to set up and don’t require opening your PC case.
How to Record Gameplay for YouTube Shorts on Mobile
Mobile is the most beginner-friendly path for Shorts — and arguably the most advantageous, because portrait-mode mobile games record natively in 9:16. No cropping required.
On iOS (iPhone): 1. Go to Settings → Control Center and add Screen Recording to your Control Center if it isn’t there already. 2. Open your game, then swipe down from the top-right corner to open Control Center. 3. Long-press the Screen Recording button to toggle microphone audio on (for live commentary) or leave it off. 4. Tap Start Recording. A 3-second countdown begins, then your screen is captured. 5. Stop recording by tapping the red status bar at the top and selecting Stop. The clip saves to your Photos library.
On Android: 1. Swipe down from the top of your screen to open the Quick Settings panel (swipe twice if needed). 2. Tap Screen Recorder (tile label varies by manufacturer — Samsung calls it “Screen Recorder,” Pixel devices call it “Screen Record”). 3. A prompt will ask whether to record audio — select Device audio and microphone if you want commentary captured live. 4. Tap Start, play your game, then tap the stop button in the notification bar when finished. The clip saves to your Gallery.
Tip: If your Android doesn’t have a built-in screen recorder, check your device manufacturer’s settings app or update your OS — most Android 10+ devices include it natively.
How to Format and Crop Gameplay Footage for Shorts
If you recorded on PC or console in 16:9, you need to reframe it to 9:16 before uploading. This section covers three tools and one key concept that separates clean Shorts from awkward letterboxed clips.
The “safe zone” rule: Keep the primary gameplay action — the player character, the kill cam, the key moment — in the vertical center of the frame. The upper and lower portions of a 16:9 crop are usually HUD elements or empty space. Your goal is to pan the crop to wherever the action lives.
Option 1 — CapCut (Free, Mobile-Friendly): 1. Import your clip into CapCut. 2. Tap Ratio and select 9:16. 3. Use the pan/position tool to center the action. 4. Trim to under 60 seconds and export at 1080p.
Option 2 — DaVinci Resolve (Free, PC/Mac, More Control): 1. Create a new project. In Project Settings, set the Timeline Resolution to 1080×1920. 2. Import your 16:9 clip and drop it onto the timeline. It will pillarbox by default. 3. Select the clip, open the Inspector, and use Zoom and Position Y/X controls to pan and scale the crop to fill the frame. 4. Export via Deliver page using the YouTube preset, then manually confirm resolution is 1080×1920.
Option 3 — YouTube’s Built-In Shorts Editor: 1. Start an upload via the YouTube app. 2. Select your clip and tap Edit. 3. YouTube allows basic cropping, trimming, and text overlays natively inside the app — sufficient for simple Shorts with minimal editing.
Adding Voice Commentary to Your Gameplay Shorts
Commentary is what separates watchable Shorts from forgettable ones. You have three realistic microphone tiers:
  • Built-in device mic: Works in a quiet room. Quality is inconsistent and picks up background noise easily.
  • Gaming headset mic: A practical step up that most console and PC players already own. Good for static desk setups.
  • Compact wireless mic: The most versatile option, especially for mobile creators or anyone recording in a room they share with others.
For wireless mic options, the Hollyland LARK M2 is a practical pick for gaming setups — its coin-sized transmitter (9g) clips onto clothing and doesn’t require a mic arm or desk stand, making it easy to add clean commentary without rearranging your whole space. The 40-hour combined battery life means it won’t die mid-session. If you’re a mobile-only creator on a tighter budget, the Hollyland LARK A1 plugs directly into your iPhone or Android for plug-and-play simplicity — no transmitter setup, no Bluetooth pairing.
Whichever mic you use, record commentary either live during gameplay (lower effort, more authentic energy) or as a voice-over in post (cleaner, more controlled delivery).
Quick Editing and Uploading Your Shorts
Shorts editing should be fast and purposeful — the format rewards tight pacing over production polish.
  1. Trim to under 60 seconds. Cut aggressively. Identify the peak moment — the clutch play, the funny reaction, the satisfying finish — and build the clip around it.
  2. Add captions or on-screen text. Auto-captions in CapCut or manual text overlays drive significantly higher engagement on Shorts. Even a hook phrase in the first 2 seconds helps retention.
  3. Add music or sound effects. Use YouTube’s Audio Library or CapCut’s built-in music to add energy. Keep voice commentary audible above background music.
  4. Export settings: MP4, H.264, 1080×1920, 60fps, bitrate of 8–15 Mbps.
  5. Upload via YouTube app: Tap the “+” button, select your clip, and YouTube will automatically detect and format it as a Short if it’s 60 seconds or under and in 9:16. Add a title, description, and hashtags including #Shorts.
  6. Upload via desktop Creator Studio: Go to studio.youtube.com, click Create → Upload Videos, upload your file, and confirm the Shorts format during the setup steps.
Can I upload horizontal gameplay to YouTube Shorts? You can upload a 16:9 video under 60 seconds, but YouTube may not surface it as a Short — it might appear as a standard short video instead. Cropping your footage to 9:16 before uploading is the safest way to ensure it’s treated and distributed as a Short in the feed.
What’s the best free software to record gameplay for Shorts? OBS Studio is the best free option for PC — it’s highly configurable and supports native vertical recording. For mobile, your phone’s built-in screen recorder (iOS Control Center or Android Quick Settings) costs nothing and captures natively in 9:16, making it the simplest starting point.
How long can a YouTube Short be? The standard limit is 60 seconds. YouTube has been testing and rolling out a 3-minute Shorts limit in some regions and accounts. Check your YouTube app or Creator Studio to see which limit applies to your channel — the experience may vary.
What resolution should I record for YouTube Shorts? Record at 1080×1920 (1080p vertical) if your setup supports it. If you’re recording in 16:9 first and cropping in post, record at 1920×1080 or higher so you retain enough resolution after the crop. 720×1280 is the minimum acceptable quality for Shorts.
Do I need a capture card to record console gameplay for Shorts? No. Both PS5 and Xbox Series consoles have built-in capture that’s more than sufficient for YouTube Shorts quality. A capture card is a worthwhile upgrade only if you want to edit on PC with direct-feed footage or add overlays — it’s not a requirement for most Shorts creators starting out.
Start With What You Have
The right recording method is the one that matches the device you’re already using. PC creators should start with Xbox Game Bar for quick clips or OBS Studio for full control. Console players can rely entirely on built-in capture. Mobile creators are already set up for the native Shorts format by default. Don’t wait until you have the perfect setup — your first Shorts just need to be vertical, under 60 seconds, and in focus. Start there, then refine as you grow.
Ready for the next step? Check out our guide on editing gameplay Shorts for faster pacing and higher watch time — or explore how to grow a gaming channel on YouTube from zero.
