YouTube Shorts has become one of the fastest-growing formats for short-form video, and the audio inside those clips is often just as valuable as the visuals. Whether you heard a perfect sound clip in someone’s Short and want to save it, or you’re building your own Shorts library and need to understand your audio options, the process isn’t always obvious. This guide walks through every practical method—clearly, without the fluff.
Two Ways People Use “Audio from YouTube Shorts”
“Audio from YouTube Shorts” means two different things depending on who’s asking. The first group wants to extract or download audio from an existing Short someone else posted—to sample it, archive it, or repurpose it. The second group is creators who want to add audio to their own Shorts or record better original sound. Both needs are valid, and this article covers both:
Extracting audio from a YouTube Short you’ve found
Using or recording audio when creating your own Shorts content
How to Extract Audio from a YouTube Shorts Video
YouTube doesn’t include a native “download audio” button, so you’ll need a workaround. Here are three methods ranked from easiest to most advanced.
Method 1 — Use an Online Audio Converter (Easiest)
Online converters are the lowest-friction option and require no software installation. Reputable tools include Y2Mate, 4K YouTube to MP3, and OnlineVideoConverter. Here’s the standard workflow:
Open the YouTube Short in your browser and copy the URL from the address bar.
Navigate to your chosen converter site and paste the URL into the input field.
Select MP3 as your output format (most converters also offer AAC or M4A).
Click Convert or Download and save the file to your device.
A few things to keep in mind: Output quality is capped by the source file—if the original Short was uploaded at low bitrate, the extracted MP3 will reflect that. Most free converter sites are also ad-heavy, so use an ad blocker and avoid clicking anything other than the main download button. Stick to tools that don’t require account creation or app installs to stay safe.
Method 2 — Use yt-dlp (Most Reliable, Intermediate)
For anyone comfortable with a terminal or command prompt, yt-dlp is the gold standard. It’s free, open-source, actively maintained, and pulls the highest-quality audio stream available without compression artifacts introduced by third-party web tools.
Install it via Python’s package manager (pip install yt-dlp) or download a standalone binary from the official GitHub repository.
winget install yt-dlp
You should see a “Successfully Installed” confirmation, similar to the screenshot below, after downloading dependencies.
Then run a single command:
yt-dlp -x --audio-format mp3 [PASTE SHORTS URL HERE]
The -x flag tells yt-dlp to extract audio only, and --audio-format mp3 converts it to MP3 on the way out. You can swap mp3 for m4a or opus depending on your needs. yt-dlp handles Shorts URLs identically to standard YouTube URLs—no special syntax required.
Why choose this over a web converter? No ads, no sketchy redirects, consistent quality, and full control over output format and filename. The trade-off is a basic level of command-line comfort, which makes this method better suited to editors, podcasters, and tech-savvy users than to casual listeners.
Method 3 — Screen Record with System Audio (Fallback)
If a Short is restricted, behind an age gate, or the converters keep failing, screen recording with system audio captured simultaneously is your fallback. The fidelity won’t match a direct extraction, but it works when nothing else does.
iOS: Enable Screen Recording in Control Center. Plug in wired headphones, start Screen Record while holding the icon to enable microphone, then play the Short. Audio is captured through the headphone passthrough loop.
Android: Most modern Android devices have a built-in screen recorder with “record audio from device” enabled in settings. AZ Screen Recorder is a reliable third-party alternative if yours doesn’t.
Desktop:OBS Studio (free, cross-platform) can capture any audio playing through your speakers or virtual audio cable. QuickTime on macOS works similarly for quick captures.
The main trade-off: you’ll capture any notification sounds or UI audio that plays during recording, and you’ll need to manually trim the clip to the audio you want in any basic audio editor.
Copyright Rules Before You Use That Audio
Before you do anything with extracted audio, you need to understand what you’re actually allowed to do with it.
Music and sounds used in YouTube Shorts are typically licensed to YouTube, not to you. That license lets the platform host the content—it does not transfer redistribution rights to viewers. Extracting a clip for your own private listening is a legal grey area in most jurisdictions, but using that extracted audio in your own public content—on YouTube, TikTok, Instagram, or anywhere else—is a different matter entirely.
Key risk: YouTube’s Content ID system scans uploaded audio. If you use a copyrighted song extracted from someone’s Short in your own video, Content ID will likely flag it. Depending on the rights holder’s policy, your video could be muted, monetized by someone else, or taken down entirely.
