Mini Tripod Stand with Universal Clip
$19.00
Multifunctional Tripod:
• Compact and lightweight with only 170g
• Foldable design for both handheld and desktop use
• 4-section extendable design to adapt different scenarios
• Mini and portable with a folded height of only 22cm
• 1/4"-20 male mount to easily install accessories, such as a mic or light
Designed with cold shoe port on the side for more add-ons
• Supports payload up to 1.5kg
• 360-degree rotation metal tripod ball head with enhanced locking force
Mini Anti-slip Universal Clip:
• Compact and lightweight with only 26g
• Supports max. payload of 2kg
• Designed with cold shoe port on the side for extra add-ons
• Bottom 1/4"-20 female mount for easy tripod installation
• Designed with non-slip pad locks to hold secure your smartphone
