DaVinci Resolve Arm for Record Not Working: 7 Fixes That Actually Work
Recording sound in DaVinci Resolve’s Fairlight page feels simple at first. Still, the record arm option can fail without warning. Sometimes the button stays grey or does nothing. Other times, it seems active but records no audio. Most issues come from a few setup problems. This guide goes through each cause step-by-step. It starts with basic checks and moves to deeper settings.
What “Arm for Record” Does in DaVinci Resolve and Why It Breaks?
The arm for record button is a Fairlight-page-specific feature. When activated on an individual track, it tells DaVinci Resolve that this track should receive live audio input and capture it when the global transport record button is pressed. The two controls work together: the per-track arm button selects which tracks record, and the transport record button actually starts capture.
Many users discover the issue here first. Pressing the transport record button alone does nothing if no tracks are armed. Pressing a track’s arm button without pressing the transport record also does nothing. Both must be active at the same time.
Beyond those two controls, several conditions must all be true simultaneously for recording to work: the track must be of the correct type (Audio, not Bus or Aux), a valid hardware audio input must be assigned to the track, the correct audio device must be selected in DaVinci Resolve’s preferences, and the Fairlight Patch Bay must route that input to the track. A failure at any single point breaks the entire chain, often with no clear error message.
Quick Pre-Troubleshooting Checklist
Before working through each fix, run through this list. Many users resolve the problem here in under a minute.
  • Are you on the Fairlight page? Recording is not available on the Edit page.
  • Is the track type set to Audio? Bus and Aux tracks cannot be armed for recording.
  • Is your audio device physically connected and recognized by your operating system?
  • Is the per-track arm button (the “R” icon in the track header) highlighted red?
  • Does the track have an audio input assigned? A track with no input cannot arm properly.
  • Does the project sample rate match your audio device’s sample rate?
  • Has DaVinci Resolve been granted microphone permission in your OS privacy settings?
Fix 1 — Verify the Track Is Properly Armed
This is the most common cause of recording failure, especially for users new to Fairlight.
  1. Navigate to the Fairlight page using the page switcher at the bottom of the screen.
  1. Locate the track header on the left side of the timeline. Look for a small button labeled “R” (or shown as a red circle depending on your version).
  1. Click the “R” button on the specific track you want to record. It should turn red or highlight to indicate the track is armed.
  1. Next, confirm the global record button on the transport bar (the red circle at the bottom center) is also active before you press play to record.
  2. If the “R” button appears greyed out and cannot be clicked, check the track type. Right-click the track header and look at track properties. Bus and Aux tracks do not have a record-arm function. Only standard Audio tracks can be armed.
When armed correctly, the track header will show a red indicator, and the track lane may display a red tint. If you are not seeing this, move to Fix 2 before anything else.
Fix 2 — Assign an Audio Input to the Track
A track with no audio input assigned cannot be armed, even if everything else is configured correctly.
  1. Right-click the track header in the Fairlight timeline.
  1. Select “Change Track Input” from the mixer.
  1. A dialog will appear listing available input sources. Select the appropriate hardware input or input bus that corresponds to your recording device.
  2. Confirm the selection and attempt to arm the track again.
And now you should be able to record the audio too. Just click the round record button to check.
In Fairlight’s routing model, hardware inputs must first be patched through the Patch Bay before they appear as selectable sources here. If your device does not appear in this list, proceed to Fix 4 to configure the Patch Bay first, then return to this step.
Note: If you are using a wireless microphone system such as the Hollyland LARK MAX 2, ensure the receiver is connected via USB or your audio interface and that your operating system has fully recognized it as an audio device before attempting to select it as an input in DaVinci Resolve.
Fix 3 — Check Audio Device Settings in DaVinci Resolve Preferences
Even if your device works system-wide, DaVinci Resolve maintains its own audio device selection that can fall out of sync after a system update or new device connection.
  1. Go to DaVinci Resolve menu → Preferences.
  1. Select the System tab, then navigate to Video andAudio I/O.
  1. Under the input section, confirm that your intended audio device is selected. If the field shows “None” or an incorrect device, click the dropdown and select the correct one.
  1. Click Save and allow DaVinci Resolve to apply the change.
Sample Rate Mismatch: If your project sample rate (set in Project Settings → Master Settings) does not match your audio device’s native sample rate, DaVinci Resolve may fail to arm tracks silently. Check both values and make sure they match — common rates are 44.1 kHz and 48 kHz. Correct the mismatch in either the project settings or your audio device’s control panel, then restart DaVinci Resolve.