Safe alternatives that cost nothing:
YouTube Audio Library (studio.youtube.com/channel/[your channel]/music) — thousands of tracks cleared for use in monetized content
Free Music Archive and ccMixter for Creative Commons-licensed audio
Pixabay Music for royalty-free tracks without attribution requirements
Note: If you’re extracting audio for commercial use, content creation, or redistribution, always verify the track’s license independently—don’t assume extraction equals permission.
How to Use Sounds from Other Shorts in Your Own Content (Platform-Native Method)
If you’re a creator who wants to use audio from an existing Short, YouTube’s built-in “Use This Sound” feature is the cleanest, safest route—because the platform handles the licensing automatically.
Here’s how it works:
Open any YouTube Short in the mobile app.
Tap the music note icon or the sound name displayed at the bottom of the screen.
On the sound’s page, tap “Use This Sound.”
The Shorts camera opens with that audio pre-loaded and ready to record over.
The original creator stays credited in your Short’s metadata, and YouTube’s licensing layer remains intact—no Content ID risk. The limitation is that not every Short has this option enabled. If the creator disabled it or the audio wasn’t properly licensed through YouTube’s system, the button won’t appear.
For broader audio discovery, YouTube Studio includes a built-in audio library where you can browse trending sounds, filter by mood or genre, and preview tracks before committing. Access it at studio.youtube.com → Content → Audio Library.
Record Original Audio for YouTube Shorts That Actually Sounds Good
Trending sounds and extracted clips are useful, but original audio is what builds a distinct creator identity—and it performs better in the algorithm over time because it can’t be flagged or muted. The challenge is that phone microphones struggle with background noise, room reverb, and distance from the subject.
A few quick habits make an immediate difference:
Record in smaller, softer rooms (a closet works surprisingly well) to reduce echo.
Position your phone as close to your mouth as possible—12 inches beats six feet every time.
Avoid HVAC noise by recording away from vents, fans, and open windows.
For creators who want to take a real step up, a compact wireless microphone designed for mobile shooting is worth the investment. The Hollyland LARK M2 is purpose-built for exactly this format: it weighs just 9 grams, so it sits invisibly on a shirt collar or lapel without showing on camera. Its 40-hour battery life means you can shoot Shorts all day without stopping to charge, and the built-in noise cancellation handles the kind of ambient environments—busy streets, cafés, outdoor locations—where Shorts are typically filmed. One microphone, no cables, audio quality that online converters and trending sounds simply can’t match.
Q1: Can you download audio from YouTube Shorts directly on the app?
No. YouTube’s mobile app does not include a native audio download or export feature for Shorts. To save audio from a Short, you’ll need to use a third-party method such as an online converter, yt-dlp, or a screen recording workaround as described in this article.
Q2: Is it legal to download audio from YouTube Shorts?
Extracting audio for strictly personal, private use is a legal grey area that varies by country. However, redistributing, publishing, or using copyrighted audio from a Short in your own public content without a license is not permitted and can result in Content ID claims, video removal, or account strikes.
Q3: Why does the extracted audio sound muffled or low quality?
YouTube compresses all uploaded video, including Shorts, which caps the audio bitrate of the source file. yt-dlp will grab the best available stream, but if the original uploader’s audio was poor, extraction can’t recover what isn’t there. Online converters often add a second layer of compression, degrading quality further.
Q4: What is the “Use This Sound” feature on YouTube Shorts?
“Use This Sound” is a platform button that lets you open YouTube’s Shorts camera with another creator’s audio pre-loaded, so you can record original footage set to that clip. The original creator remains credited automatically. It’s the safest, most compliant way to incorporate sounds from other Shorts into your own content.
Q5: Can I use YouTube Shorts audio in a TikTok or Instagram Reel?
Technically, you can extract and upload it—but the copyright restrictions travel with the audio, not with the platform. A song licensed for use on YouTube is not automatically cleared for TikTok or Instagram. Using it publicly on another platform carries the same infringement risk and may trigger content moderation on those platforms as well.
What to Do Next
If you’re extracting someone else’s audio, use yt-dlp or a trusted converter for the best quality—and stop at personal use unless you’ve verified the license. If you’re building your own Shorts, invest in clean original audio from the start; it’s the one element that’s entirely yours. Start with the YouTube Audio Library for free, safe background music, or explore our guide to Shorts creation best practices to build a channel that lasts.