Fix 4 — Configure the Fairlight Patch Bay Correctly
The Patch Bay is the most frequently overlooked configuration step, and it is the reason many intermediate users get stuck even after completing everything else correctly.
  1. In DaVinci Resolve on the Fairlight page, go to the top menu and select Fairlight → Patch Input/Output.
  1. The Patch Bay opens with two panels. The left panel lists hardware inputs (your physical audio device channels). The right panel lists Fairlight track inputs.
  1. Click a hardware input source on the left, then click the corresponding track input on the right to draw a connection (patch) between them.
  2. A line or highlight will confirm the connection is active.
  3. Click the “Patch” button and return to your track. The patched hardware input should now appear as an assignable source in Fix 2.
Without an active patch, DaVinci Resolve has no way to route your hardware signal into a track, regardless of what is selected in preferences. The Patch Bay effectively acts as a virtual cable between your physical device and the Fairlight recording chain. This single step resolves the problem for a large proportion of users who have done everything else correctly.
Fix 5 — Grant System Audio Permissions to DaVinci Resolve
Operating system privacy controls can block DaVinci Resolve from accessing any microphone input entirely. This is especially common after major macOS updates or on fresh Windows installs.
macOS
  1. Open System Settings (or System Preferences on older macOS versions).
  2. Navigate to Privacy & Security → Microphone.
  3. Scroll through the app list and confirm DaVinci Resolve is toggled on.
  4. If it was previously off, toggle it on, then fully quit and relaunch DaVinci Resolve.
Windows
  1. Open Settings → Privacy → Microphone.
  2. Ensure “Allow apps to access your microphone” is turned on.
  3. Scroll down to “Allow desktop apps to access your microphone” and confirm it is also enabled.
  4. Restart DaVinci Resolve after making changes. Changes do not apply to a running session.
Fix 6 — Reset Audio Preferences or Reinstall Audio Drivers
If all previous fixes have failed, corrupted preference files or outdated audio drivers are the remaining likely causes.
  • Reset DaVinci Resolve preferences:
  • macOS: Delete the preferences folder at ~/Library/Preferences/Blackmagic Design/DaVinci Resolve/
  • Windows: Navigate to C:\Users\[Username]\AppData\Roaming\Blackmagic Design\DaVinci Resolve\ and delete or rename the preferences folder
  • Reinstall or update your audio interface drivers from the manufacturer’s website. Do this even if the device appears functional, as driver corruption can cause silent failures in DAW applications.
  • After resetting preferences, relaunch DaVinci Resolve and reconfigure your Audio I/O and Patch Bay settings from scratch.
Q1: Why is the arm for record button greyed out in DaVinci Resolve?
A greyed-out arm button usually means the track has no audio input assigned, the track type is set to Bus or Aux rather than a recordable Audio track, or no valid audio device is selected under Preferences → System → Audio I/O. Check all three conditions before moving to more advanced troubleshooting steps.
Q2: Can I arm for record on the Edit page in DaVinci Resolve?
No. Track recording is exclusively a Fairlight page function. The Edit page does not expose track arming or the Fairlight recording workflow. Switch to the Fairlight page using the page switcher at the bottom of the DaVinci Resolve interface to access all recording controls. Contrarily, you can use the Voiceover Tool in the “Edit” page, shown as a microphone icon in the timeline bar. It sets up the recording input and track automatically in the background. This lets you capture audio without leaving the edit space or adjusting extra routing manually.
Q3: DaVinci Resolve shows my audio device, but still won’t record — what’s wrong?
The device appearing in Preferences does not mean the Patch Bay is configured. Open Fairlight → Patch Input/Output and verify that your hardware inputs are actively routed to track inputs. A missing patch connection is the most frequently missed step, even when the audio device is fully recognized by both the OS and DaVinci Resolve.
Most arm for record failures in DaVinci Resolve resolve at Fix 1, Fix 2, or Fix 3. The Patch Bay configuration in Fix 4 catches the majority of the remaining cases. System permissions and driver resets are last-resort steps that apply only to a small subset of users. Work through the checklist and fixes in order rather than jumping ahead, and you will reach the root cause faster.
